18in Wheels ???
Discussion in '1st Gen Tundras (2000-2006)' started by Tellicotim, Apr 19, 2022.
  1. Apr 19, 2022 at 11:19 PM
    Tellicotim
    Tellicotim [OP] New Member
    03 Tundra V8. 4×4
    LED , K an N air filter
    Traded for 2022 Tundra wheels today.
    6 lug 18in 265/70R18. I have a Rough country 2in lift. Can I make these work on my 03 tundra, Or should I sell them. Running 2018 4runner 17" wheels now with no problems of rubbing. Thanks Screenshot_20220411-225827_Facebook.jpg
  2. Apr 19, 2022 at 11:21 PM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    Put em on, let us know. Measure the center hub hole and backspacing.
    5N0W808 likes this.
  3. Apr 19, 2022 at 11:34 PM
    Beefnbread
    Beefnbread Electric Soup
    Oregon
    2000 SR5 Tundra 4x4
    265’s should fit no problem with 2 inch lift. Honestly you could even go bigger. My concern is that you might need wheel spacers because those rims do not look deepset. Give her a go
  4. Apr 19, 2022 at 11:37 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Those are 33” tires. Should fit with a 2” lift but wheel spacers may be needed
  5. Apr 19, 2022 at 11:43 PM
    Beefnbread
    Oregon
    2000 SR5 Tundra 4x4
    I’m pretty sure those say 265 on them? Where’d you get that from?
  6. Apr 19, 2022 at 11:45 PM
    empty_lord
    05 rollover special
    265 is the width. 70 is the % of the width for the sidewall.
    a 265/70r18 is roughly a 33” tire (well 32.65”)
    And 10.43” wide
    my trucks on 255/80r17. Which are a hair over 33”
    5N0W808, GODZILLA and KNABORES like this.
  7. Apr 19, 2022 at 11:47 PM
    Beefnbread
    Oregon
    2000 SR5 Tundra 4x4
    You’re right, you’re right my bad
    GODZILLA and empty_lord[QUOTED] like this.
  8. Apr 19, 2022 at 11:48 PM
    empty_lord
    05 rollover special
    We call tires by size in “. With metric widths, % sidewalls and “ wheels…
    tire sizes are a confusing mess lol
  9. Apr 19, 2022 at 11:53 PM
    Tellicotim
    03 Tundra V8. 4×4
    Don't seem to be deepset, should I run 1.5" spacers or maybe 2" spacers ?
  10. Apr 19, 2022 at 11:53 PM
    Beefnbread
    Oregon
    2000 SR5 Tundra 4x4
    Yeah, I was thinking 32. :eek:
    Honestly 33’s are better. so good!
  11. Apr 19, 2022 at 11:54 PM
    empty_lord
    05 rollover special
    I would put one on in the front to see how close it is to the control arm. If that’s fine turn it lock to lock and see how close you are to the frame
    not sure on the backspacing on the new tundras. But if it’s like 2/3rd gen tacos a 1/4” spacer would do
    Darkness likes this.
  12. Apr 19, 2022 at 11:57 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    I still wanna know the hub bore. If the new wheels have a smaller hub bore, are there spacers that can adapt?
    big hub bore:
  13. Apr 19, 2022 at 11:58 PM
    empty_lord
    05 rollover special
    On a quick glance it appears Toyota is still using the same bore. But I’ve yet to measure one
  14. Apr 19, 2022 at 11:59 PM
    empty_lord
    05 rollover special
    Quick google search shows it’s still a 106mm bore.. should fit
  15. Apr 20, 2022 at 12:00 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
  16. Apr 20, 2022 at 12:02 AM
    empty_lord
    05 rollover special
    Well now I’m just confused. No new tundras have been in for service yet so I haven’t been able to check one
  17. Apr 20, 2022 at 12:03 AM
    empty_lord
    05 rollover special
    Hmm found a photo of one. Yea. These are a no go for any Toyota other than the new tundra. A slave can make it fit yea. But you won’t be hub centric anymore
  18. Apr 20, 2022 at 12:07 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Nothing an angle grinder or chrisb’s lathe cant fix.
    des2mtn and shifty` like this.
  19. Apr 20, 2022 at 8:33 PM
    Tellicotim
    03 Tundra V8. 4×4
    If I put 2" Spacers wouldn't that nullify the center bore difference ?
  20. Apr 20, 2022 at 8:41 PM
    empty_lord
    05 rollover special
    yes.
  21. Apr 20, 2022 at 8:41 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    I wouldnt recommend it, but i did find spacers without the hub lip. It also said those wheels are for m14 studs. I dont know if that could cause problems. You’re gonna kinda be on the bleeding edge of this. Would be cool to find spacers with the 106mm on the hub side and the 95 (or whatever it is) on the wheel side.
    5N0W808 likes this.
  22. Apr 20, 2022 at 9:41 PM
    Tellicotim
    03 Tundra V8. 4×4
    Yes noticed the holes in those wheels are a little bigger than my other wheels. Don't think I wanna tackle that , probably just sell them, Tires have a 150 miles on them guy said, look brand new. Bridgestones
  23. Apr 20, 2022 at 9:43 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    If you have them why not try installing them? You'll know in 10 minutes.
    5N0W808 likes this.
  24. Apr 20, 2022 at 9:53 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Yea, mock em up, get a pic, let us see.
