Binding sway bar links?
Discussion in '2.5 Gen Tundras (2014-2021)' started by COTundra23, May 11, 2022.
  1. May 11, 2022 at 8:30 AM
    COTundra23
    COTundra23 [OP] New Member
    I am currently running fox coilovers with approximately 2.5-3” lift up front.
    On the even slightest bumps or bumpy roads, I am feeling a rattle down near my front axles. Cv axle angles look find and everything feels nice and tight.
    after lifting the truck up and doing a visual inspection, the only thing I can think of is the sway bar end links. The angles are that aggressive but I could imagine some binding occurring and causing this popping, loose feeling.
    any ideas?
  2. May 11, 2022 at 8:56 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Try driving without the sway bars to see if your theory is correct.
    DeesCrewMax likes this.
  3. May 11, 2022 at 9:00 AM
    COTundra23
    Lol that was my initial thought right after posting.
    Curious to see if anyone else has experienced similar issue
  4. May 11, 2022 at 9:07 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Who did the install? Were the fasteners, LCA and other bolts torqued with truck in the air or on the ground?
  5. May 11, 2022 at 9:10 AM
    COTundra23
    The coil install? I did.
    And to be honest, I can’t recall
  6. May 11, 2022 at 9:16 AM
    frichco228
    Frank
    Virginia
    If done in air, that may be a contributor. How many miles on the coilovers? Depending on use, they may need to be rebuilt, generally around 50k miles, less with heavy off road use. Google search fox coilover noise.....lots of posts out there on many Suv and truck forums about noise, rattle, clunks with the Fox so check some out and it may help you diagnose.
    Lastly, approaching 3 inch lift, adjustable UCA is often needed. And no idea on the miles and year of your truck, but could be UCA, ball joints worn. My first step would be checking torque, truck on ground, for everything in front suspension.
  7. May 11, 2022 at 9:39 AM
    COTundra23
    less than 10k on the coils. No leaking or any sign of rebuild necessary at this point.
    2019 with 48k miles. SPC UCAs as well.
    I’ll go back through and re torque and see if that helps!
  8. May 11, 2022 at 10:05 AM
    frichco228
    Frank
    Virginia
    COTundra23[OP] likes this.
