  1. Apr 8, 2022 at 9:34 AM
    Darkness, bmf4069 and Sirfive[QUOTED] like this.
  2. Apr 8, 2022 at 9:34 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Ah, you've summoned me. I've ridden an old school big-bore 2-stroke and multiple big-bore 4-strokes. The '83 YZ490 was a much different beast than any of my 4-strokes I've ridden. It was a bat out of hell and could kick your ass, but it was a blast to ride. Tons of compression to kick over, your hands would shake for awhile after getting off. Seat was like a couch. I miss that bike, but my KTM provides the same range of power in a different way. The YZ was barely ridden after getting the KTM.
  3. Apr 8, 2022 at 10:00 AM
    Maybe that's why it's peeled? Was originally green and resprayed at the distribution point to make it red pearl?
    Truthfully, I've never seen that two tone mix when I bought mine, only the green/tan combo but only the largest dealers (Boch) had them in my area on any regular basis.
    bmf4069[QUOTED] likes this.
  4. Apr 8, 2022 at 10:02 AM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    No, the tan was sprayed after the red. There was red under the door sills. Didnt really pay attention to the door jambs.
    RUSTYNUTS, bmf4069 and Jack McCarthy like this.
  5. Apr 8, 2022 at 10:36 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    i double checked and i dont have rear vents. But i also dont have the rear cup holders on the center console like the sequoia did. Maybe its newer model stuff.
    5N0W808[QUOTED] and RUSTYNUTS like this.
  6. Apr 8, 2022 at 11:21 AM
    Why is my color combo not listed but green/tan is?
    GODZILLA likes this.
  7. Apr 8, 2022 at 11:21 AM
    Hmm, now I wanna see the door sills on a green/tan...
    RUSTYNUTS and Jack McCarthy like this.
  8. Apr 8, 2022 at 11:33 AM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    I had an air line push to fit/connect come loose so I searched for lock clips. Found these for water/irrigation but they work on my 3/8 air lines and I think I can file them for a better fit.
    @FrenchToasty @Casper421
    RUSTYNUTS, FrenchToasty and Sirfive like this.
  9. Apr 8, 2022 at 11:51 AM
    Yeah it looks like a John guest safety clip.
    Good call!
    alb1k[QUOTED] likes this.
  10. Apr 8, 2022 at 11:55 AM
    alb1k
    Left Coast
    It's good
    If you want any I'll send them to you.
  11. Apr 8, 2022 at 11:57 AM
    alb1k
    Left Coast
    It's good
    OOOH, looks like the John Guest have intended for air!
    Edit: Nope, intended for water lines and fittings, very close though.
  12. Apr 8, 2022 at 1:04 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Beats me
  13. Apr 8, 2022 at 2:05 PM
    I think someone said previously that 2 tone trucks likely didn't come that way from the factory and we're painted upon delivery at the dealer.
    Basically, Ironman is special.
    bmf4069[QUOTED] and NUDRAT[OP] like this.
  14. Apr 8, 2022 at 2:36 PM
    "SPECIAL" :D
    I actually pontificated that possibility with another member's truck on here a while back, but it didn't gain any traction. I'd need to see the back of the cab wall and bed wall. If they took time to paint those, I'd be leaning more in-favor of this being 'factory' or 'port' versus dealer.
    chrisb, Darkness and RUSTYNUTS like this.
  15. Apr 8, 2022 at 3:14 PM
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE; previous 02 AC 323k
    Eibach pro suspension Nitro 4.88 with Auburn Pro LSD and PTFE diff bushings Level 8 MK6 18x9 SAIS bypass JBA cat back Scangauge 2 Diode dynamic fogs. LED heads
    Leave yourself an out.
    Space on all 4 sides but always in front
  16. Apr 8, 2022 at 3:34 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    :sadviolin:iron man, iron man, does whatever an iron can…
    chrisb, bmf4069, Darkness and 3 others like this.
