Fox 2.5 install questions/issues
Discussion in 'Suspension' started by 94slowbra, Mar 17, 2022.
  1. Apr 13, 2022 at 9:09 PM
    94slowbra
    94slowbra [OP] New Member
    john
    new orleans
    2016 TRD pro
    Yes, fox calls 80 ft/lbs. Double checked that
    The through bolt is tq'd to 173. Did this today to regrease the bushings.
    Everything else is to spec. Going to run to the alignment shop to have them check everything over
  2. Apr 13, 2022 at 9:24 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    What'd your torque the nut that holds the UCA spindle bolt?
  3. Apr 13, 2022 at 9:33 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I have got away with doing this on a few sets of coilover, but I know it isn't the best method. Compressing the coil prevents the chance of damaging the threads. Some guys get lucky but I've seen stripped coilovers and wouldn't want to have that.
  4. Apr 14, 2022 at 5:25 AM
    94slowbra
    john
    new orleans
    2016 TRD pro
    Dont remember off the top of my head but it was listed in JBAs install instructions, I went with that. If I remember correctly it was lower than the factory bolt. I can double check that today
  5. Apr 14, 2022 at 5:29 AM
    94slowbra
    john
    new orleans
    2016 TRD pro
    I have been using the spring compressor while the coilover is still in the vehicle. Eliminates a few steps. I still can't see how you would be able to adjust them without compressing the spring.
    Hopefully I can get them quiet and I'll be all set
    DeesCrewMax and Darkness[QUOTED] like this.
  6. Apr 14, 2022 at 6:53 AM
    DeesCrewMax
    DeesCrewMax New Member
    Deric
    2018 Cement Crewmax SR5
    Accutuned Fox 2.5 DSC/2.0 rr, SnugTop Rebel, Alpine Amp, OEM LED headlights, LED fogs, Remote Start, RB20 steps, RCI Skids, 10" BA Muffler, 17" Icon Alloy Six Speeds, 15" Tint, Pro-clip mount
    Did you have to unclip / shift / remove anything under the hood to remove that massive uca bolt?
    Coincidentally, I have those same arms waiting to be installed. I could not find the suggested grease locally and ordered it from JBA directly. Almost did the Lucas red n tacky, but directions specifically say not too.
  7. Apr 14, 2022 at 9:15 AM
    94slowbra
    john
    new orleans
    2016 TRD pro
    There are a couple if sift lines that are in the way on the passenger side that you can take out if the clip and move. Drivers side was easy. Nothing had to be removed on either side to get them out. It's tight but it fits.
    Lube them up good. I had to go back and regreade mine since I used the wrong stuff. Pain in the ass.
    Have a tq wrench ready, they need to go to 173 ft/lb.
    Really not a bad job. I actually did it at night just using my rock lights too see
  8. Apr 14, 2022 at 9:38 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Also not sure if your uppers came with specific washers but mine did and they're thick. If you lose one like I did, best to order more (2 cost me $20+ shipped!) because the upper will definitely shift when articulated and make noise.
  9. Apr 14, 2022 at 9:48 AM
    Vizsla
    Vizsla 2 = 2.5
    Had a noise that sounded similar to what you are hearing with a new Fox coilover, super annoying. Found what it was when upgraded suspension, there are 2 rubberish washers in the top mount where the shock attaches to the top hat and they came apart. Still in place, just broken allowing the shock and hat to contact metal to metal and make noise. Maybe give them a look if nothing else works out.
    04B8B16E-7F92-42F2-8D80-609E264BBD68.jpg 90EE8A57-28C4-46A0-AAA3-65334C7BF249.jpg
  10. Apr 14, 2022 at 10:03 AM
    94slowbra
    john
    new orleans
    2016 TRD pro
    Thanks for that. I'm going to go over everything one more time when I get it back from alignment. If all else fails ill pull them and see
  11. Apr 14, 2022 at 8:55 PM
    94slowbra
    john
    new orleans
    2016 TRD pro
    So i got it back from the alignment shop and everything was the same. Same noise and nothing new. So I pulled it in the garage and went over every bolt, again. They were all to either factory spec or spec provided by the manufacture of the part.
