Fuel recomendations
Discussion in 'Performance and Tuning' started by MoToad, Mar 29, 2022.
  1. Mar 29, 2022 at 1:02 PM
    MoToad
    MoToad [OP] New Member
    Toad
    BC Kanuckistan
    2009 Tundra DLX
    My new (to me) 09 Tundra RCSB came with advice on continuing running mid grade or premium fuel. With the latest fuel price numbers thru the roof I am considering going to low test. Not a flex fuel model here, just the standard one. Also not towing at this time. Will go with mid if that comes to be. So, anyone run regular and any noticeable problems?
  2. Mar 29, 2022 at 1:09 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    I’ve only ran 87 octane since I got mine new. I know of some other would run 89/91 due to some engine issues.
    NueveTundra and Metro14536 like this.
  3. Mar 29, 2022 at 1:46 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    87 is fine, is what the truck was designed to run
  4. Apr 2, 2022 at 5:52 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I don't see any reason not to run 87 octane.
    WILLINH and NueveTundra like this.
  5. Apr 2, 2022 at 5:59 AM
    Silver17
    Northeast
    2017 TRD 4x4 Harrop SC
    Were you told to not to run 87 because it is tuned for a higher octane? That’s the only good reason not to.
    2mchfun and NueveTundra like this.
  6. Apr 2, 2022 at 6:11 AM
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    Regular is fine assuming it’s stock. Nice to buy used from somebody who thought that highly of it though!
    ETA Turned on Engine Masters this morning and they’re dyno testing 87 91 and 110. Conclusion was unless you’re detonating 87 like with boost there’s no benefit to higher octane. No surprise
    Black Wolf and NueveTundra like this.
  7. Apr 2, 2022 at 6:16 AM
    tundratoofun
    tundratoofun Yall better rednekonize
    Glendale
    Beast
    87 in everything unless it makes BIG POWER.
  8. Apr 2, 2022 at 7:42 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Exterior: Toytec ultimate 3" lift level, Total Chaos Uniball UCA's, Total Chaos Cam Tab Gusset kit, AcanII smoked headlights, AcanII smoke Tail lights (2.5 gen style), DV8 front winch bumper , Badlands 12k winch with Apex Synthetic, White AUTMATCH Shackles 3/4" D Ring Shackle, Apex Winch shackle, Trail Ridge mirrors ,Icon Rebound Pro 17"x8.5" +25, Cooper Discovery STT Pro 285/70R17, PowerStop drilled n slotted rotors W/Carbon pads, Rigid flood flush mounts rear bumper , WeatherTec rain guards , OEM black side badges , Rigid Amber Radiance Pods. Energy Suspension Red Rack and Pinion Bushings, EAG front mesh Grille, RCI HighLift bed mounts. Rough Country DS2 Steps, A.R.E OverLand Canopy with Ascend basket, Stickers: ToyTec lifts windshield banner, Red Strange Music window sticker(back cab), White Strange Music sticker(back canopy), White Rigid sticker x2 (canopy sides), white Official BigFoot Research Team (Back Canopy) Interior: Alpine double din touch iLX-650 , JL C5-653's (front) JL C1-650x (rear) , JL JX400 4 channel amp , JL JX500 mono amp , 2 JL 12" subs , WeatherTec floor mats, Kenwood F/R Dash Cams, Black steering wheel emblem overlay, Tekonsha P3 Brake controller, ToyTec "Fresh" Scent coilover air freshener, Under the Hood: Koyo all aluminum radiator, Mishimoto red silicon hoses , XS Power 3000 amp battery , LAlectric 300 amp Alternator , K&N replacement filter. Online LED store accessories Fuse/relay box. (Identified) Dirty Deeds 8" Cat back exhaust with DD resonator delete/axel over converted into dump. Coming soon:
    Like every one's stated above 87 is what the truck is built for (unless its a highly modified motor or has a super charger)
  9. Apr 2, 2022 at 7:51 PM
    This^^^^ Stick with mid grade.
  10. Apr 2, 2022 at 7:51 PM
    Cock-A-Doddle-Do
    Cock-A-Doddle-Do New Member
    Brett
    Cypress, Texas
    2021 TRD Off Road CM -Super White
    ^^THIS^^....Next question?
    WILLINH likes this.
  11. Apr 27, 2022 at 7:05 AM
    dkahs05
    dkahs05 New Member
    2020 Tundra TRD PRO