  17. Apr 8, 2022 at 3:35 PM
    I’m always planning out moves in my head, how I’d tuck and roll over a hood, or if I jumped off, could I run it out. I also think about having a stick or throwable on board for emergencies
    chrisb, bmf4069, Darkness and 2 others like this.
  18. Apr 8, 2022 at 5:12 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    A good moto boot to a car door wakes up the driver :)
  19. Apr 8, 2022 at 5:36 PM
    bmc02
    bmc02 New Member
    Buddy
    E WA
    05 DC SR5 / 06 SEQUOIA LTD
    Fixed my '82 Suzuki dt115 outboard today. Wouldn't start after having sat for over a year. No spark. Worried it was something difficult (old motor, hard to find parts) and expensive like the CDI or stator. Turns out the kill switch was bad... Huge relief! When you finally hear it fire up, what a beautiful sound.
    chrisb, bmf4069, txagg and 3 others like this.
  20. Apr 8, 2022 at 5:49 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Thank you good sir. I learned somethin new. Always thought the ‘jet’ in ‘jet black’ somehow derived from the aircraft.
  21. Apr 8, 2022 at 5:57 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Absolutely not mister. How dare you. Gemstone black. It literally says ‘jet’ is a gemstone. And it’s black. And the term ‘jet black’ is used to reference the blackest black possible. I have a feeling you didn’t read the handout.
    chrisb, bmf4069, daveeasa and 3 others like this.
  22. Apr 8, 2022 at 6:02 PM
    I saw lowest rank of coal, and mineraloid and got confused, that was a fight or flight statement
  23. Apr 8, 2022 at 6:15 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
  24. Apr 8, 2022 at 6:19 PM
    chrisb, bmf4069, txagg and 1 other person like this.
  25. Apr 8, 2022 at 6:20 PM
    NUDRAT
    NUDRAT [OP] 6 lug life
    SW CT
    Between 'Ridgelines'
    Did someone say 2-stroke?
    https://youtu.be/WrQSCaUvtcM?t=11
    for you folks in TX & SO-Cal, the white stuff on the floor is called snö :)
    KK6PD, daveeasa and RUSTYNUTS[QUOTED] like this.
  26. Apr 8, 2022 at 6:21 PM
    One man’s garbage is another man’s treasure……
    Darkness[QUOTED] and daveeasa like this.
  27. Apr 8, 2022 at 6:22 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Haha. I knew you’d be the one to respond to that. I ride a YZ 250 but I don’t hate 4-strokes. I just love the sound and smell of a 2 stroke too much. And I’ve got a green sticker that I won’t give up. Gotta enjoy it before they outlaw 2strokes altogether.
    One of my buddies Jesse that I used to ride with had a CR500 that was an absolute beast and I wanted nothing to do with it. He talked me into tryin it out once. I took off up a sandy riverbed (we were up near Beaumont) and even in soft sand, and me sitting on the tank, the front tire still came up goin into 3rd gear. I turned around and took it straight back to him and said “keep this fucking thing away from me. There’s absolutely no reason for a dirt bike to have that much power.” Then our other buddy Kevin wanted to try it out. He gassed it off this little 6 foot drop that we’d been hittin all day, and the thing rocketed right out from under him. He got the wind knocked out of him and the bike suffered a snapped rear fender. On the way home, Jesse pulls into the Honda shop and kevin says “what are we doin here?” Jesse replies “You’re buying me a new back fender.” Classic.
  28. Apr 8, 2022 at 6:23 PM
    empty_lord
    05 rollover special
    Put my a pillars in.. waiting on the grab handles. How fun…. Legit just need a driver side door panel and the right seats. (Plus the regular cab stuff, but it’s close enough for now) and I’ll be happy with my interior.
    chrisb, Sirfive, bmf4069 and 4 others like this.
  29. Apr 8, 2022 at 6:26 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
  30. Apr 8, 2022 at 6:28 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    GET HIM BROTHER!
