Choice between the REadyLift plus2, coachbuilder, or Westcott Designs?
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by NLTRDPro, Feb 7, 2020.
  1. Feb 23, 2022 at 3:23 PM
    #91
    SAGE63
    San Diego County
    I believe the '18 pro had the 6112 Bilsteins up front. anyway Jeff had a set of collers and upper spacers that will fit my 6112's and allow me the same lift at a lower circlip setting and replace my CB shims. I am going to keep the cb shims and only use the collars due to the tundra lean... btw 2021 limited trd offroad is what I have with +3 CB shackles. My truck is the one on his website for the Tundra roof rack
    update it was the 15-17 not 18...
    ackthresher likes this.
  2. Feb 28, 2022 at 1:04 PM
    #92
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    Has anyone received there westcott lift that has ordered. I ordered mine Feb 12. Nothing yet.
  3. Mar 2, 2022 at 10:16 AM
    #93
    motoryder
    motoryder New Member
    I'm a little confused now on the Westcott kit. I was under the impression that it was ONLY a preload collar and not an additional "shim". On their website it even states that it will not affect suspension travel. If that's the case, why the need for bumpstop spacers? Wouldn't the need for a bumpstop spacer mean that your up-travel is now limited due to the shock being mounted lower in the perch?
    How is this not a spacer lift?
    xJuice likes this.
  4. Mar 2, 2022 at 2:44 PM
    #94
    RusPro21
    Don
    Pa.
    Finally got tracking on my lift today. I will let someone else explain it Motoryder.
  5. Mar 2, 2022 at 3:02 PM
    #95
    FISHN43
    FISHN43 New Member
    Ohio
    2020 Super White TRD Pro
    I ordered mine on the 10th. Also got tracking info today. Yay!
  6. Mar 2, 2022 at 3:12 PM
    #96
    RusPro21
    Don
    Pa.
    You doing the full kit? Or coachbuilder shackle for the rear?
  7. Mar 2, 2022 at 4:47 PM
    #97
    FISHN43
    FISHN43 New Member
    Ohio
    I ordered just the front lift kit. I already have Coachbuilder +2 shackles installed but I’m going to jump on the group buy and go up to the +3.
    baron likes this.
  8. Mar 2, 2022 at 4:55 PM
    #98
    RusPro21
    Don
    Pa.
    Do you off road or tow? I’m up in the air on the rear yet.
  9. Mar 2, 2022 at 5:13 PM
    #99
    baron
    baron New Member
    Brett
    2021 TRD Pro
    Thanks for this. I had no clue about the GB. I'm going to hop on and order the +3.
    For the group - when is the CB Steering Kit required/recommended?
  10. Mar 2, 2022 at 5:23 PM
    #100
    RusPro21
    Don
    Pa.
    Hey Brett, Over on the GB page it’s explained for the steering kit.
  11. Mar 2, 2022 at 5:27 PM
    #101
    FISHN43
    FISHN43 New Member
    Ohio
    Not much off roading yet but plan on some trips in the future. I do tow an 18’ fishing boat though.
  12. Mar 2, 2022 at 6:26 PM
    #102
    baron
    baron New Member
    Brett
    2021 TRD Pro
    I did see that. I'm familiar with these from performance vehicles I've owned, so I understand what they do functionally. What I'm wondering is if something like a Westcott kit, which is a pretty moderate lift, warrants a steering kit? Are you planning on running one?
  13. Mar 2, 2022 at 6:32 PM
    #103
    RusPro21
    Don
    Pa.
    I’m not going to run the steering kit. I’m leaning on going with the full westcott lift after talking to a few that have the full kit. I don’t tow or off road with my truck. And I don’t see that happening. Worst case down the road if I need I will have the coachbuilder shackles added then. I also received mySCS wheels I will be adding them also.
    baron[QUOTED] likes this.
  14. Apr 6, 2022 at 5:59 PM
    #104
    Ebart
    Ebart New Member
    Ernie
    2021 Toyota Tundra TRD Pro
    I’m starting to get really confused on this westcott lift. I was wanting to put it on my 21 TRD Pro. All the forums I read and the videos I watch say I can clear 35’s on my factory wheel and only have to remove the front splash guard and the mud flap. I messaged westcott and also called them. They are saying for 35’s I’d have to do a fender push in. Anyone that can offer first hand experience would be great. I was thinking about going with the 305’s instead hoping that it would prevent me from removing the mud flap. Black truck want to try and keep down on road grimes
  15. Apr 16, 2022 at 3:11 PM
    #105
    FISHN43
    FISHN43 New Member
    Ohio
    I’m getting ready to install the Westcott front lift. The only thing I’m worried about is seating the new collar. In one of their YouTube videos Westcott places the shock upside down on the collar between the jaws of a large vice. Then they use a hard plastic mallet and strike the bottom of the shock to seat. My vice would be to small for this method.
    Does anyone that installed themselves have any other tips or tricks to seat the preload collar?? TIA
  16. Apr 16, 2022 at 7:25 PM
    #106
    RusPro21
    Don
    Pa.
    I think there is only 2 ways. The one you just mentioned in the video that westcott hammered it on. My installer is going to use the press machine. Westcott has a video showing it being done.
