What is this?
Discussion in '2.5 Gen Tundras (2014-2021)' started by PermaFrostTRD, Apr 8, 2022.
  1. Apr 8, 2022 at 5:07 AM
    PermaFrostTRD
    PermaFrostTRD [OP] Tumescent Member
    Northern NY
    Next to the rear view mirror? GPS antenna (my head unit doesn’t have NAV, btw)?
    2019 sr5 crewmax
    Am I being tracked? Should I wrap it in tinfoil?:tinfoilhat:
    Darkness likes this.
  2. Apr 8, 2022 at 5:11 AM
    timsp8
    NY
    GPS antenna is on the dash. I thought that was the front camera and stuff for the lane assist. Does your truck have that though or did that start in 2018 with all the safety sense stuff.
  3. Apr 8, 2022 at 5:12 AM
    Makoy339
    Makoy339 Simplicity = Reliability !!!
    Super White TRD
    TRD parts
    I believe thats part of the Radar Sensor system.
    PermaFrostTRD[OP] likes this.
  4. Apr 8, 2022 at 5:13 AM
    Blueknights75
    Ron
    Clayton, NC
    Part of it is the Toyota Safety Sense hardware.
  5. Apr 8, 2022 at 5:15 AM
    PermaFrostTRD
    Northern NY
    it does. No front camera, but BSM and collision avoidance.
    Sorry, just realized I need to update avatar and profile.
    So "yes" to the tinfoil? LOL
    Thank you for the reply.
    timsp8[QUOTED] likes this.
  6. Apr 8, 2022 at 6:20 AM
    Wallygator
    If you carry your cell phone with you, yes, you are being tracked. o_O :gossip:
  7. Apr 8, 2022 at 6:20 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    2007 RCSB 2014+ TRD Pro Conversion 5.7 4x4
    Full 2014+ Conversion Regular Cab Short Bed 4X4 2019 TRD Pro Grill, 2014+ Front End Swap 2014+ Interior/Dash Swap with TRD Pro Leather Seats, 2014+ Bed Swap with TRD Pro Stamping SOS 2/4 Drop Kit
    Look from the front closely. I am pretty sure there is a small camera in there.
    It works with the radar sensor in the grill for all the safety sense system. If pre collision and auto braking is activated it will take pictures of the “threat” at like .5 second intervals.
    August of 2017 is when production changed to add all the Safety Sense system. I haven’t seen a 2018+ without a front camera yet.
    The radio headunit, GPS antenna, network gateway is what is tracking you and sending that data to Toyota. All the guys with the new trucks and the app that can see ODO, Fuel, Remote Start ect on thier phone. If your phone can see the data so can Toyota. The network gateway is sending it out from the truck to a “network”
  8. Apr 11, 2022 at 6:23 PM
    PermaFrostTRD
    Northern NY
    Any idea where? What it looks like? Not trying to be a douche, but I kind of miss the crummy nav from my 2014. Was wondering if I could merely swap head units with an OEM that “has NAV” already. I only use it to see upcoming bends in unfamiliar roads or named streets in a city. Any kind of “turn by turn” directions I was using Waze & now Apple Maps since their waze-esque traffic updates seem to be pretty on point.
    I just don’t really wanna do the aftermarket thing.
  9. Apr 11, 2022 at 7:00 PM
    panicman
    Eric
    2018 SR5 CM TRDoffroad MGM
    I didn’t want to either. But Waze is just one awesome thing you get if you take the plunge. AE56E23B-9AC8-4D78-93D6-C917AF077395.jpg
  10. Apr 12, 2022 at 3:16 AM
    PermaFrostTRD
    Northern NY
    That looks really slick. Is it apple car play nav or independent or both? What unit is that.
    panicman[QUOTED] likes this.
  11. Apr 12, 2022 at 3:23 AM
    18" TRD Off Road Wheels
    Yes, that is a camera. It is not a camera you can look through or access like your reverse camera, but the TSS system uses it for lane keep and collision avoidance.
  12. Apr 12, 2022 at 8:45 AM
    panicman
    Eric
    Thanks! It’s the Pioneer DMH- WT8600NEX multimedia receiver. It allows for wireless Apple CarPlay, so you pick your own NAV app. You do give up the CD player, but I haven’t played a CD in a long time.
  13. Apr 12, 2022 at 2:51 PM
    timsp8
    NY
    Older diagram, but it shows the routing. Not sure if the part # changed.
  14. Apr 12, 2022 at 2:54 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    That's the ambient light sensor.
    mountainpete likes this.
  15. Apr 12, 2022 at 2:57 PM
    timsp8
    NY
    Don’t want to disagree with you, but:
    Part # 86860 in the diagram.
    Where is it then?
  16. Apr 12, 2022 at 3:10 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    You are both right.
    The circular item is the ambient light sensor.
    On older Tundras there is also a GPS antenna in the dash in that location. 2014-2019 also are under the dash but it's a different antenna. 2020+ have relocated the GPS, AM/FM and XM to a single shark fin antenna on the roof.
    Edit: the antenna on the outside of the roof at the front is just a sat radio antenna. And a poor one at that.
  17. Apr 12, 2022 at 3:26 PM
    BrunoTheRescuePup
    BrunoTheRescuePup New Member
    SW Portland Metro
    2021 MGM Limited TRD
    Eibach Pro-Truck 2.0, Coachbuilder +1, Undercover Flex, Tyger Star Armor, TRD Rear Sway Bar, DD SS3 Max, MisoCustoms
    This is accurate. If you drive with the window in front of the camera frosted over you will get a TSS disabled error.
  18. Apr 12, 2022 at 4:14 PM
    Jernik
    Jernik New Member
    Jeremy
    2020 MGM Tundra Crewmax
    That's a big box for just a little camera. I bet they have all kinds of surveillance equipment tucked in there - listening to every word you say, tracking everywhere you go, taking air samples to see how often you bathe, what you had for lunch, if/what you smoke... I need more foil, my hat isn't big enough! :tinfoilhat:
  19. Apr 12, 2022 at 5:31 PM
    Army_of_One
    Army_of_One New Member
    2019 MGM 4X4 CrewMax, 2005 Cement 4x4 Double Cab
    OEM+
    HulkSmurf14 and Cpl_Punishment like this.
  20. Apr 12, 2022 at 9:12 PM
    MALIBU1794DC
    MALIBU1794DC Like a Japanese Texas built Rock
    2019 Double cab 1794
    What head unit is that?
  21. Apr 12, 2022 at 11:43 PM
    panicman
    Eric
    Post #12
