Be VERY CAREFUL if you are buying a Tundra for towing
Discussion in '3rd Gen Tundras (2022+)' started by Jnevans, Apr 21, 2022.
  1. Apr 24, 2022 at 6:52 PM
    #91
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    whats funny is we have been wondering for years what the weak point is which determines the gvwr. Ie is it axles, suspension, frame ext. ironic that suspension alone allowed them to raise rating
    Acedude and rruff like this.
  2. Apr 24, 2022 at 7:00 PM
    #92
    mass-hole
    mass-hole New Member
    And no generator like the Powerboost. Its kinda dumb and it irritates me that the Sequoia is hybrid only
    Acedude likes this.
  3. Apr 24, 2022 at 7:02 PM
    #93
    mass-hole
    Its possible it has an uprated axle. I believe the Powerboost has a stronger axle than the standard Ecoboost due to the extra low end torque.
    But ford also only increases the GVWR of the PB by only 200 lbs I believe. The standard F150 is 7150 lbs and the PB is 7350
    Hbjeff[QUOTED] likes this.
  4. Apr 24, 2022 at 7:09 PM
    #94
    Joe T
    Joe T New Member
    The powerboost would come with the 9.75 vs the 8.8 rear axle. I think all 3.5 ecoboost motors come with the 9.75 and that is the petro motor that comes in that package. Its 3800 gawr and in some configurations it goes up to 4800 I believe, but in the heavy payload package with 3.73s. So the powerboost is probably the standard 9.75.
  5. Apr 24, 2022 at 8:51 PM
    #95
    xc_tc
    xc_tc New Member
    F150 Powerboost is 1.5 kWh. Prius Prime battery is 8.8 kWh, the old plugin was 4.4 kWh. The nickel metal hydride is a bit heavier but it’s much cheaper than a lithium battery.
    Sirfive[QUOTED] likes this.
  6. Apr 24, 2022 at 8:55 PM
    #96
    Sirfive
    Sirfive Master Procrastinator
    ‘02 Limited AC TRD
    Bassani cat-back
    I’m sure they’ll pass the discount.
  7. Apr 25, 2022 at 6:54 AM
    #97
    newdles
    newdles New Member
    brandon
    Red 2022 tundra
    Ok, I’m officially done worried about what the tundra can tow.
  8. Apr 25, 2022 at 8:22 AM
    #98
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    You should weigh it...
    ttps://www.tundras.com/threads/payload-stickers.99329/page-16#post-2737474
    "I have some encouraging information to share with everyone. I had picked out a 2022 SR5 crewmax, 4wd. The door sticker, like others here said 1395lb payload. Our local dealership is fantastic. They did a ton of searching, talking with toyota, etc. So we decided that when the truck came in we would take it to the scale down the road. They had the 33 gallon tank full for me. We weighed the truck, with no one in it. The GVWR listed on the door is 7210. The truck curb weight was 5560 lb. Do the math, you get a payload of 1650lb! I'm thinking that the payload listed on the door is considering a passenger weight(s) of 250lb. That's just a guess. I'm happy that the truck met our requirements (we will use it to tow a travel trailer). Proud new Tundra owners!"
  9. Apr 25, 2022 at 8:24 AM
    #99
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    5N0W808[QUOTED] likes this.
  10. Apr 25, 2022 at 12:21 PM
    #100
    montyz81
    montyz81 New Member
    It would be nice if Toyota, or every manufacturer, would have an automatic calculator that tells you what your capacities are as you add option packages.
  11. Apr 25, 2022 at 12:34 PM
    #101
    r1-superstar
    DB
    UTAH
    You should build an app for that. Add on aftermarket stuff and cargo. :thumbsup: You would be rich.
    Cpl_Punishment and Mattedfred like this.
  12. Apr 25, 2022 at 1:26 PM
    #102
    Archive
    Archive New Member Vendor
    Eric
    '22 Tundra CM 6.5' TRDOR
    Archive Garage Suspension
    Dfrink, rruff, Terndrerrr and 3 others like this.
  13. Apr 25, 2022 at 2:27 PM
    #103
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Lol. Scales on the steps. I’d bet wives would get a kick out of that.
