Oil brand
Discussion in '2.5 Gen Tundras (2014-2021)' started by PonyMan, Apr 8, 2022.
  1. Apr 12, 2022 at 12:01 PM
    #61
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    As far as reading material for the seal conditioners, I do not. Googling it is a shit show. This is just information I've learned from talking with different engineers and chemists, so take it with a grain of salt. Any oil with an API rating will have to meet certain parameters, so they all essentially contain the same conditioners, etc. The amount will vary, but it won't be out of API specs. If you want to actually swell the seals on something, use diesel, it seems to swell the seals on anything :muscleflexing:
    As far as UOAs, this is a great reference to get a better understanding
    https://bobistheoilguy.com/engine-oil-analysis/
    And for grease, check this out
    https://bobistheoilguy.com/functions-of-grease/
    I find myself checking the grease page whenever I need to check cross compatibility, etc.
    JRS[QUOTED] likes this.
  2. Apr 12, 2022 at 3:01 PM
    #62
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    The 2 million mile Tundra did 5k OCIs...
    stevesgraytundra likes this.
  3. Apr 12, 2022 at 3:28 PM
    #63
    Sumo91
    TN
    You mean the guy who is on his 3rd tundra and has over 2 million miles logged? He does 10k OCIs
  4. Apr 12, 2022 at 4:04 PM
    #64
    sd172
    sd172 New Member
    South Dakota
    2021 Sequoia Nightshade
    I think he meant that changing your oil more frequently will do more for eliminating engine wear than using an expensive oil.
    Q: Why does one change oil anyway?
    A: Modern day gasoline is a product of deep crude oil treatment and contains a significant amount of aromatic compounds (including BTEX) that produce large quantities of black soot when burning. That soot with blow-by gases contaminates oil regardless of what brand of oil you use.
    Sumo91 likes this.
  5. Apr 12, 2022 at 4:40 PM
    #65
    Sumo91
    TN
    Oil has soot holding capabilities, which is 'one' of the reasons why it turns black. And it's almost a non issue in gas engines (except DI engines). Diesel is another story, they're high compression and much more prone to blow by . The detergent/dispersant packs clean and suspend insolubles so they don't settle on engine surfaces and they're able to be removed when draining oil.
    10k mile oil from my tundra is brownish (but getting better every oil change as the oil cleans)
    10k mile oil from my 7.3 is black.
    sd172[QUOTED] likes this.
  6. Apr 12, 2022 at 4:43 PM
    #66
    Rocko9999
    Rocko9999 New Member
    Mobil High Mileage. Has best seal conditioning package IMO.
  7. Apr 12, 2022 at 4:55 PM
    #67
    sd172
    sd172 New Member
    South Dakota
    Are you running a lot of highway miles with both engines?
    Sumo91[QUOTED] likes this.
  8. Apr 12, 2022 at 5:08 PM
    #68
    Sumo91
    TN
    Yes. 7.3 is 2wd so it's all highway, lots of towing and idle time as well.
    Tundra is 70% highway. Lots of offroading and towing. Got her with 172k miles. She's about to hit 240k. PO only used Dino oil, so the high quality oils I've been using has been cleaning up all deposits in the engine. My current oil has tons of esters and Alkylated Naphthalene. Great for cleaning.
  9. Apr 12, 2022 at 5:26 PM
    #69
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    No, I don't mean that...
    I was just pulling your chain as in, it was a joke.
    When it comes to OCIs... I say do whatever you feel comfortable with for your truck. I do 5k b/c I'm SC'd and see it as a modified service interval and further protection for the boosted motor.
  10. Apr 12, 2022 at 5:29 PM
    #70
    Sumo91
    TN
    I thought it was a joke. But didn't want to offend you by laughing just in case you were serious :rofl:
    Toyotoholic[QUOTED] likes this.
  11. Apr 12, 2022 at 5:38 PM
    #71
    sd172
    sd172 New Member
    South Dakota
    Sumo91 likes this.
  12. Apr 12, 2022 at 5:40 PM
    #72
    sd172
    sd172 New Member
    South Dakota
    I know I need to reach out to those guys. They have the best stuff.
  13. Apr 12, 2022 at 5:50 PM
    #73
    Sumo91
    TN
    Here's some good reading material and an insight into the company.
    https://bobistheoilguy.com/forums/threads/high-performance-lubricants-pcmo-series.344421/
    I talked to the owner for about an hour discussing my oil needs, amongst other things. Really great guy, and is happy to answer any questions you may have, it's nice to be able to call the owner of the company if you have any questions, he even made a special batch of 75w for me at no upcharge from their regular gear oil cost. I run their HDEO personally. But wouldn't have an issue running their PCMO.
  14. Apr 12, 2022 at 5:57 PM
    #74
    Bulldog9
    Bulldog9 "My other car is a Porsche"
    NOVA
    2017 TRD PRO in Cement
    see sig for mods.....
