Roadmaster Active suspension review
Discussion in 'Suspension' started by thedonn, Feb 25, 2022.
  1. Mar 22, 2022 at 7:39 PM
    #61
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    So are you still using these?
  2. Mar 22, 2022 at 7:49 PM
    #62
    Mobeyk
    Mobeyk New Member
    Oshawa Ontario Canada
    2012 Tundra TRD pro, 2018 SR5
    Vland headlights, LED fogs, Rough country lower bumper LED bar, third light switch to LED, ICL ceramic coating, hood fender
    I,m confused so the +1 rubbed not the +2? Im waiting for the +2. Will take a while before they come in but once installed, I post pics.
  3. Mar 22, 2022 at 7:50 PM
    #63
    Bradleybb
    Bradleybb New Member
    Georgia
    2021 CM TRD OR
    Transmission cooler TRD REAR SWAY RCI front skid
    No, just the RAS ,
  4. Mar 22, 2022 at 7:59 PM
    #64
    Mobeyk
    Mobeyk New Member
    Those braces can be moved. The brace is bolted on. I bet one can drill holes a bit higher and move the brace higher up. I will contact Coachbuilder and inquire about this. The brace is just to prevent side to side movement that the OEM shackles have. Im aware that the brace itself is square and the square part needs to be machined out for a perfect fit. In any case, one would not expect to have to play around with a product one paid 300$ for. How much would you think the brace needs to move up to clear the hanger of the RAS?
    texasrho83 likes this.
  5. Mar 22, 2022 at 8:39 PM
    #65
    MadMaxCanon
    I am talking to David now, he said they should work. Linked him to this thread.
  6. Mar 22, 2022 at 8:41 PM
    #66
    MadMaxCanon
    How thick is the metal of that ras eyelet top? I can't imagine why it would rub.
  7. Mar 22, 2022 at 8:42 PM
    #67
    Mobeyk
    Mobeyk New Member
  8. Mar 22, 2022 at 9:42 PM
    #68
    MadMaxCanon
  9. Mar 23, 2022 at 5:37 AM
    #69
    Bradleybb
    Georgia
    2021 CM TRD OR
    I was originally running the +2 fit perfect , changed to the +1 they would not fit ,compared +1 and 2 side by side
    The brace on +1 was lower 1/2”best I remember , milled down installed ran with them about 3k,decided to get rid of
    Truck took off +1 and discovered they had been making contact with the RAS bracket , if any one purchase +2 measure from bottom edge of brace to bottom, picture of of my +1 , install is one way no adjustments, ,I probably could run with them this way but I got what I needed out of BECDCFC9-D85D-40A9-95D9-E37E7C28226B.jpg the RAS
  10. Mar 23, 2022 at 6:06 AM
    #70
    MadMaxCanon
    Thanks, were you using stock leaf springs? What was your total lift with these +1s included?
  11. Mar 23, 2022 at 6:33 AM
    #71
    Bradleybb
    Georgia
    2021 CM TRD OR
    Stock leafs DC , RAS set white spacer +1 had 1.25 lift , +2 had 1.75,measurements taken center of wheel cap to edge of bed
    If you get the + 2 CB check measurement against the one I posted
    DiamondW likes this.
  12. Mar 23, 2022 at 6:50 AM
    #72
    MadMaxCanon
    I have to stick with the +1 or nothing at all. I am only looking for about 1.75" lift at the most since my 5160's are only rated to 1.5" total lift. I really want the RAS so i may have to forgo the shackles completely if the +1 wont fit.
  13. Mar 23, 2022 at 7:10 AM
    #73
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    No they don't.
    I'm running 5100s in the rear with the 3" lift (@BOSS4x4s shackles @ 2" and the RAS adding one more inch). Not a problem...
  14. Mar 23, 2022 at 7:50 AM
    #74
    MadMaxCanon
    Do you offroad or have extended bump stops?
  15. Mar 23, 2022 at 8:49 AM
    #75
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    The lift concerns with shocks have to do with full droop shock length. The lift provided by a 1 inch block, or the shackle for example will make the lower shock mount 1 inch further down on full droop. The lift provided by RAS does not do that, it doesn’t change the available suspension travel, it just changes the static load on the leaf spring. Am i thinking correct?
    MadMaxCanon likes this.
  16. Mar 23, 2022 at 9:38 AM
    #76
    MadMaxCanon
    The ras still raises the bed of the truck away from the axle, so it would effect the extension of the piston of the shock going up.
  17. Mar 23, 2022 at 9:54 AM
    #77
    Bill3648
    Bill3648 New Member
    Loudoun County, VA
    2019 Silver Sky Limited Crewmax
    Diamondback SE RCI skid plate Husky Mats WeatherTech bed-liner SCS Ray10's Eibach Stage 2 coilovers Toyo AT3 275/70/18 RAS HD Tuffy console safe
    Just ordered the HD today!
    r1-superstar likes this.