    So I decided to tq every bolt to factory spec. Some vary by alot. After doing this my popping is 95% gone. I only hear it now because I'm listening for it. I'm driving about 600 miles tomorrow so I'll recheck everything when I get back. At least now it doesn't sound like a shitbox going down the road
    DeesCrewMax likes this.
  12. Apr 14, 2022 at 9:22 PM
    Tundra1D6
    Tundra1D6 Well that escalated quickly…
    Who did you take it to for the alignment?
    Most people half azz them, even more so In New Orleans.
  13. Apr 15, 2022 at 4:52 AM
    94slowbra
    john
    new orleans
    2016 TRD pro
    Firestone on Vets by lakeside mall.
  14. Apr 18, 2022 at 8:02 AM
    DeesCrewMax
    Deric
    Nudging for an update on your ride quality, noises, and/or general feedback.
    I installed my JBA UCA's on Saturday and was no where near as bad as I was anticipating. Asked a neighbor to help push the bolt toward the arm (from the engine bay) while doing the passenger side as I could not reach the arm and bolt at the same time. Took about an hour per side taking my time, but the passenger side was more tedious due to the hoses and wires getting in the way. Getting an alignment tomorrow and have not driven more than 10 miles as my camber is SUPER NEGATIVE and my toe in is NOT GOOD. Hopefully the shop will hit the mark provided in the JBA instructions.
    Fox 2.0 rears (adventure tuned from accutune) should arrive today and I hope to install in the next couple of days. I'm looking forward to doing one piece at a time to really feel the result of each component (variable). I'm looking forward to getting mine, but the fronts (2.5 adventure tuned) are still likely a month out.
    Anyway, sorry to muck up your thread. I hope yours are treating you well and your road trip was a success!
  15. Apr 18, 2022 at 8:07 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Where'd you pull torque specs from?
  16. Apr 18, 2022 at 8:29 AM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Same
    monaco730[QUOTED] likes this.
  17. Apr 18, 2022 at 9:15 AM
    94slowbra
    john
    new orleans
    2016 TRD pro
    Got the right grease in for the arms so my squeak is mostly gone. I will most likely do one more "flush out" of grease soo in hopes that will 100% eliminate it.
    All other noises/pops have gone away since I tq'd everything to factory spec. Lime I said earlier, all we set to either factory or specs provided by manufacturer. Since I did them all at once I'm not sure which component was the culprit but it's taken care of and that's what matters.
    I still need to get my rears custom valved (only the fronts have been done so far) but the ride is great. I know shocks work together so I cant say 100% yet but so far so good
    DeesCrewMax[QUOTED] likes this.
  18. Apr 18, 2022 at 9:16 AM
    94slowbra
    john
    new orleans
    2016 TRD pro
    Either from install instructions (fox and jba) or from the thread stickied at the top of the page for factory components
  19. Apr 18, 2022 at 7:19 PM
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    Never heard of such soft coils on a Tundra, and I didn't know the Fox shocks could fit a 18" coil. No reason why it wouldn't work though. I thought the Ironman FC Pro coils were long and soft at ~19" and 583lb.
    You are looking for a soft ride, and it's what Accutune recommended?
    BTW, if someone wants some cheap spring compressors that worked fine for me, $31 will get you these: https://www.amazon.com/WINMAX-TOOLS-AUTOMOTIVE-Compressor-Capacity/dp/B0158BOJUW
  20. Apr 18, 2022 at 7:25 PM
    #50
    DeesCrewMax
    Deric
    that’s what they suggested for me as well. It works in conjunction with their shock tuning. They made sure I had no extra weight up front (bumper, winch, etc) and thought my aluminum skids were fine for this setup. I called in twice and spoke to two different guys and both suggested the same thing.
