  1. Apr 4, 2022 at 4:13 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    You do not have to remove the door panel on DC, I can't imagine you have to on an AC.
    NUDRAT[OP], Darkness and FrenchToasty like this.
  2. Apr 4, 2022 at 4:15 PM
    image.jpg 1217A0DC-E909-4DFA-B46C-ADAC5FF7009A.jpg Let’s see how insertion goes….
  3. Apr 4, 2022 at 4:15 PM
    Yeah I remember pulling the door panel to get at the moulding and prying it from the inside to loosen & enable it to be pulled off the door now that @FirstGenVol mentioned it.
  4. Apr 4, 2022 at 4:18 PM
    alb1k
    Left Coast
    It's good
    Keep those tabs on the belt strip - line them up one after the other. Like a angle closing in geometry.
  5. Apr 4, 2022 at 4:19 PM
    alb1k
    Left Coast
    It's good
    Those clips don't go there.
  6. Apr 4, 2022 at 4:20 PM
    Ok. Mine were not coming off without a lot of force and and I wasn't about to pry from the painted, visible side of my door. I had to use a small pry bar to get mine off.
    Darkness and Jack McCarthy like this.
  7. Apr 4, 2022 at 4:24 PM
    Yeah they stayed when I kinda slid off the old one, and yeah I slowly brought the angle in to get each clip to go down the channel, im not sure if the clips might have moved in the belt channel?
    BubbaW likes this.
  8. Apr 4, 2022 at 4:25 PM
    alb1k
    Left Coast
    It's good
    it's weird because I just did mine on the passenger side. I had done the driver's side a year ago and took the whole truck apart. I swear to god, this time on passenger side I did front and back in like 20 minutes. Only unbolted/loosened side mirrors.
    Jack McCarthy likes this.
  9. Apr 4, 2022 at 4:30 PM
    daveeasa
    So do the door trim w side mirrors. Mental note made. Hope I can remember
    shifty` likes this.
  10. Apr 4, 2022 at 4:31 PM
    alb1k
    Left Coast
    It's good
    Those clips go inside the door. Your weatherstrip makes an upside down U around the outer door panel, but those clips are in the middle of the window opening. outboard side.
  11. Apr 4, 2022 at 4:34 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    I'll throw my .01 into the mix. I chose to remove not only the inside door panel but mirror since it goes underneath the outside mirror trim a few inches....personal choice. I also placed the old trim side by side with new trim since the old trim had a wore mark where clips were. Using a marker, matched on new where clips were on old trim. In the below pic you can kinda see a yellow marker where clip was marked on new trim.
    Window trim pieces
    bmf4069, Darkness, shifty` and 4 others like this.
  12. Apr 4, 2022 at 4:35 PM
    I think the AC is slightly different. I'm fairly certain I had to remove my mirrors too because it tucks under the mirror in the front.
    Darkness likes this.
  13. Apr 4, 2022 at 4:36 PM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    So awesome, have wanted one of these since High School. Came close to winning one on bat recently.
  14. Apr 4, 2022 at 4:38 PM
    alb1k
    Left Coast
    It's good
    I might have made that more confusing. the clip attachment point for the door side is in the door. I can'r remember if those clips wrap the door/window opening. I left the clips on the belt, aligned them and went front to back after I had the part behind the side mirror all the way in.
  15. Apr 4, 2022 at 4:40 PM
    Sirfive
    Sirfive Master Procrastinator
    ‘02 Limited AC TRD
    Bassani cat-back
    AC does get intimate with the mirror.
    chrisb, RUSTYNUTS, Darkness and 3 others like this.
  16. Apr 4, 2022 at 4:42 PM
    alb1k
    Left Coast
    It's good
    I so want to go pull this belt out. But I can't risk breaking those clips. I think last go I broke 1 of 4 on the way out. But if you don't loosen the side mirrors on the front doors, forget it.
  17. Apr 4, 2022 at 4:43 PM
    Do the door tweets just pop off right?
    I def think I misaligned most of them on the front as I was sliding it in, loosening the mirror will def help. Now the back doesn’t seem to be clipping and seating on that super small clip and the most rear part where it flares up the window
  18. Apr 4, 2022 at 4:44 PM
    alb1k
    Left Coast
    It's good
    The DC is less intimate. Both (AC/DC) need the mirrors loose or out based on that pic.
  19. Apr 4, 2022 at 4:44 PM
    The dealer gave me extra clips. I think you can order them separately. I don’t recall them being expensive.
    RUSTYNUTS, Darkness and BubbaW like this.
  20. Apr 4, 2022 at 4:45 PM
    alb1k
    Left Coast
    It's good
    door tweets pop off. I do it with my hands.
  21. Apr 4, 2022 at 4:46 PM
    Lucky I did yoga today!
  22. Apr 4, 2022 at 4:47 PM
    alb1k
    Left Coast
    It's good
    My wife is a yoga instructor. She gets inverted.
    chrisb, RUSTYNUTS, bmf4069 and 3 others like this.
  23. Apr 4, 2022 at 4:58 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    I was fortunate I reckon cause my new trim had clips attached, simply had to slide them to their proper place.
  24. Apr 4, 2022 at 5:04 PM
    For the rears, is the clip supposed to go into the weird loose metal clip inside the window? image.jpgimage.jpg
    It doesn’t exactly line up back there it seems
    RUSTYNUTS and Darkness like this.
  25. Apr 4, 2022 at 5:07 PM
    alb1k
    Left Coast
    It's good
    I'm at a loss, I can't remember that much detail. Sorry.
  26. Apr 4, 2022 at 6:00 PM
    After mucho fucking around with those, I think it’s actually easiest to remove all the white clips, put them where they need to go, then slide the belt molding down into place and snap each one. I kept only hitting 1:4 clips.
    And @alb1k i think that rear little clip slides into a home at the back of the rear door. I need to pull the driver side rear and see if I can get it to stick!
    alb1k, Darkness and Jack McCarthy like this.
  27. Apr 4, 2022 at 7:01 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Honestly when I did my doors it was a shit show. I had an hour to be somewhere and thought "this will take 20 minutes tops"
    An hour later I was barely getting the 2nd one snapped in. I think @FirstGenVol has a good idea to loosen the mirror because the front edge is supposed to tuck under the mirror. I couldn't jam mine under the mirror and I ended up with maybe half a centimeter too much toward the handles. F it, doesn't rain much here. Still bothers me to see it.
    And @FrenchToasty if you can put the clips in the door, then snap the trim onto the clips thats the smart way. I have a very bad habit of doing things when I don't have the time to do them right.
    RUSTYNUTS, KK6PD, shifty` and 3 others like this.
  28. Apr 4, 2022 at 7:25 PM
    Only two out of 4 numbers for the evening drawing. Not lucky enough today I guess.
  29. Apr 4, 2022 at 7:36 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Took my new ride for a spin.
  30. Apr 4, 2022 at 7:51 PM
    alb1k
    Left Coast
    It's good
    What's going on here? You have a new Chevy or a Fleetwood or bought some land?
