Save Ironman 2022 aka Panhandlemonium
Discussion in '1st Gen Tundras (2000-2006)' started by bmf4069, Mar 31, 2022.
  1. Apr 7, 2022 at 6:27 PM
    #181
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    They're probably full of it. Take a look at the adjusters for the lowers.
    The rear ones should have the bolts pushed fully to the outside (towards the wheels) and the front ones should be mostly inwards.
  2. Apr 7, 2022 at 7:30 PM
    #182
    Do the goobers at Firestone even know how to handle those aftermarket UCA's? Are those not more adjustable?
  3. Apr 7, 2022 at 8:12 PM
    #183
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    Looks like DNA all over the place
    BroHon, chrisb and FrenchToasty like this.
  4. Apr 7, 2022 at 8:43 PM
    #184
    They promised otherwise
  5. Apr 7, 2022 at 8:43 PM
    #185
    Hell yeah!!!!
  6. Apr 7, 2022 at 8:48 PM
    #186
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    I must be a big ol fat donger too because the last time I checked, Freedoms aren’t adjustable.
    chrisb, bmf4069[OP] and FrenchToasty like this.
  7. Apr 7, 2022 at 8:51 PM
    #187
    Shalt JBA and spc be the only two in that fight?
  8. Apr 7, 2022 at 8:52 PM
    #188
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    And yeah, I agree with everyone else. I set the tabs to eyeball center and got 1.6 on the driver. I bet if I would have pushed the passenger rear out it would be close to the same and would have evened out that negative camber.
    God I wish we had another day.
  9. Apr 8, 2022 at 3:53 AM
    #189
    No I guess I am the donger. I just assumed all the aftermarket UCA's had some adjustability.
    It's hard to find a shop around here than can do a proper alignment with my SPC arms. I have to go to the 4x4 shop and last time they were assholes about it.
    bmf4069[OP] likes this.
  10. Apr 8, 2022 at 4:03 AM
    #190
    bmf4069 [OP] Michelob Ultra coinesour
    I'll throw the AAL in and level the truck out then take it to a different firestone here. Maybe they'll have a competent tech. If not, we'll do a good adjustment when I make my way down there.
    chrisb and 5N0W808 like this.
  11. Apr 8, 2022 at 4:04 AM
    #191
    Freedoms are basically just to get more.....freedom.....in your UBJ when lifting.
  12. Apr 8, 2022 at 7:47 AM
    #192
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    So, solo motosports brings out the extra caster LCA’s and alignment shops just ‘happen’ to forget how to adjust for caster…
    chrisb, 5N0W808, MrDirtjumper and 2 others like this.
  13. Apr 8, 2022 at 7:53 AM
    #193
    I would suggest you show/tell @bmf4069 how to do that if he doesn't already know. Something tells me that's too complex an operation for the employees at Firestone.
    That way he can revisit them for an adjustment that's close to how it should be considering he got the lifetime "all-we-do-is-adjust-toe" package. :D
    chrisb and bmf4069[OP] like this.
  14. Apr 8, 2022 at 7:57 AM
    #194
    He showed me, but we were both kinda inebriated. I got the gist of it though. It's those cam bolts that kinda confuse me, and I don't wanna fuck with toe. I hate tie rod ends.
  15. Apr 8, 2022 at 8:16 AM
    #195
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    3 years ago when I installed the SPC uppers on mine I had to drive back to the shop to show them how to add more caster...even though I left the instructions with them. So I'd say they mostly just want to fiddle with the cams and get the pretty green colors.
  16. Apr 8, 2022 at 8:39 AM
    #196
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
  17. Apr 8, 2022 at 1:18 PM
    #197
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    I thought freedom added 2-3 degrees of caster. I'm not buying firestone's explanation. I also have the lifetime alignment and I called a few different ones until I found a guy who knew lifted trucks and aftermarket parts. (my old lifted tundra on stock arms had that much caster).
    Also, I think SPC are the only arms that are adjustable. JBA add more caster but don't have the adjustable ball joint SPC does.
  18. Apr 8, 2022 at 4:07 PM
    #198
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    I’m one of those people who isn’t exactly great with words so I just say fuck a lot.
    Trust me, I think they all heard enough of it last weekend.
    chrisb, 5N0W808, bmf4069[OP] and 2 others like this.
  19. Apr 8, 2022 at 4:25 PM
    #199
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    bmf4069[OP] and Sirfive like this.
  20. Apr 8, 2022 at 4:36 PM
    #200
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Dont forget to set your ride height before making other adjustments, if that missing inch of lift on the driver side really bugs you. Maybe check height at the body mounts to make sure its not a misalignment with a fender.
    5N0W808, NUDRAT and bmf4069[OP] like this.
  21. Apr 8, 2022 at 4:47 PM
    #201
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    All this talk of no BBQ made me crave brisket. So…
    Kinda feel like a dick and like I should have done this last Thursday but then I also kinda feel like I’ll have a 12lb brisket to split with the Mrs. in the morning so ehh…
    5N0W808, bmf4069[OP], shifty` and 5 others like this.
  22. Apr 8, 2022 at 6:54 PM
    #202
    Money shot or it didn't happen!
    bmf4069[OP], Sirfive and FrenchToasty like this.
  23. Apr 8, 2022 at 8:55 PM
    #203
    After talking with the guys at the specialty shop, I'm gonna put in the AAL, then lift the front more. They're gonna level it then I'm gonna take it to another firestone. They can handle lifts at the other one.
    chrisb, 5N0W808, NUDRAT and 1 other person like this.
  24. Apr 8, 2022 at 8:59 PM
    #204
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Tell them you want:
    -0.1 camber
    2.8 caster
    .15-.20 total toe (.07-.10 per side)
    chrisb, NUDRAT, des2mtn and 1 other person like this.
  25. Apr 8, 2022 at 9:01 PM
    #205
    I gave them JD's specs, but they couldn't meet them because my uppers drooped too much.
  26. Apr 8, 2022 at 9:07 PM
    #206
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    Sounds like a big ol bag of booshit to me.
  27. Apr 8, 2022 at 9:19 PM
    #207
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    My uppers outers are way higher than the inners. You’re should be closer to level? Or are your outers lower than your inners?
  28. Apr 8, 2022 at 9:20 PM
    #208
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    zoomed out so i can fit the pic kinda fish eye’s everything. But, by droop, do you mean your upper arms have dropped past level and your ubj’s are lower than your uca bushings?
  29. Apr 9, 2022 at 5:40 PM
    #209
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    I put it in the 1st Gen round up PM thread. You sure you don’t want anything for it?
  30. Apr 9, 2022 at 7:21 PM
    #210
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    Sorry to disappoint but it wasn’t my greatest. Wife and I went to go grab drinks & dinner and I guess somehow my fire went out. So it got about 2 hours of smoke and then about the same time to cool back off. Lit it back up for another couple hours but started dozing off around 1:30 so I just bailed, wrapped it and put it in our oven.
    5N0W808, Sirfive, bmf4069[OP] and 3 others like this.
