Coilovers hitting
Discussion in 'Suspension' started by BrownieT, Jun 11, 2019.
  1. Jun 11, 2019 at 1:16 PM
    BrownieT
    BrownieT [OP] New Member
    2018 Tundra TRD 4x4
    Noticed how close and that there has been obvious contact. Is this normal? Bump stops prevent this from happening ?
  2. Jun 11, 2019 at 1:21 PM
    TheBeast The Beach
    did you get an alignment already ? mine were close too but alignment gave me a bit more space. not much but just enough not to hit. I also grinded the sway bar ears because they were hitting as well.
    I usually see this issue with KING coilovers (which I have as well)
    Tundyfundy likes this.
  3. Jun 11, 2019 at 1:21 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Did you install a sway bar spacer? If so that may be the cause. I saw another member that had this problem. Also you need to get it aligned. Did you
    monaco730 and 15whtrd like this.
  4. Jun 11, 2019 at 2:20 PM
    BrownieT
    2018 Tundra TRD 4x4
    Ya got alignment when I put them in. No sway bar installed, all stock. Would uppers give more clearance ?
  5. Jun 11, 2019 at 2:24 PM
    Tundyfundy
    Bay Area, CA
    What you are seeing is the coilovers hitting the sway bar end links that attach your front sway bar. You can pull it off, which a lot of guys do. Especially if you're off-roading as it limits articulation.
    upper control arms will help create more space but not garuanteed to not hit. Can you post more pictures of the surrounding components? what size lift?
    T-Rex266 likes this.
  6. Jun 11, 2019 at 2:40 PM
    BrownieT
    2018 Tundra TRD 4x4
    I only installed the king 2.5 oem replacement, front and back. Factory uppers.
  7. Jun 11, 2019 at 2:46 PM
    Tundyfundy
    Bay Area, CA
    Ps bump stops have nothing to do with this.
    15whtrd likes this.
  8. Jun 11, 2019 at 2:47 PM
    TheBeast The Beach
    who did your alignment ? 4x4 shop or joe schmoes specialized in camrys and civics ?
    15Yota and Tundyfundy like this.
  9. Jun 11, 2019 at 2:48 PM
    15whtrd
    15whtrd Mr. Blonde
    There was a thread just like this recently. The kit came with sway bar spacers. If those are in, remove them.
  10. Jun 11, 2019 at 3:11 PM
    TXTundra2722
    2015 Black Tundra
    True, someone just posted this same thing a week or two ago
    Tundyfundy and 15whtrd like this.
  11. Jun 11, 2019 at 3:16 PM
    Tundyfundy
    Bay Area, CA
    monaco730 likes this.
  12. Jun 11, 2019 at 3:21 PM
    Tundyfundy
    Bay Area, CA
    The problem another guy had was caused by the spacer that I circled in the above pics. They came with his kit and his installer put them on and his coilovers hit his sway bar. removing the spacers it solved the problem. Check and see if some came with yours. My second guess is alignment was botched.
  13. Jun 11, 2019 at 3:27 PM
    BrownieT
    2018 Tundra TRD 4x4
    Ok thanks. No spacers in lift alignment numbers are as follows
    mtndds98 likes this.
  14. Jun 12, 2019 at 8:34 PM
    zackbremer
    zackbremer New Member
    Da Z
    remove ur sway bar and leave it off thank me later
    831Tun and 15Yota like this.
  15. Jun 12, 2019 at 9:35 PM
    monaco730
    monaco730 New Member
    16 Inferno Tundra
    Fox shocks, TRD Exhaust, TRD grill, TRD shift knob, weathertech floor/bed liners, ARE topper, FrontRunnerOutfitters cargo rack, Relentless cargo bars, color matched front bumper/side mirrors, fuel wheels, nitto RGs, K&N intake
    Yep that was me with this same issue. When i had my readylift kit installed, it came with front sway bar spacers. These were causing my fox coilovers to rub the sway bar end links just like yours. You say you dont have these spacers so i think i would just remove the front sway bar if i were you.
  16. Jun 24, 2019 at 6:03 PM
    Raider0311
    Raider0311 New Member
    Jeff
    Oklahoma City, OK
    2014 Tundra 1794
    Roll n Lock bed cover, Icon Stage 8, RXT leaf pk, 18" XD Bully's, Nitto 35's, Billet UCA's
    Ouch! Glad you posted this. Getting my truck done next week and now know what to look for. Good luck buddy, hope you get it worked out!
  17. Jul 12, 2021 at 1:27 PM
    kahoa2121
    kahoa2121 New Member
    What was your final solution to this?