  21. Apr 21, 2022 at 5:55 AM
    #51
    94slowbra
    john
    new orleans
    2016 TRD pro
    Correct, this is what was recommended for the best ride. So far so good and I have plenty of adjustment on the collar still.
    I tried a spring compressor like that and couldn't fit them between the coils. The other style is thinner and fits between.
    rruff and DeesCrewMax like this.
  22. Aug 21, 2022 at 3:44 PM
    #52
    BruteForceBeWithYou
    BruteForceBeWithYou New Member
    Stephen
    2019 Cement Grey DC
    So I ordered 0-3" FOX 2.5 shocks from Accutune for my 2019 Tundra. I was concerned about having to mount them and then measure and adjust and re-mount them, really didn't want to do this, but was willing to if it meant getting it right. I mounted them right out of the box adding one coach builder shim to drivers side to compensate for lean. Really didn't know how this would affect anything but decided to try it. I also added CB +3 shackle for the rear. After getting everything installed and driving around the block my truck sits at 41" ground to fender on both driver and passenger sides and the rear is at 41-3/4" on both driver and passenger. Evidently the driver side shim I installed is doing its job and also allowed me not to have to make any adjustments. I neglected to take a measurement before I started so not sure exactly how much of a lift I actually have but I very happy with the results!!
  23. Aug 21, 2022 at 3:48 PM
    #53
    BruteForceBeWithYou
    Stephen
    2019 Cement Grey DC
    This is it after alignment. I had Bilstein 6112 for 2" lift previously and the fox 2.5" definitely make it a bigger climb to get into. Absolutely love the stance now.
    equin, GarTX526, Elduder and 5 others like this.
  24. Aug 21, 2022 at 5:12 PM
    #54
    DeesCrewMax
    Deric
    Looks great!
    I’m making the same move. My shocks are finally tuned and I’m just waiting for them to be shipped! Currently have 6112 at 1.9 with 1 shim in each side. I did ask about using the shims and they suggested compensating for lean (if I cared to) by adjusting the collars and not using the shims fwiw.
    The spring compressors listed above do allow you to adjust on the vehicle I believe so the install uninstall reinstall procedure isn’t always necessary.
    How do you like the ride so far compared to your 6112?
  25. Aug 21, 2022 at 5:18 PM
    #55
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Looks great! Congrats. Don't forget to extend your bump stops a smidge
  26. Aug 21, 2022 at 5:19 PM
    #56
    BruteForceBeWithYou
    Stephen
    2019 Cement Grey DC
    I debated on adjusting for drivers side lean but the shim made more sense to me because I liked the idea of the shocks being compressed equally on both sides. The ride is much more controlled vs the 6112 I had. It isn't nearly as jarring. I'm sure it will need a break-in period but I'm very impressed so far. Its a bit softer with the 500lbs springs and just way more controlled and predictable, only way I can describe it.
  27. Aug 21, 2022 at 5:58 PM
    #57
    Pescador74
    Pescador74 I’m here to fluff. Where’s the casting couch?
    Gabe
    2016 White 4x4 SR
    Pro comp UCA's , Fox 2.5 reservoirs, 295 70 R18 Toyos, ARE Shell
    My fox 2.5s have no adjustment unless you remove the whole shock...
  28. Aug 21, 2022 at 6:00 PM
    #58
    BruteForceBeWithYou
    Stephen
    2019 Cement Grey DC
    I have heard of some being able to compress the spring in place but not sure. Regardless, I really didn't want to have to do that. I am curious how much lift I actually have. Would like a ground to bottom of fender well measurement on a stock Tundra just for curiosity.
  29. Aug 21, 2022 at 6:06 PM
    #59
    rruff
    rruff New Member
    I think if you jack up the truck and partially compress the spring, you should be able to turn the adjuster. Or are you saying you can't access the collar?
  30. Aug 21, 2022 at 6:48 PM
    #60
    DeesCrewMax
    Deric
    AccuTune Offroad likes this.
