  1. May 11, 2022 at 9:13 AM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    we build a twin engine push-me pull-me and id be all over it. But i cant fwd. regardless of what my brain says, my heart will try to powerslide out of trouble. Almost sent my buddies srt4 off a cliff, and sent his civic si into all the cones while trying to auto-x.
    bmf4069[QUOTED] likes this.
  2. May 11, 2022 at 9:24 AM
    It is when you're a "collector of stuff" (light or heavy hoarder) and get to the point where doing that requires a 1-2 day investment to get to everything once a quarter.
    Those are the exact kind of situations where it can't hurt to throw out an offer. "I see all that stuff you've got there ... would you rather have $2,500 in cash instead?" which has netted me soem great stuff. Clean up the things you don't want to keep, set aside one or two you do, then re-sell the cleaned stuff to get rid of for more than you paid for the lot. In some cases, I've managed to 10x-20x my profit on something *and* get to keep the real gems out of it.
    Then again, doing that too much is a very quick way to become a "collector of stuff".
    NUDRAT[OP] and bmf4069 like this.
  3. May 11, 2022 at 9:54 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    Limited slip diff and a little practice and that FWD will pull you around a corner and out of trouble.
  4. May 11, 2022 at 1:10 PM
    One of em does have a LSD.
    chrisb[QUOTED] and Sirfive like this.
  5. May 11, 2022 at 1:15 PM
    4WD conversation w/someone at work today.
    "Hey, what would happen if you, like, put your truck in 4HI and took a slow, sharp-radius turn on asphalt?"
    "I dunno, I doubt I'd ever do something like that... I'm assuming it'd start binding and chunking once you turned past a certain point."
    Anyway, I didn't know how to answer what, if anything, would ultimately break. I've always been told "Don't do that, in 4HI and especially not 4LO".
    What actually would happen? What would be the damage?
    I've had the truck in 4WD while it was dumping rain and pulled into dry parking deck before. But once I felt how tough it was to turn, I realized and turned it off.
  6. May 11, 2022 at 1:28 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    i need you to get a raise and extra off-time. Id bet your neighbor would partially trade a mitsu pajero body to keep his glass in. I bring a whole 2 dr pajero for your shop buddies, and a body only to pad the utility bed trailer purchase.
  7. May 11, 2022 at 1:33 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    leaving jambo i was in 4 hi and felt a drag when turning on to the highway. Clicked to rwd under 40mph and carried on for 560 miles.
    i made an asphalt slow tight corner and felt resistance toward foward that alerted me something was wrong.
  8. May 11, 2022 at 1:34 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Sorry, I just couldn't resist :)
    Engaging 4wd on pavement???? | Toyota Tundra Forum (tundras.com)
    bmf4069 and shifty`[QUOTED] like this.
  9. May 11, 2022 at 2:12 PM
    Right, right, I did see that one, but it's pretty scant. I'm curious what would happen if you continued? Like ... What would fail first?
    For example, could the force of the tire with all that weight pushing it downward into dry asphalt causing the not wanting to move (but needing to) exceed the force splines would take, causing something to grenade? Or would something else twist/shear/snap first?
    BubbaW[QUOTED] likes this.
  10. May 11, 2022 at 2:18 PM
    I should add to this, maybe.
    I mentioned to him this occurrence, after he asked about my truck, and that's what started the 4WD on pavement conversation: https://www.tundras.com/threads/wha...-gen-tundra-today.2558/page-1346#post-2757242
    The post I just linked has nothing to do with me asking the question above today. But based on a thread found using search on the TS forum, it sounds like my 'thud' situation is something other 1GT owners found. Still, curious what would snap/give 1st if I, say, decided to circle a street light pole on the blacktop of a Wallyworld parking lot .
  11. May 11, 2022 at 2:34 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    My oval window beats that. First time it moved in 15 years was powered by Toyota.
    Sirfive[QUOTED] likes this.
  12. May 11, 2022 at 5:08 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Here’s todays progress on the un-fuck the rack. Included is a roll on liner on the top. That thing always got beat to shit and the clear coat was finally failing. I’ll dial it in and add the rack tomorrow.
    chrisb, bmf4069, CodyP and 4 others like this.
