My Work/ "Resto" Thread
Discussion in '1st Gen Builds (2000-2006)' started by VR6T, Feb 26, 2022.
  1. Feb 26, 2022 at 8:57 AM
    VR6T
    VR6T [OP] In fealty to the God-Emperor I serve the Imperium
    San An TX
    00 Tundra Limited 2WD AC
    Really really OEM
    So work done thus far:Timing belt
    water pump
    upper ball joints
    sway bar frame bushings and end links
    ABS speed sensors
    rear shoes
    rear axle seals
    starter
    pos battery terminal
    idler pully
    thermostate
    raidator
    des2mtn likes this.
  2. Feb 26, 2022 at 9:00 AM
    VR6T
    San An TX
    Really really OEM
    des2mtn likes this.
  3. Feb 26, 2022 at 7:31 PM
    05tturbotundra
    05tturbotundra New Member
    good work, looks really good!
  4. Feb 27, 2022 at 6:17 PM
    VR6T
    San An TX
    Really really OEM
    Thank you. Its been a long weekend.
    Oil change, plugs, ABS speed sensors and still trying to figure out why my brake light wont clear.
  5. Mar 27, 2022 at 3:02 PM
    VR6T
    San An TX
    Really really OEM
    So this week I installed a front and rear dash cam, had my buddy wire it up as I am dogshit with wiring. Fixed my running light issue. And started mocking up the new exhaust. Factory 2.25" to a 2.5 single in to a 3" out. And I got some lightly used FJ wheels ordered as well.IMG_20220327_163421_986.jpg IMG_20220327_163421_940.jpg
  6. Apr 2, 2022 at 6:32 PM
    VR6T
    San An TX
    Really really OEM
    • Well the inly problem I ran into was the fact that all the lug studs I replaced were too short. Problem has been fixed with some M12x1.5x 2.75 inch grade 8 studs. Should have them mounted correctly by next Saturday.And then I'll put the dogs back in it. Not gling with OEMs, I'm going to upgrade to some drenched LED pods I think.