  14. Apr 26, 2022 at 7:14 AM
    #104
    Sparky916
    Sparky916 New Member
    Blake
    22 Lunar Rock Limited TRD OF
    Just pulled my 34' TT 8k-9k loaded on a 4hr trip each way and the truck did great. Only complaint I really have is that I couldn't get the BSM to detect the trailer. Tried auto setting for length and inputting the length of the trailer and neither one sensed cars on the side of the trailer for me.
    dekeman, =JSG=, Hbjeff and 6 others like this.
  15. Apr 26, 2022 at 7:38 AM
    #105
    Coasty
    Coasty New Member
    Pat
    Oregon
    2022 SRS Crew Max 6.5 4x4
    Impressive, you have that setup leveled out nicely, I assume with a WD hitch? What kind of mileage did you see?
  16. Apr 26, 2022 at 7:48 AM
    #106
    Sparky916
    Blake
    Thanks, yeah I have a WDH with 2 sway control kits. I still had about 1.5" sag in the rear fully loaded, but going to try and fine tune the WDH and see if I can get rid of that on my next trip. I was averaging around 11MPG with my speed at 55-65MPH. The truck does have the westcott 3/1 collar lift and 35"s. Overall I was really impressed with how it pulled and I had no sway. I've pulled the same TT with my Silverado and my Suburban that has bags and the tundra felt better pulling the TT.
  17. Apr 26, 2022 at 9:28 AM
    #107
    Coasty
    Coasty New Member
    Pat
    Oregon
    Glad to hear that as I've had towing anxiety and our trailer is only 5500 loaded up. I wouldn't have guessed you had it lifted because I would have thought the nose would be higher than its sitting. Have you done any research on airbags for the rear?
  18. Apr 26, 2022 at 9:54 AM
    #108
    Sparky916
    Blake
    I wouldn't worry too much about a 5500lb trailer if it was me. What I've notice a lot online and going down the road is people just don't spend the time to set up their hitch properly or even their trailer brake. I spent quite a bit of time dialing in my WDH to get the trailer sitting level and I'll adjust it again before my next trip to try to get rid of the 1.5" of sag, but IMO that's acceptable sag in my book. A proper setup on a WDH makes the world of difference towing IMO. I'm not going to get bags in the rear because I don't want to limit the suspension for off-road use. Also, I'm eventually going to be upgrading the suspension when lifts become available. If I was pulling daily I'd look into it, but the handful of times I pull a year I don't think its necessary because the truck is more than capable with the proper setup.
    Acedude likes this.
  19. Apr 26, 2022 at 9:59 AM
    #109
    Coasty
    Coasty New Member
    Pat
    Oregon
    I agree with setting up the WD hitch properly, on my Ram 1500 it took me an hour of playing around with it to tune it in and it paid off. I carry dirt bikes in addition to my trailer so I look at payload in the bed as my limiting factor, it'll be interesting to play around with it but I"m glad to read that its' such a capable towing platform even with the 35's on it.
    Sparky916[QUOTED] likes this.
  20. Apr 26, 2022 at 10:17 AM
    #110
    Sparky916
    Blake
    Yeah, haven't pulled the TT with the dirtbike in the back yet, but later in the year I'll be loading my bike in the bed while pulling the TT. If it was me and I had more than 2 bikes back there I'd be looking into some bags. I'd assume any universal coil over bag kit would work? But, haven't looked into it. However, I did have 3 bikes, a small electric quad, my sons power wheel, and 5g gas can in the bed which wasn't really a whole lot of weight. After this last trip we've decided were going to get a class C next year anyways. My kids are finally at the age that I'll need a little trailer to pull 3 small atvs, my wife's atv, and my dirtbike.
  21. Apr 26, 2022 at 10:20 AM
    #111
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I agree with this part.
    Don't agree with this. Whether you like it or not, at some point an engineer (or maybe a few of them) looked at the design of the Tundra and determined that's the max weight it can safely carry, based on a number of factors that you and I can only guess at. The truck MIGHT be capable of carrying more but, if no one at Toyota is willing to sign off on it, I'm not willing to test the limits, especially on public roads with my family in the truck.
    GODZILLA likes this.