  13. May 11, 2022 at 5:13 PM
    So is the plan to just lower the tailgate to get thing underneath when it’s loaded on top or is that not possible?
  14. May 11, 2022 at 5:18 PM
    alb1k
    Left Coast
    It's good
    Yeah - that's the tradeoff. I notched the back of the top to allow the tailgate to open, because for strength I bolted into the bed rails. So - that thing's not opening very easily. It's also partially why i got the longer load bars, to widen my footprint. I'll see how much I mind tailgate access only. Time for one of those hook bars for pulling stuff out.
  15. May 11, 2022 at 5:23 PM
    Sunnier
    Sunny
    San Diego, CA
    I missed you telling us what you want to carry on that rack. If that set-up holds that weight, I’m very impressed. It certainly looks good. :thumbsup:
    I recommend a rake.
    @KevinK
  16. May 11, 2022 at 5:24 PM
    It’s too bad you couldn’t combine something like a locking roll-n-lock cover with a rack that extends to the pickup bed sides so it doesn’t interfere with operation of the locking cover.
  17. May 11, 2022 at 5:24 PM
    A cane?
  18. May 11, 2022 at 5:26 PM
    Sunnier
    Sunny
    San Diego, CA
    A rake
    Paging @KevinK the pioneer of this most efficient method
    KevinK and FrenchToasty[QUOTED] like this.
  19. May 11, 2022 at 5:29 PM
    alb1k
    Left Coast
    It's good
    Spare, propane tank, maybe water, etc. Hence the need for more strength than I previously had. And soon here, something like a tire would run into the cab roof and not through the back window in a crash...
    I plan to upgrade some of the hardware once everything is lined up. But it should be quite solid when all is said and done.
  20. May 11, 2022 at 5:30 PM
    alb1k
    Left Coast
    It's good
    Probably this little number.
    bmf4069 and FrenchToasty[QUOTED] like this.
  21. May 11, 2022 at 5:31 PM
    That’s a nice unit
    alb1k[QUOTED] likes this.
  22. May 11, 2022 at 5:35 PM
    alb1k
    Left Coast
    It's good
    it's 40% off and free shipping from real truck. 19 bucks...
  23. May 11, 2022 at 5:37 PM
    Sunnier
    Sunny
    San Diego, CA
    Not bad…
    … but what else can you do with it?!
    With this, you can clear a campsite, kill a fire, ready hot coals to cook dinner….
    Darkness, chrisb, bmf4069 and 3 others like this.
  24. May 11, 2022 at 5:41 PM
    See I totally bring a rake while camping as well, and have heard so many times, I’ve never thought to bring a rake.
    But……. I bring a leaf rake, if you need a rock rake, your in the wrong area. As far as coals and fire, I have a little 2 foot Stanley shovel that is perfect.
    I did take a rock rake to the river, because I knew no leaves would be present4F0B7358-01CA-4C3A-A6F0-AD4F1724C6F5.jpg
    NUDRAT[OP], bmf4069, 5N0W808 and 2 others like this.
  25. May 11, 2022 at 5:44 PM
    Sunnier
    Sunny
    San Diego, CA
    I got you— but a rock rake does what yours does, and can pull heavy gear out from the cab end of a covered truck bed, so….
  26. May 11, 2022 at 5:45 PM
    NUDRAT
    NUDRAT [OP] 6 lug life
    SW CT
    Between 'Ridgelines'
    Nobody ever had too much brakes.
  27. May 11, 2022 at 5:45 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I use my full sized shovel or a ratcheting bed bar to get stuff from the front of my bed.
    NUDRAT[OP] and FrenchToasty like this.
  28. May 11, 2022 at 5:47 PM
    NUDRAT
    SW CT
    application used in Japan on something else? Get them shipped from some abroad place? ebay. dk, uk, etc?
    I used to get unobtaniums from Sweden & UK.
    Jack McCarthy likes this.
  29. May 11, 2022 at 5:49 PM
    NUDRAT
    SW CT
  30. May 11, 2022 at 5:50 PM
    alb1k
    Left Coast
    It's good
    Don't forget the broom. A tent must.
    txagg, daveeasa and FrenchToasty like this.