  18. Mar 23, 2022 at 10:05 AM
    #78
    r1-superstar
    DB
    UTAH
    Correct, but an extended bump stop is not necessary since the travel downwards hasn't been increased. Bump stops only assist when the suspension is traveling downwards.
  19. Mar 23, 2022 at 10:20 AM
    #79
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    thats the position of the piston at ride height. Which also is changed by a load in the bed. When you raise the back of the truck into the air with wheel off the ground, i cant imagine an RAS truck extending any different than a non ras truck.
  20. Mar 23, 2022 at 10:26 AM
    #80
    MadMaxCanon
    True but a bump stop would still help since a jarring hit with the truck bed higher will translate to a harder bottom out, plus, imo the stock bumps are trash.
  21. Mar 23, 2022 at 10:55 AM
    #81
    r1-superstar
    DB
    UTAH
    Hence the reason why I run Sumo Spings. :thumbsup:
  22. Mar 23, 2022 at 1:06 PM
    #82
    MadMaxCanon
    Yeah, im going to be installing Durobumps when i do the install.
  23. Mar 23, 2022 at 1:20 PM
    #83
    MadMaxCanon
    I talked to David at Coachbuilder and he said he worked with the engineers at RAS to ensure that their products work together, so I am not sure what the issue was in this case, but David seems to think something was not adjusted correctly.
    Hbjeff likes this.
  24. Mar 23, 2022 at 1:41 PM
    #84
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
    This is weird, but my RAS looks different than your guys' RAS. My back "hook" came from below and would never have been any issue with CB shackles..... It gave me 1" lift with a dime shim. A nickel or a quarter gap would achieve more lift. FYI, they do not sag over time.
  25. Mar 23, 2022 at 1:46 PM
    #85
    MadMaxCanon
    You have a 2nd Gen, David had to recheck with RAS when 2.5 came out so I am assuming it changed for whatever reason for the 2.5 gen.
  26. Mar 23, 2022 at 6:02 PM
    #86
    Mobeyk
    Mobeyk New Member
    So Coachbuilders work with the RAS available now. Im not worried of the shocks. I have Eibachs that are for 0-1” lift but my truck is most of the year loaded plus the tongue weight of the trailer. I drive only in winter with empty bed and i can back the RAS down in that case. Does an extra inch really affect the shocks that much when you are 90% of time loaded ?
  27. Mar 28, 2022 at 8:26 AM
    #87
    tlpru
    tlpru New Member
    trent
    Southlake, Texas
    2016 Trd Pro
    added power mirrors, auto fold mirror, 2019 TRD head and FOG lights, FORTIN remote start, retrax tonneau cover, 18" fuel BFGK02, TRD sway bar, TRD intake
    Installed this weekend.... HD tundra Kit....I set it using the black disc, why...I don't know......guess I wanted the max it would do
    again most likely overkill. but why not.... I'll load test it soon...wanted to post some pics,..
  28. Mar 28, 2022 at 8:29 AM
    #88
    tlpru
    tlpru New Member
    trent
    Southlake, Texas
    2016 Trd Pro
    can't say I notice much in the way it handles, but after driving the truck for 5 years I notice the rack a little.... I didn't measure it before... but like others have said... its probably a 1"
    but I do have a before pic with my boat..... ill post when I get around to hooking it up again
  29. Mar 28, 2022 at 8:52 AM
    #89
    16CMTXED
    16CMTXED New Member
    Gary
    Central Texas
    2016 Tundra CM
    Eibach Pro Sport Shocks (1.25in), RAS HD, Sumo Springs, HAWK Talon Rotors, OEM Tow Mirrows, Lund Hard Fold Tonneau, ESP Storage, Stampede Flares, Husky xAct Fit liners, General Grabber ATX 275/60R20
    I installed front Eibach Pro Shocks to 1.25in clip setting, to offset the added rake from adding RAS-HD. Took a roadtrip this weekend (around 500 miles) and am really liking how the truck rides with the new shocks (did the rears also). Much smoother ride than previously with the stock black shocks. Will be towing 7k lb TT this summer, hoping/expecting this setup to help with squat and stiffening up the ride when loaded. IMG_20220327_140659613_HDR.jpg
    okcowboy, MyActualName and willot1 like this.
  30. Mar 28, 2022 at 9:01 AM
    #90
    MadMaxCanon
    Did you have to take the side of the shackle off for the eyelet install or did you pass it through the gap? Are you leafs touching your sway bar in that last pic?
