Need shock advice
Discussion in 'Suspension' started by Kem77, Apr 6, 2022.
  1. Apr 6, 2022 at 8:26 AM
    Kem77
    Kem77 [OP] New Member
    Kem
    2011 tundra trd
    We are on the 2021 Baja trail and I killed my front shocks yesterday. Can you recommend me what shocks would be equivalent or better than what I have?
  2. Apr 6, 2022 at 8:28 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    4600s are stock replacements, or if you want to lift the truck there are many coilovers available. Need more info, intended use, want to lift?, budget?
  3. Apr 6, 2022 at 8:29 AM
    frichco228
    Frank
    Virginia
    and I am guessing, with a shock break like that....are you running a spacer level kit up front?
    Luckydog likes this.
  4. Apr 6, 2022 at 8:44 AM
    Hanzo
    Hanzo New Member
    OME, Dobinsons, or Ironman shocks might be another consideration.
  5. Apr 6, 2022 at 8:45 AM
    Kem77
    Kem
    2011 tundra trd
    Hmm. That’s sounds right. We bought it used and I think the guy mentioned something about something to raise the front end to level it with the back.
  6. Apr 6, 2022 at 8:55 AM
    Kem77
    Kem
    2011 tundra trd
    It’s a daily driver but we like to have fun too. Some lift would be good and the ability to do yesterday (whoops) without breaking them again.
  7. Apr 6, 2022 at 8:55 AM
    Hanzo
    Hanzo New Member
    What are you looking to spend?
  8. Apr 6, 2022 at 8:58 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    6112s and send it
    SAGE63 and FrenchToasty like this.
  9. Apr 6, 2022 at 9:01 AM
    Kem77
    Kem
    2011 tundra trd
    What is the price range?
  10. Apr 6, 2022 at 9:04 AM
    Hanzo
    Hanzo New Member
    1,000-10,0000 just depends what you want. The sky’s the limits really. But I think to replace four shocks and front coils with a quality entry level system you’re talking 1,.200-1,500.
  11. Apr 6, 2022 at 9:15 AM
    1794TX
    Steven
    N.TX
    '20 1794
    With the info you've provided so far, what @frichco228 said about a spacer lift was begging a deeper conversation. Best get that spacer lift out and put in a proper lift if you're going to be playing rough. 'Lift Kits' come in all shapes and sizes, and this forum is a great place to do research. Whatever you think your current budget is, I'd stick to the moto 'buy once, cry once' and fit the budget to the use, even if you have to take a pause on the purchase.
    Since it's your daily driver, I'm betting you're in a rush to get it in some drivable shape, so if this string doesn't provide perfect info quickly, it might do to get that one shock replaced and work on the lift after. As Frank also said, and by the look of your shock, a Bilstein 4600 is the item you want for a straight replacement.
    I have a Falcon levelling kit, and love it. Drawbacks for heavy use are that it's using stock springs (which you appear to have). Stock springs are comfy on the road, but not as capable as off-road aftermarket springs. The shocks are off-road ready, and again; they're really great. If you want a higher lift, though, these will only get you 2.25" without further considerations. Other folks love their various brands of shocks and lifts too; and hopefully you can draw information from their previous posts and from them directly.
    A great place to start research is here: Guide: Different Types of Lifts | Toyota Tundra Forum (tundras.com)
    Be ready for a storm of opinions.
    Good Luck, and congrats on your purchase of a Tundra.
  12. Apr 6, 2022 at 10:12 AM
    Hanzo
    Hanzo New Member
  13. Apr 6, 2022 at 10:21 AM
    bmw345
    bmw345 New Member
    CT
    2018 Platinum Pro, Pro Fox's TRD Skid
    6112/5160 combo would be great and you can dump that front spacer if you have one. Problem is no one has any 6112 and no one know when they will actually be in stock. I waited two months for the 6112's and ended up going with Toyota and the TRD Pro Fox kit. They were in stock and shipped quickly. Not sure if they are still available at this time. Good luck!
    SAGE63 likes this.
  14. Apr 6, 2022 at 11:37 AM
    Kem77
    Kem
    2011 tundra trd
    Oh bummer! We were planning on going with the 6112’s. Thanks so much for everyone’s input!
  15. Apr 6, 2022 at 11:42 AM
    Kem77
    Kem
    2011 tundra trd
    Is this the spacer?
  16. Apr 6, 2022 at 11:43 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Brett at Underdog might have some, give him a call 480-269-2833
  17. Apr 6, 2022 at 11:45 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    Yes, while the spacers not really recommended it's the lack of bump shim that caused it to fail. Spacer moves everything down, including the compressed length of the shock assembly causing it to become the bump. You wouldnt have had this failure had a bump shim been installed.
  18. Apr 6, 2022 at 11:55 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yep, you should've extended your bump stops
  19. Apr 6, 2022 at 12:07 PM
    bmw345
    bmw345 New Member
    CT
    Sure is and it looks like your cam tower may also be leaking judging from the stain on your exhaust shield.
  20. Apr 6, 2022 at 12:56 PM
    Kem77
    Kem
    2011 tundra trd
    Thanks for the bump stop advice. I’ve never heard of those but that’s a great idea!
  21. Apr 6, 2022 at 1:29 PM
    CavBluTundra
    CavBluTundra CavBluisdabomb
    Howard
    2018 TRD Off Road Limited
    A member has a set of Ironman front coilovers for sale on here right now. Couldn't figure out how to paste a link to his post.
  22. Apr 6, 2022 at 2:30 PM
    SAGE63
    San Diego County
    Depending on where you are located someone may have some low mileage take offs available for sale...I might next week, I am in San Diego
