22+ 3rd Gen Wheel offsets/fitment thread
Discussion in 'Wheels & Tires' started by randomquickness, Dec 23, 2021.
  1. May 13, 2022 at 3:15 PM
    #391
    hasselhof
    hasselhof New Member
    Finally got these mounted after fedex lost not one, but two separate packages (original order and then replacements). 17x8 +5 trd pro sema replicas. 305/70r17 cooper at3 xlt
    D2945710-BCB5-4D7B-9FD3-A546EDEB1CEC.jpg 72CD78B9-2F67-4E12-B01A-67A4350FB578.jpg 4CFDC025-8B1A-447C-B951-F0D0AF9EA7C3.jpg
    still waiting on my procomp coils and some other odds and ends. Happy with the look and performance so far.
    Sparky916, sbxx312, dekeman and 3 others like this.
  2. May 14, 2022 at 9:12 AM
    #392
    bigjuice
    bigjuice Spring hath arrived…
    WA State
    2024 Terra TRD Pro
    Is that the slimline GoRhinos (4” wide) or the Regular width ones ?
  3. May 14, 2022 at 11:37 AM
    #393
    hasselhof
    slimline rb20’s. I prefer no running boards but the wife is only 5’3” lol and my 6 yr old needs a running start to get in even at stock height. Welding up some custom brackets though as the go rhino ones drop down too much imo.
    bigjuice[QUOTED] likes this.
  4. May 14, 2022 at 11:46 AM
    #394
    Ride123ca
    Ride123ca New Member
    hasselhof.....would love info on the yakima/prinsu setup....wasnt aware yak had 22 availability....what are the bars on top of the rear racks? How do u like them?....was debating the yak vs thule adjustables....tia
  5. May 14, 2022 at 8:30 PM
    #395
    hasselhof
    rear platform is prinsu as well. The Yakima overhaul Is not technically a 22 setup, I had bought the rack with intention of Installing on a retraxone, but it took forever to get the tonneau. I ended up removing the side deck rail systems and installing it with the clamps. I have the tonneau now, but Yakima has nothing in stock currently and I can’t get the tonneau mounting kit. Side bars took me months to get. Also have been waiting for smaller 60”
    Cross bars.
    I’ll be happy with the setup when I have everything in hand. During ski season I put on low crossbars to transport skis. The tslots on the retrax makes that easy.
  6. May 15, 2022 at 1:37 AM
    #396
    Ride123ca
    Ahhhh.....thanks hasselhoff! Seems by the time these manufacturers get products designed for our trucks the 23 will be out....lol
  7. May 15, 2022 at 1:24 PM
    #397
    n8banga
    n8banga New Member
    Nate
    Hi everyone, thank you in advance for any help. About to order new wheels and tires before my delivery on Tuesday!
    Truck is a 22/ Platinum with AVS. Ideally would like to remain stock/ no lift or level looking at
    Fuel SLEDGE 20 x 9 (NOT SURE ABOUT 19 OR 20 Offset would be better
    Tires - 275/65/20 Nitto Terra Grappler G2.
    Do you think this will still drive good with the slightly larger tires? I drive a lot/ made a mistake getting mud tires and a level from a iffy shop on an old truck and i'm not trying to make that mistake again. But any advice on if this will fit/ if there will be any rub/ any better recommendations for a tire size and the offset of 19 or 20 before i order it would be greatly appreciated.
  8. May 15, 2022 at 7:17 PM
    #398
    hairychestedfrog
    hairychestedfrog New Member
    Idaho
    22 Tundra SS Red Plt CM
    You'll be fine w/o a lift, the offset will fit well also (assuming +)
  9. May 15, 2022 at 7:47 PM
    #399
    Ride123ca
    Yup....a +18 or 19 looks killer with a 27to a 35"
  10. May 15, 2022 at 7:52 PM
    #400
    smurfskier
    smurfskier New Member
    22 Tundra
    Love the ski the east license plate frame
  11. May 15, 2022 at 10:14 PM
    #401
    n8banga
    n8banga New Member
    Nate
    I finally went to order everything and discount tire won’t let me order it because it says they won’t fit maybe I should pick a random car?
  12. May 15, 2022 at 10:20 PM
    #402
    bigjuice
    WA State
    2024 Terra TRD Pro
    Funny…I thought they had an option that showed +1 and +2 size’s up but didn’t realize it would prevent you from ordering (though I see the logic).
    You will need to go into the store (best bet) as their online store like most places hasn’t been updated to show the upsize fits…
    …or give them a call.
    hairychestedfrog likes this.
  13. May 16, 2022 at 6:07 AM
    #403
    99ways2die
    99ways2die New Member
    OEM Platinum wheels with Cooper Discoverer AT3 XLT in 285/60/20 with BORA 1" spacers.
    Just to give any one a good idea of the outcome.
    Pic1: Front wheel-no spacer; rear-spacer installed:
    Pic2: Spacers on both wheels:
    Pic3: Spacers on (front view):
    Pic4: Side view/mirror:
  14. May 16, 2022 at 6:46 AM
    #404
    Swarley
    Swarley New Member
    Thanks for the visuals. Anyone know if the OEM Platinum wheels have the same offset as 18" TRD offroad wheels (+60)?
  15. May 17, 2022 at 9:13 PM
    #405
    Troa
    Troa I blue it again.......
    Nomad
    2022 Blueprint Limited
    I posted this in another thread already, but I figured I'd post here as well in case anyone else is considering a similar setup. Really fills the wheel wells nicely without affecting ride quality or needing any supporting efforts/mods.