  22. Apr 26, 2022 at 10:47 AM
    #112
    Breathing Borla
    Northern Illinois
    Hey toyota, how about a payload package,
    as an option, let us check a box to get the Hybrid GVWR in a non hybrid.
    platinum crewmax 4 x4 payload package
    7660-5620 = 2040 lbs payload
    that would solve the problem for a lot of people and Toyota it would be super easy for toyota to do.
  23. Apr 26, 2022 at 10:54 AM
    #113
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    11mpg towing a travel trailer with 35s is very impressive
    Sparky916 and Malinois38 like this.
  24. Apr 26, 2022 at 11:24 AM
    #114
    Coasty
    Coasty New Member
    Pat
    Oregon
    Ill see how it does with the bikes back there and if I need to look at air bags then I will. It would be nice as Breathing Borla suggested to have a payload package as an option. The motor will pull it but the limiting factor seems to be the payload for a lot of folks. I agree with Hbjeff, 11 is good mpg for the load and 35's but you kept speed down which is why, I drive mine the same way. How did the brake controller work, any issues?
  25. Apr 26, 2022 at 11:39 AM
    #115
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    Do you, like almost every single person I know, test the limits of the speed limit?
    Whether you like it or not, at some point an engineer (or maybe a few of them) looked at various factors of the roadway and its environment (curvature, traffic, entry/exit points, weather) and determined the maximum speed you may safely travel at, based on a number of factors that you and I can only guess at. Your vehicle MIGHT be capable of safely going faster on that road, but if no one in your state (or province?) Dept of Transportation is willing to sign off on it, are you willing to test those limits, especially on public roads with your family in the truck?
    (Not necessarily aiming this only at you; just pointing out the exact same argument applies to speed limits, which many, many people happily admit that they don’t abide by while policing others’ towing habits)
  26. Apr 26, 2022 at 12:02 PM
    #116
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I'm one of the few who actually drives the speed limit, though I am willing to go up to 10 kph (6 mph) over the limit when going downhill (and the same amount under when going uphill) in the name of fuel economy.
    For the record, I'll probably end up adopting your thinking that if I'm over my GVWR but under my GAWRs, I'll probably be ok. I mean, Toyota didn't even balk when the owner of the first million mile Tundra admitted to carrying over a ton in it.
  27. Apr 26, 2022 at 12:12 PM
    #117
    Archive
    Eric
    Bro, don't try to argue the truck is tougher than Toyota says it is. My feeling is that the GVWR is Toyota's max rating for doing all truck things with it, including some offroad stuff.
    Oh you know a guy who hauled way more on the highway babying it? I don't care.
    Tacoma guys have been trying the same thing for years due to dismal payload and they bend and replace literally every single part, and that may not be wailing on it either.
  28. Apr 26, 2022 at 12:12 PM
    #118
    Terndrerrr
    Music City
    6UR-FE
    Yep. Toyota all but boasted about the million mile trucks' ability to be pushed past its stated limits. They did the same thing with a series of Tundra ads they made about the truck they loaned to some ranch to be used however they wanted for 100k miles. The ranch guys said they used it like an HD truck. It pulled loads that were way beyond the door jamb and was just fine. These were ads made by Toyota.
    I noticed in that video, they were careful not to show 12 cattle in the livestock trailer like the ranch hand claimed, and the engineer says something like "while I can't recommend using your truck this way, it is great to see that it had no problems at all for 100k miles of abuse". They come right up to the line of legal liability (in the event someone uses their truck in a similar way and causes an accident) without crossing it.
    Edit: here's the series:
    https://www.youtube.com/watch?v=Q4YFM6UoM9s
  29. Apr 26, 2022 at 12:15 PM
    #119
    scape
    scape New Member
    2017 1794 Tundra...Waiting on a 22 1794
    Then, the lawyers reviewed it...
  30. Apr 26, 2022 at 12:28 PM
    #120
    Terndrerrr
    Music City
    6UR-FE
    I am not making a judgement on whether anyone else should or should not haul at any level above their door jamb.
    What I am saying is, if you ignore the posted speed limit which actually is a legally enforceable standard, then your argument when you police other people's payload habits is invalid.
    Nm6300'asl likes this.