  17. Apr 17, 2022 at 5:07 AM
    #107
    FISHN43
    FISHN43 New Member
    Ohio
    A press would be the best/easiest way but I don’t have one. Just looking for any other methods or tricks/tips that people have used.
  18. Apr 17, 2022 at 5:19 AM
    #108
    TruPatriot
    TruPatriot New Member
    Lee
    Northeast Texas
    2020 TRD Pro MGM Mall Crawler & Trail Riding Queen
    I recommend renting the RIGHT tools needed for the installation. It sure beats a trip to the emergency room and hours of frustration by using the MacGyver method.
  19. Apr 17, 2022 at 7:22 AM
    #109
    FISHN43
    FISHN43 New Member
    Ohio
    I have everything I need except a way to seat the collar- which can be accomplished by applying even pressure either from striking or pressing it. I know plenty of guys have installed themselves. Just seeing if there are any other methods other than the two mentioned above. If none, I’ll find someone with a press or large enough vice.
    TruPatriot likes this.
  20. Apr 23, 2022 at 12:55 PM
    #110
    FISHN43
    FISHN43 New Member
    Ohio
    Installed Westcott front yesterday. I have CB +2 shackles in the rear right now. I have a set of +3 shackles ready to install but I kind of like the look as is. I’ll have to hook my boat up and see what happens….
    S-Q-U-A-T !
  21. Apr 24, 2022 at 9:53 PM
    #111
    Luke_Skywalker
    Luke_Skywalker New Member
    Luke
    2020 Tundra TRD Pro
    Eibach TRD Pro Front Springs, Dirt King UCA's Coachbuilder +3 shackle (poly bushings)/carrier bearing drop, steering upgrade, bumper shims, White Knuckle Sliders, Leitner Designs, Baja Designs, Switch Pro, Victron Solar, BORA 1.25", BFG KO2s, Wheelers Superbumps, VLED interior lights, 12" Sub, Window Tint.
    I would reallllllly love to hear experiences from those folks who have either the CB kit or the Westcott and THEN put a bumper/winch (or both) in their vehicle. This is the singular thing that is keeping me from purchasing one of these. If anyone has any input im sure im not the only guy on here whos pondering this one!
  22. Apr 25, 2022 at 1:28 PM
    #112
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    Can I bother you with checking what's the distance from center of the wheel to the bottom of your wheel well opening in the rear?
  23. May 7, 2022 at 8:45 PM
    #113
    Tundraofnv
    Tundraofnv New Member
    2020 Cement Crew
    Can you run the TRD rear sway bar with the CB +3 shackles?
  24. Jun 7, 2022 at 6:46 AM
    #114
    FISHN43
    FISHN43 New Member
    Ohio
    Any of you guys getting bump steer after the Westcott install? I get it mostly at lower speeds. On bumpy roads I get a lot of feedback through the steering wheel. On smooth roads truck tracks perfectly straight and smooth. I’m confident in my alignment guy but wonder if theres more that can be done to eliminate the bump steer.
  25. Jun 7, 2022 at 12:49 PM
    #115
    TruPatriot
    Lee
    Northeast Texas
    I have no issues at all!
  26. Jun 15, 2022 at 7:29 AM
    #116
    DadduMan
    DadduMan New Member
    2021 Black Tundra TRD Pro
    So I went with the Westcott Fox TRD Pro kit. In the rear I kept my CB +2 shackles and just added the 1” block. No difference in ride quality at all in fact it’s better with the alignment! I also have the rear sway bar and decided to flip the sway bar ubolts 90degrees on the axel to avoid any issues. Also had to do the ABS/BrakeLine relocation kit to avoid tension in the stock ABS and brake lines with added height.
    Before and After.
    CB +2 Shackles, 1inch block and Sway Bar.
    Abs/Brake line extension.
    KatoK, PNWTundra2021 and FISHN43 like this.
  27. Jul 23, 2022 at 7:13 PM
    #117
    Ebart
    Ebart New Member
    Ernie
    I’ve had this kit and not had any time to put it on. The plan is to do it in the morning. After looking through the box I found 4 washers I’m not sure what to do with. Any ideas?
  28. Jul 23, 2022 at 9:10 PM
    #118
    DadduMan
    DadduMan New Member
    This is exactly what came in my kit. Are you saying you have extra washers in there?
  29. Jul 23, 2022 at 9:28 PM
    #119
    Ebart
    Ebart New Member
    Ernie
    93904C92-BD99-4264-90F0-68E955ABDD63.jpg 986DFA8A-A29B-4BD6-A6BE-2C5985D553A0.jpg
    The 4 washers to the left. After some research I’m pretty sure they are bump stop spacers
  30. Jul 23, 2022 at 10:37 PM
    #120
    rag9836
    rag9836 New Member
    Robert
    Riverside, CA
    2021 Tundra TRD Pro Crew Max
    275/70/18 BFGs, TRD Cold Air Intake, BRShine LED light swap, FRAC front camera, ESP Under Seat Storage, Rocky Mounts bike holder, tinted front driver and passenger.
    What’s the power and mpg loss look like when going to 35”’s?