    Pirelli Scorpion AT+ 275/65r20 P-rated tires on the stock Limited TRD wheels with stock suspension and no spacers. They're 34.1"x10.8" vs the factory 32.5"x10.4". Largest tire I could find without stepping up to an E load rating.
    No poke. No rub. Didnt even pin back the liners.
    Drives exactly like stock with just a touch heavier steering. No perceived increase in road noise. Exactly what I wanted! MPG differences TBD. I had 16mpg average on the computer for the first 600 miles. Not a great baseline lol
    Ohbewan23, gnc1017, roti and 6 others like this.
  16. May 18, 2022 at 6:50 AM
    #406
    Breathing Borla
    Northern Illinois
    cool, Ive been poking around looking for a larger P rated set up, damn hard to find. Im thinking about a platinum truck and want to go lighter set-up this time and not Load E and heavier wheels, etc.
    well done.
    how are the on-road manners?
  17. May 18, 2022 at 6:55 AM
    #407
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    Weight is key, really wanted a set of TE37’s but didn’t want to drop $2k extra on wheels. Found this company online with great reviews- 17’s weight 21.5 lbs. https://www.blackhornoffroad.com/collections/toyota/products/bh01br
    My toyo AT3 35x12.5x20’s weight 60lbs each so my new set up will be about 6lbs heavier per wheel than the stock Off-road 20’s with fallen tires based off other folks weights
  18. May 18, 2022 at 7:10 AM
    #408
    Troa
    Nomad
    They're excellent. A bit more resistance when turning the wheel and they seem to want to unwind the steering with a bit more force when straightening out from a tight corner, but that's about the biggest difference I've noticed so far. Only driven them on city streets for about an hour and freeway for about 30 minutes so far, but they seem extremely close to stock.
  19. May 20, 2022 at 2:34 PM
    #409
    CarlsSenior303
    CarlsSenior303 New Member
    Carl
    2022 Tundra Limited TRD Offroad Army Green (hopefully)
    I'm sure this has been asked/answered but I've searched around and not found anything - does anyone know the max tire size that can go on the 2022 Limited TRD Offroad stock + without any mods (leveling kit, lift, cutting, etc...)? It has the 20" TRD Offroad wheels. Was hoping for at least 285/60/R20 in the Falken Wildpeak AT3W, since the AT3Wa that came on them look the same as the tires on my wife's highlander lol.
    I asked my local shop, and they are recommending 275/60R20, otherwise they said they would need to install a leveling kit. Thanks in advance!
  20. May 20, 2022 at 4:10 PM
    #410
    DexterL
    DexterL New Member
    35x11.5x20 fits
    bigjuice likes this.
  21. May 20, 2022 at 5:14 PM
    #411
    99ways2die
    In case any one wants to know what a Platinum looks like on a Westcott 3/1 kit (well, they state that AVS/air trucks end up with 2" only in the front and they are correct).
    Anyway,
    2" gain in the front
    1.5" gain in the back
    1.5 rake front to back
    285/60/20 Cooper Discoverer AT3 XLT
  22. May 22, 2022 at 9:11 PM
    #412
    fordguy1470
    fordguy1470 Member-ish
    West Columbia, SC
    22 CM SR5
    Getting there
    Where did you get the amber fogs? I dig those.
  23. May 23, 2022 at 9:47 AM
    #413
    Troa
    Nomad
    I fit 275/65r20 no issues. Slightly wider than the 35x11.5s mentioned above, but also a little shorter (Theyre 34.1x11.8)
  24. May 23, 2022 at 12:48 PM
    #414
    Joshuak175
    Joshuak175 New Member
    Have you confirmed they fit? I just called and they said there wasn’t enough room between wheel and calipers.
  25. May 29, 2022 at 9:10 AM
    #415
    roti
    roti New Member
    Quoting to confirm this has also been my experience. Just put on some ridge grapplers in same size on stock suspension and wheels for my TRD sport and it honestly feels the exact same as stock. Just slightly more noise as I ramp up speed from a stop sign or light but overall I’m very happy.
    0 rub whatsoever and did not have to touch the liner at all either.
    ScottieBones and Troa[QUOTED] like this.
  26. May 30, 2022 at 2:15 PM
    #416
    brucega7x
    brucega7x New Member
    2022 Tundra SR5 CrewMax 4X4
    I have the 20" TRD wheels and it looks like there's no lock nut? I thought they all had one lock nut on each wheel?
  27. May 30, 2022 at 4:05 PM
    #417
    hasselhof
    laminx film. Heretic makes a replacement set but not about to pay $550 lol.
    will be adding a yellow 20” light bar to the center ‘tundra’ bumper bar as well. Just waiting for parts to show.
  28. May 31, 2022 at 12:05 AM
    #418
    bigjuice
    WA State
    2024 Terra TRD Pro
    Westcott design has a set coming out also.
    https://youtu.be/Q300BzwUU3s
    Sparky916 likes this.
  29. May 31, 2022 at 2:06 PM
    #419
    Sparky916
    Sparky916 New Member
    Blake
    22 Lunar Rock Limited TRD OF
  30. Jun 20, 2022 at 8:41 AM
    #420
    gr8fasushi
    gr8fasushi 22 Tundra Limited TRD Off Road
    anyone running +25 offset? I'm curious how much poke that would look like. I'm thinking of getting the Method 305 17x8.5 +25 offset.
