  1. May 6, 2022 at 10:51 AM
    A couple more data points.
    If you have the amp, here's the amp wiring layout when I compared Yeti's to the EWD, suggesting the rear speakers are on the left-hand connector, and may have their own amp channel:
    If you don't have the amp, I think this EWD seems to show the non-amplified trucks had a head unit with two connectors, S6 and S7, where S6 connector was dedicated to the rear speakers: https://tnstatic.net/attachments/upload_2021-11-6_13-33-55-jpg.658473/
    And here's a pic of the overall diagram of a non-amplified system showing that dual-harness setup from Yeti's thread: https://tnstatic.net/attachments/upload_2021-11-6_13-27-37-jpg.658468/
    Bottom line: If you confirm you have the amp, one of two things is probably your problem.
    A) That left hand connector is damaged or unplugged.
    B) The channel powering that left hand connector is fried.
    There's always a possibility that (C) the head unit fader/balance is shorted, or rear channel is fried, but I'm skeptical.
  2. May 6, 2022 at 10:55 AM
    Sirfive
    Sirfive Master Procrastinator
    ‘02 Limited AC TRD
    Bassani cat-back
    Ive been sitting on these p1694’s for a few years, might be time to bite the bullet and install em in something.
    txagg, daveeasa and chrisb like this.
  3. May 6, 2022 at 10:58 AM
    daveeasa
    I’d have sent you my alpine double din, it was plug and play, even had Bluetooth module but it actually sold on the action site and the buyer immediately disputed. So oh well. Lesson learned, keep stuff for friends.
    Sirfive likes this.
  4. May 6, 2022 at 11:07 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    I have a pioneer deh-x6600bt, i can use if need be. Or pull the premier hu out of the blazer.
    Might have to get snowbob or mr.bridgebuilder to help with an install.
    i do know i dont want a screen, and would prefer something with a blackout button that will turn all the lights off, but keep playing.
    chrisb likes this.
  5. May 6, 2022 at 11:31 AM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    On V3 of my homebrew seat risers. V2 was a complete no go. Still a touch tall, but nothing I can do about it for now. Not unless I want to have custom fasteners done.
    Thats a feature the OEM Toyota 86 radio has, it's nice. Just keeps the 4 buttons and volume knob backlit.
    chrisb and Sirfive[QUOTED] like this.
  6. May 6, 2022 at 11:34 AM
    Someone needs to clean the hair off the amp and the grease laden finger residue on the radio. o_O
    RUSTYNUTS and Darkness like this.
  7. May 6, 2022 at 11:36 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    i raised the passenger seat in grandpas tacoma 1.25” in the front and 1.5” in the back for grandma to see over the hood. Sitting in it raised like that, its comfortable on the legs, but i wouldnt be able to see traffic lights. My eyes are level with the top of the windshield.
    thats cool to know about the 86 radio. I wonder if it has other features i could use like empty_lord was talking about.
  8. May 6, 2022 at 11:39 AM
    If you were closer, I'd knock it out for you, if you had the HU.
    RE: 6x9 Fosgates. The rear AC doors have a baffle holding the rear speaker into the door, it looks like this. Once that's removed, apparently as evidenced by @REESE77 's AC truck here, a 6x9 fits in the opening. I wish Metra made a damn baffle bracket to properly secure a 6x9 in w/o drilling, 6x9s put out a hell of a lot more bass than a 6"-6.5" in my experience. Note the white plastic bits where the factory baffle I linked screw in, and the footprint on his door where that baffle used to be.
    Sirfive[QUOTED] and chrisb like this.
  9. May 6, 2022 at 11:44 AM
    Something like this, off another Tundras.com member's 2014 Tundra:
  10. May 6, 2022 at 11:45 AM
    Damn now you mention it, I need to eat some lunch!
    KK6PD and Jack McCarthy[QUOTED] like this.
  11. May 6, 2022 at 11:51 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    good to know. Would it be beneficial to build a properly sized box in the door, or fit one of those foam ?baffle? Basket things?
    I dont crank music, so stock has always been fine, but if i have BT (in the HU) i should be able to run my 25w soundbar. (Plan to have an inverter, and maybe a 2nd battery and isolator)
  12. May 6, 2022 at 12:01 PM
    In my (dated) professional experience, these foam baffles are gimmicky bullshit that only serve to dampen sound, and protect your speakers from the elements. But trying to design a proper tuned enclosure that would fit in the door cleanly is also bullshit. Your door is a natural enclosure, though the airspace inside is more akin to what a speaker would have on a baffleboard in a free-air config than anything. But door speakers are designed to operate in tht kind of environment. You can read the airspace specs on most quality drivers. YMMV.
    KK6PD and Sirfive[QUOTED] like this.
  13. May 6, 2022 at 12:47 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    I did that on my old T100 and it sounded so much better.
  14. May 6, 2022 at 1:37 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    On another side note, the rocks and ripples seem to have given me a bit of extra camber. Its bushings and balljoint time. As much for piece of mind, as a general concern.