    You guys change your oil?
    OHwendTrd likes this.
  15. Apr 12, 2022 at 6:39 PM
    #75
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 Maggie 1900
    Didn’t the million mile tundra run Toyota oil? Seems to me that its not the type of oil but the maintenance and not driving it like you stole it.
    What I find interesting about people who spend $$$$$ on oils, it’s only to turn around and sell with only 50k miles on the vehicle.
  16. Apr 12, 2022 at 7:22 PM
    #76
    Fishhead
    Fishhead New Member
    Usually use Amsoil 0w20 but the last couple of changes I’ve used Valvoline Extended Protection 0w20. (Lots of moly in its great additive pack).
    I use either Amsoil or Toyota filters.
    Tyman and Wallygator like this.
  17. Apr 13, 2022 at 6:57 PM
    #77
    parkerbows
    parkerbows New Member
    Jack
    2017 crew max sr5 trd off road
    Firestone air ride air bags
    I change my one oil 2 times a year. i will pay 100 bucks twice a year for the best oil out there.
  18. Apr 14, 2022 at 3:20 AM
    #78
    Bammer
    Monroe, CT
    Because it costs the most, it's the best?
  19. Apr 14, 2022 at 4:09 AM
    #79
    parkerbows
    Jack
    Definitely not. But I have watched a couple independent tests which are good enough for me to spend an extra 80 bucks a year.
    https://www.youtube.com/watch?v=TWuKvnCq1js
    Wallygator and Tundradrenalin like this.
  20. Apr 14, 2022 at 4:53 AM
    #80
    Bammer
    Monroe, CT
    What if I told you that a truck at work was retired due to rot that had 298,000 miles on it, original motor that had yearly oil changes with bulk dino oil, no smoke, no consumption.. Ridden hard and put away wet it's whole life.
    We all feel better when we pour in that expensive liquid gold every 5k and think, I'm doing good. Are we? Or are we flushing money down the toilet?
    nobodyintexas and sd172 like this.
  21. Apr 14, 2022 at 5:03 AM
    #81
    parkerbows
    Jack
    I spend alot on my truck and I am ok with it if I am wasting money. I change myself so I am basically just paying the same as someone who takes to a dealer
    SShooterZ and Wallygator like this.
  22. Apr 14, 2022 at 5:34 AM
    #82
    Tundradrenalin
    Tundradrenalin New Member
    Virginia Beach, VA
    2016 DC Black TRD nonPRO
    Methods, Toyos, Kings, TCs, CBs
    This is such an interesting and unique forum topic. Thank you for making this thread!
  23. Apr 14, 2022 at 5:42 AM
    #83
    Bammer
    Monroe, CT
    Fair enough
  24. Apr 14, 2022 at 5:43 AM
    #84
    Bammer
    Monroe, CT
    They always are interesting in the beginning, then they usually spiral into a pit of doom , despair and name calling.
    PonyMan[OP] likes this.
  25. Apr 14, 2022 at 5:46 AM
    #85
    Tundradrenalin
    Virginia Beach, VA
    hi John. I'm Andrew. :pccoffee:
  26. Apr 14, 2022 at 6:12 AM
    #86
    Bammer
    Monroe, CT
    Hi Andrew...:hattip: I thought your name was Male?o_O
  27. Apr 14, 2022 at 6:14 AM
    #87
    Bammer
    Monroe, CT
    For the record , I use M1 , usually 0W20, but I'm going to try 0W30 next change, see what shakes.
  28. Apr 14, 2022 at 8:16 AM
    #88
    Charliebrn
    Charliebrn New Member
    NW Ohio
    2017 DC Limited 4x4 Tundra
    Tyger Folding Tonneau cover Polished stainless running boards LED interior lighting VLED Footwell Kit LED Bed lighting
    Eh, I read on a blog at Blackstone that their techs usually just use regular Dino oil and change it at 3k.
    me, I’ve been using M1 0w-20 and last December had an OA done by them and it got a fantastic report, so guess I’ll just keep doing the same every 4K. Brand probably doesn’t matter if it’s frequent, but most of my driving is towing or city, so I’ll do it every 4k
    Hoff, PonyMan[OP] and WILLINH like this.
  29. Apr 14, 2022 at 8:23 AM
    #89
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    Kirkland 0-20 for me.
    I posted an oil analysis on the Harrop Stage 1 thread.
    4700 miles on oil. no shear. Strong TBN. no metals.
    this oil had my dyno tuning on it.
    so...Kirkland is good enough for me.
    Nowhereman likes this.
  30. Apr 14, 2022 at 8:37 AM
    #90
    stevesgraytundra
    stevesgraytundra New Member
    Stephen
    2021 MGM SR5 CM 4x4
    Humanity advanced from the Stone Age to the instant global communication age so that we could all question someone else’s choice in motor oil.
    Wallygator, Sumo91, TTund16 and 4 others like this.
