JLT Oil Separator
Discussion in '2.5 Gen Tundras (2014-2021)' started by TRD 4 ME, Apr 6, 2022.
  1. Apr 6, 2022 at 11:50 AM
    TRD 4 ME
    TRD 4 ME [OP] New Member
    2021 Tundra TRD Off Road Cement
    FYI- This is a pic of almost 3 ounces recovered in the first ~7,000km on the Tundra. I was not expecting this much.
  2. Apr 6, 2022 at 11:53 AM
    CNE0207
    CNE0207 New Member
    Arvada, CO
    2020 Cement CM Limited
    Curious… where does this go and what does it improve? Thanks.
  3. Apr 6, 2022 at 11:56 AM
    TRD 4 ME
    During the process of venting crankcase pressure back through your intake track, large amounts of oil, in the form of vapors, intake tube, intake manifold runners and even dilute your gas, lowering its octane level. This happens on all engines and is even worse with forced inducted vehicles (supercharged and turbocharged) as crankcase pressures are increased. To combat this, we have developed an oil separator of our own design. Milled from solid billet aluminum this is a rock-solid piece. It has a knurled tank base for easy removal to drain the spent oil and an O-ring seal to prevent any leaks.
    Filtering consists of a fine mesh stainless steel screen that traps fine oil vapors and releases them once heavy enough to fall. They then pass through a 1/2" thick 1/16th" aluminum honeycomb filter where they grow every larger and then fall into the bottom. By the time the oil gets through the filter it's too heavy to be passed on into the intake. The tank holds 3 oz of fluid, while that may not sound like a lot, you shouldn’t see that much oil in your PCV system. Drain it every 2000-3000 miles and you will never come close to filling it.
    Saltyhero13 likes this.
  4. Apr 6, 2022 at 12:00 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    You use "we" in "your" explanation.
    Is this a copy paste or are you with JTL?
  5. Apr 6, 2022 at 12:01 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    are you now 3oz low in oil?
  6. Apr 6, 2022 at 12:03 PM
    TRD 4 ME
    Copied from the website.
    I cannot tell if I am down on oil as I have changed in twice in the first 7000km and just checked this last night.
  7. Apr 6, 2022 at 12:04 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Well, you are either pulling oil from your crankcase.....or creating new oil.
    it's one or the other.
  8. Apr 6, 2022 at 12:09 PM
    TRD 4 ME
    Yeah its coming from the crank case but it would not be reflected as the oil was recently changed. Will need to empty next oil change.
  9. Apr 6, 2022 at 12:22 PM
    CNE0207
    CNE0207 New Member
    Arvada, CO
    Pics of how it attaches to the crankcase?
    nobodyintexas likes this.
  10. Apr 6, 2022 at 12:40 PM
    TRD 4 ME
  11. Apr 6, 2022 at 12:58 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    I have the same unit, great product does a an awesome job.
  12. Apr 6, 2022 at 1:09 PM
    2mchfun
    X2
    Giskk, Blue Thunder and FrenchToasty like this.
  13. Apr 6, 2022 at 1:18 PM
    Tundradrenalin
    Tundradrenalin New Member
    Virginia Beach, VA
    2016 DC Black TRD nonPRO
    Methods, Toyos, Kings, TCs, CBs
    looks good, pour it back in :D
  14. Apr 6, 2022 at 1:37 PM
    Deacon Blues
    Deacon Blues New Member
    2018 Tundra TRD Off Road
    Sumo91 likes this.
  15. Apr 6, 2022 at 1:46 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    I'd be really curious what an oil analysis on this would be if you sent it to Blackstone.
    Blue Thunder likes this.
  16. Apr 6, 2022 at 3:30 PM
    TRD 4 ME
    I do a few quick oil changes during the break-in period
    bulldog93, Giskk and Terndrerrr like this.
  17. Apr 6, 2022 at 3:33 PM
    CoffeeAddict
    CoffeeAddict New Member
    2016 Tundra CrewMax
    Between your suspension suggestions and this, I’m about to ask you to just send me your complete build sheet so I can make myself a wishlist for my truck. :D
    Blue Thunder and 2mchfun[QUOTED] like this.
  18. Apr 7, 2022 at 5:36 AM
    Tundradrenalin
    Virginia Beach, VA
    for anyone wondering, that's roughly 4300 American miles.
  19. Apr 7, 2022 at 5:48 AM
    2mchfun
    It is installed inline between pcv valve and the intake manifold. Without it that crap becomes part of the combustion fuel/air/crap mix.
  20. Apr 7, 2022 at 5:51 AM
    Bammer
    Monroe, CT
    Do you really need to rip the foam out?
  21. Apr 7, 2022 at 6:17 AM
    Tundradrenalin
    Virginia Beach, VA
    I didn't rip the foam out to install mine. But it helps for visibility. The foam is removable if you're careful. You basically bisect the PCV return tube and reroute one side to the canister and the other side to the PCV valve.
    Bammer[QUOTED] likes this.
  22. Apr 7, 2022 at 6:27 AM
    2mchfun
    I pulled out a few small chunks, like the size of a lime if all combined.
  23. Apr 7, 2022 at 6:28 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Interesting how European lux autos come with an oil separator standard yet most other autos do not. While it sounds horrible to burn that through intake the engineers factored it in.
    I'd like to hear their explanation of why it is "OK" not to include a device like this standard, anyone know?
    Echo5Golf likes this.
  24. Apr 7, 2022 at 6:29 AM
    2mchfun
    Profits, lots of units equals big profits:thumbsup:
  25. Apr 7, 2022 at 6:32 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Most folks don't service their cars. some not at all. some wait for a light to come on. so, it would fill up & bypass.
    and removing oil with out refilling your crankcase will lead to oil starvation.
    and, isn't this more apropos to direct injection motors?
    our non-direct injections motors don't really give hoot.
    Mater, Saltyhero13 and 1794TX like this.
  26. Apr 7, 2022 at 7:35 AM
    Blue Thunder
    Washington
    Love my catch can. Here’s mine after 3k miles…about half full. I do a lot of short drives, so I’m thinking moisture is giving me the coffee-n-cream color
    2272D9AC-600C-4893-A03D-7C4490B38EA2.jpg 37568174-8FEA-49D1-BB55-749ED330911A.jpg
  27. Apr 7, 2022 at 8:14 AM
    Warreng
    Warreng New Member
    i have also read they can freeze up in the winter. Enough reason for me to not have one.
  28. Apr 7, 2022 at 12:20 PM
    Rocko9999
    Rocko9999 New Member
    So just dump it back in the engine and be on your way?
    RitcheyRch likes this.
  29. Apr 7, 2022 at 12:21 PM
    Rocko9999
    Freeze up as can't remove can to check the oil? Why not just let it warm up first?
  30. Apr 7, 2022 at 12:33 PM
    Warreng
    Warreng New Member
    i am no expert, but a quick google pulled up lots of posts. When it gets cold, they trap lots of water, which freezes overnight, and puts pressure back into the crank case when its blocked. People were suggesting to empty every few days in winter. again, I am not an expert, but that sounds like a PITA
    TTund16 likes this.