    Anyone got any 100k mile rockauto part reviews that will confirm my bias? Or should my dog and i live on ramen and natty light for the rest of the year and get the good stuff like solo and camberg and kings?
    i also didnt oil my air filter when i did the fluids and filters when i got the truck…probably closer to a 4.8 thanks to panhandle and jamboree dust.
  15. May 6, 2022 at 1:43 PM
    805Tundra
    805Tundra New Member
    Ben
    Central Coast
    2004 White 4x4 Double Cab
    Want to thank @Festerw and @bmf4069 for pointing me in the right direction. They had pointed out that a wheel bearing may be my issue with what I thought could be the tires. I started paying closer attention to the noise and was noticing a patterned humming noise in the cab, louder and most noticible around 30-40 mph. This sound continues in neutral at that speed and I can not replicate it at the same rpms standing still. On top of that the noise gets quieter on slight right hand curves, which was my original post was about. This is sounding more and more like a bad wheel bearing the more i research. Going to get an alignment as well as get the tires balanced and rotated just to make sure and rule out a tire issue.
    If it is a bad wheel bearing is it better to get the whole hub assembly or buy the bearings and just have a shop press the old ones out and new ones in? Appreciate the help!
    Darkness, bmf4069, chrisb and 3 others like this.
  16. May 6, 2022 at 1:45 PM
    805Tundra
    Ben
    Central Coast
    Ramen and natty for sure
    oscardog86 and Sirfive[QUOTED] like this.
  17. May 6, 2022 at 1:46 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Jack it up, and give it a wiggle.
    tacoguybill, chrisb, NUDRAT and 2 others like this.
  18. May 6, 2022 at 1:51 PM
    805Tundra
    Ben
    Central Coast
    Also was going to try this as well, thanks!
  19. May 6, 2022 at 1:55 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Oh, put your back into the balljoint test. Helps if only 1 side is jacked and you can throw 100 lbs into it. Some people use a prybar against the UCA and tire while feeling for 1/8” of movement.
  20. May 6, 2022 at 3:31 PM
    Cummins3500
    Logan
    Since we’re doin fab work, let me run something by y’all. I need a way to mount my spare in the bed. Due to the exhaust setup, and eventually adding hammer hangers w/ cross bar my spare 285 won’t fit back under the truck. Plus this would let me put the camper top off and on as needed.
    you think I could mount this to the bed up against the cab? Or should I keep looking. It’ll at least stand the tire up and get me most of my bed space
    https://www.victory4x4.com/product/UNI-TM.html
  21. May 6, 2022 at 3:43 PM
    Victory is cool and all, but you could buy a lot of these for that much monies
    https://www.4xinnovations.com/Tire-Carrier-Wheel-Mount-Plate-and-Support-Gusset_p_163.html
  22. May 6, 2022 at 3:45 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Tie it to the front bedhook bracket and see how you feel. When i was young and dumb, i left the spare strapped to the front bedside of the f100, out in the elements. The jeep xj and s10 blazer both mount to the side, standing behind the wheel well, and ive put covers over both.
    but for prosperity, real badasses keep 2 spares bolted to the passenger side, because its harder to be heroic with a passenger, and if your passenger outweighs you, put them in the driver seat.
    bmf4069 likes this.
  23. May 6, 2022 at 4:07 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    If the bearing is just starting to go it may be noisy but won't have any play/physical movement.
    You can try spinning the hub (may require cv removal if 4wd) and listening to see if it sounds gritty inside.
  24. May 6, 2022 at 4:10 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    When its time to worry about it, you can feel the movement. About 1/8” in any direction. So 1/16” to either side of center.
    oscardog86 and 805Tundra like this.
  25. May 6, 2022 at 4:49 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I'd probably just do the bearings and replace them with Koyo/SKF/Timken.
    bmf4069, chrisb, NUDRAT and 1 other person like this.
  26. May 6, 2022 at 5:46 PM
    Cummins3500
    Logan
  27. May 6, 2022 at 5:52 PM
    You could probably get a piece of plate or something to sandwich the bed with(I was thinking at the front of the bed near the cab)
    NUDRAT and Cummins3500[QUOTED] like this.
  28. May 6, 2022 at 8:12 PM
    Cummins3500
    Logan
    that’s what I’m picturing, appreciate the link and brainstorming :thumbsup:
  29. May 8, 2022 at 1:12 PM
    Solid Snake
    Solid Snake The Anciet of Mu Mu
    West TN
    2006 AC 4x4 V8
    Just finished hand washing my truck. West Tennessee pollen is a bitch this time of year.
    tacoguybill, bmf4069 and YardBird like this.
  30. May 8, 2022 at 3:51 PM
    snoope
    snoope The Old Man
    Hurry up and wait.... dealership will be delivering it too me at the end of the week....:D
    They are completing the 100k service; timing belt,tensioner and water pump and then send it too me :thumbsup:
    Pix to come But NICE to be back in a Toyota truck again :yes:
    KNABORES, shifty`, oscardog86 and 3 others like this.
