Pickup bed lean…bad leaf bushing, shock?
Discussion in '1st Gen Tundras (2000-2006)' started by Jack McCarthy, May 8, 2022.
  1. May 8, 2022 at 1:17 PM
    Jack McCarthy [OP] Working remotely from the local pub
    Okay, I originally thought the leaf bushing was bad since I can feel/hear metal hitting metal on small potholes and the rubber of the bushing looks like it partially gone from peeping out.
    Considering the bed is sitting up higher on the left by an inch or so, is it really that or just the bad shock I need to replace or both?
    BTW, the shock tower is still there and it’s not like the shock isn’t attached.
  2. May 8, 2022 at 2:59 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Gas charged shocks add a touch of lift, like your palm pushing up a bit. That looks like more than shocks. I'm thinking both shocks and bushings.
  3. May 8, 2022 at 3:01 PM
    alb1k
    Left Coast
    It's good
    BTW, that doesn't look like a bad parking spot, but I can add an inch to the uphill side based on the slope of the ground.
  4. May 8, 2022 at 3:52 PM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    Dads ranger had a crooked bed, so after pulling the bed to change the fuel pump, i stacked some washers underneath to level it.
    check your suspension first, the ranger had been in a collision at some point.
    Jack McCarthy[OP] likes this.
  5. May 8, 2022 at 3:53 PM
    Another member here mentioned isolaters. I’m guessing I need those. Here’s some pics.
  6. May 8, 2022 at 4:02 PM
    alb1k
    Left Coast
    It's good
    I've been hanging on to my stock DC shackles in the event I want the added height back as opposed to my TC drop shackles. I don't know if they are the same as n your AC, nor your timeframe. But they will be available for free in about a month if they help you.
    gosolo likes this.
  7. May 8, 2022 at 4:04 PM
    You think my shackles are bad? I see the surface rust which I can clean up with a wire wheel. Is there a bushing to replace in those as well?
  8. May 8, 2022 at 4:05 PM
    alb1k
    Left Coast
    It's good
    I don't know. But the frame side has bushings in them. Just a thought.
  9. May 8, 2022 at 4:07 PM
    alb1k
    Left Coast
    It's good
    Now you have me thinking, maybe frame side doesn't have a bushing. I'm going to look at them
  10. May 8, 2022 at 4:07 PM
    Thanks. I’ll take a closer look once I’m able to replace the shocks.
  11. May 8, 2022 at 4:09 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    I found leaf bushings, but RA doesnt sell just the shackle bushings.
  12. May 8, 2022 at 4:11 PM
    alb1k
    Left Coast
    It's good
    I’m not crazy yet.
  13. May 8, 2022 at 4:13 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    I wonder if the leaf bushings will fit in the shackle.
  14. May 8, 2022 at 4:17 PM
    alb1k
    Left Coast
    It's good
    I do not know. My guess is they are the same, but It's only a guess.
  15. May 8, 2022 at 4:21 PM
    Shouldn’t this look symmetrical on both sides?
  16. May 8, 2022 at 4:26 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Left bushing has seen better times and right not far behind !
    Jack McCarthy[OP] and Sirfive like this.
  17. May 8, 2022 at 4:30 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    each leafspring needs 4. 2 for the front, and 2 for the back.
  18. May 8, 2022 at 4:41 PM
    I thought it was one big piece. One for the front of the leaf and one for the back. That’s interesting.
    Looks like a bigger issue trying to get the outer housing of the old one out. That’s going to be quite a bit of chisel work.
    Sirfive[QUOTED] likes this.
  19. May 8, 2022 at 5:12 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Bushings...2 Fnt Leaf, 4 Rear....2 for Leaf/2 for shackle
    KK6PD, gosolo, Sirfive and 1 other person like this.
  20. May 8, 2022 at 5:26 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    While mine are not too bad of shape, I have to consider many of our parts such as this will reach NLA sooner rather than later. Some of our rigs are in or approaching the 20 yr Antique age :facepalm:
  21. May 8, 2022 at 6:21 PM
    I think we’ll be okay on aftermarket suspension parts that are as good or better. If you have to buy a wiring harness though you might be screwed unless you can get a used one. Same with the electronics.
  22. May 8, 2022 at 7:47 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    It’s probably in the front not the rear.
    Normally the lean to the left “Tacoma Lean” as the gas tank is on that side.
  23. May 9, 2022 at 12:07 PM
    Question: Have you measured the wheel gap around all 4 wheels? Just curious if the passenger front gap is about 1-2" lower than the driver front, and the driver rear is about 1-2" higher than the passenger rear.
  24. May 9, 2022 at 12:22 PM
    No it’s definitely the same in the front. I went out to check again and it appears the back of the left side of the cab is sagging a bit. Huh.
  25. May 9, 2022 at 12:28 PM
    I guess next thing I'd do is measure the shock itself to see if one is extended more than the other.
    If they've got more than 40-50k miles on them and/or you drive in wicked salt and crazy ass washboard roads, I'm guessing one is shot. Catastrophic shock failure will produce lean like that and isn't always externally visible.
  26. May 9, 2022 at 12:30 PM
    Take that number and multiply by five.
    AresEsMaLo likes this.
  27. May 9, 2022 at 12:30 PM
    Oh - one more question. How does the truck respond if you stand up and bounce on the passenger edge of the bumper, vs. the driver edge of the bumper?
  28. May 9, 2022 at 12:32 PM
    It good in the front with the new Bilstein 4600s. I have them for the back but i need to finagle getting in there with a sawzall.
  29. May 9, 2022 at 12:40 PM
    Because of the rust? Why not just use a decent nut splitter, split the nut, and spin it off? Project Farm covered some splitters out there. Personally, I have a decent one, but usually just take a dremel with 1" cutoff swheel, score the nut, and if it won't free up with a chisel, I'll hit the other side. Get new grade 8 poly-lock hardware if yours didn't come with it. (Start vid at 3m14s if it doesn't automatically)
    https://www.youtube.com/watch?v=EWLxzuDMuhk#t=3m14s
  30. May 9, 2022 at 12:44 PM
    The nut is still in good shape but very little space to try and break it free. It’s definitely rusted on there.
    Haven’t thought about a dremel. Plan was to move the trailer cable harness so I can get in there with a 12” sawzall blade.
