Wiring help
Discussion in 'Electrical' started by spcbuzzard, Apr 8, 2022.
  1. Apr 8, 2022 at 2:37 PM
    spcbuzzard
    spcbuzzard [OP] New Member
    Dustin
    2011 Tundra 4.6L V8
    So I had a critter chew up some wiring and it’s been a nightmare trying to get a suitable replacement. The wiring goes to my map sensor and the colors don’t match up. I’m texting to figure out which wires to splice together. The first pic is what remains in the truck. Second pick is the attachment I got from a scrap yard today.
    note that there are four wires on the new attachment and only three on the existing wiring.
    Any help would be much appreciated.
    2011 Tundra
    V8 4.6l 2wd
  2. Apr 9, 2022 at 7:20 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    2007 RCSB 2014+ TRD Pro Conversion 5.7 4x4
    Full 2014+ Conversion Regular Cab Short Bed 4X4 2019 TRD Pro Grill, 2014+ Front End Swap 2014+ Interior/Dash Swap with TRD Pro Leather Seats, 2014+ Bed Swap with TRD Pro Stamping SOS 2/4 Drop Kit
    Took me a while to find it but here it is from the 2011
    Connector D80 Intake Manifold Vacuum Sensor
    I think this image is as you are looking into the connector from the side with no wires. With the latch switch upward, and looking into the connector, I believe that means Pin#1 Black Pin#2 Black Pin#3 Yellow Pin #4 White/Black on your junkyard connecter. If you can tell me what year and engine of the truck you cut that from I can look it up. Also where you cut if off the harness.
    All the diagrams (below) show the Intake Manifold Vacuum Sensor to be Blue/Red, Brown, Blue. I think the one you have is a different connecter of the same style. Hence why the wiring is a different color and has a 4th wire.
    Pin #1 Blue Red Stripe PIM
    Pin #2 Brown E2
    Pin #3 Blue VC
    Mater and texasrho83 like this.
  3. Apr 10, 2022 at 10:06 AM
    spcbuzzard
    Dustin
    2011 Tundra 4.6L V8
    Jeff thank you so much man. I’ve been playing with it and I got it to work.
    One of the blacks were extra (it came from a Prius and I imagine it has something to do with its batteries). Yellow to brown was constant power. White/ black to blue was the neutral, and one of the blacks went to the blue red.
    Jeff_5_7 and Mater like this.
