Ironman 4x4 Suspension
Discussion in 'Suspension' started by linwozzle, Apr 1, 2020.
  1. Dec 12, 2021 at 3:17 PM
    #571
    sea_weathered
    sea_weathered New Member
    Pacific Ocean
    2018 DC Adventure Chuck Wagon
    Alright, got the pre assembled FCP struts at 3.5”, and their UCA’s. I’ve got around 200 miles on them. Coming from a 3” spacer lift, I’m very pleased with the ride quality! Good alignment numbers too, with almost 4 deg caster.
    387C70D8-2EDC-481D-B1A0-F86E42D1E34A.jpg E8E78205-1A1D-4CD6-939B-7400D23E38E7.jpg 86718217-DF13-4B74-A933-ADB321EE24D5.jpg
    Skew12, Wallygator, AstroDude and 8 others like this.
  2. Dec 19, 2021 at 10:18 AM
    #572
    AstroDude
    AstroDude New Member
    Eddie
    2011 Toyota Tundra Double Cab 4x4
    Ironman 4x4 3.5" lift Stoptech drill and slotted rotors RRW 0 offset rims BMC 35" K02s TrailToys High Clearance Rear Bumper Steel and Kevlar braded brake lines Front diff drop UpTop Overland Rack RoofNest Falcon XL Roadshower 4L IronMan4x4 Awning IronMan4x4 Privacy Tent Custom built bed molle panel (because they don't make them for crew cabs)
    Installed my 3.5" lift about 3 weeks ago and it's going great so far.
  3. Dec 19, 2021 at 11:49 AM
    #573
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    Thanks! Some details... like how is the before and after ride and handling with different loads, on road and off?
  4. Dec 19, 2021 at 12:20 PM
    #574
    AstroDude
    Eddie
    Well I'm having issues where my OEM rims are touching the UCAs which causes the traction control to go off when making hard turns.
    Once I get my new rims, race relation wheels, I'll take the Tundie off road but I can tell the rebound is smoother when I took it to Little Blair Valley. I'll give more updates in January when my rims come in.
    rruff likes this.
  5. Dec 19, 2021 at 12:24 PM
    #575
    rruff
    rruff New Member
    Wow, haven't seen anyone mention clearance issues on the UCAs before... good to know! Guess everyone has rims with less offset?
  6. Dec 28, 2021 at 5:12 PM
    #576
    TRDblvd
    TRDblvd New Member
    2019 Toyota Tundra TRD 4X4 Sport
    Finally got mine wrapped up, thought I'd share.
    tervanun, Gee Dub, Skew12 and 10 others like this.
  7. Dec 28, 2021 at 5:17 PM
    #577
    NWPirate
    Zach
    WA
    Looks great!
    Are those Method 705's? Mind sharing the wheel specs?
  8. Dec 28, 2021 at 5:26 PM
    #578
    TRDblvd
    TRDblvd New Member
    Thanks. Yep, 705. I believe they just come out. Titanium color, 18x9, +25 offset
    Gee Dub and NWPirate[QUOTED] like this.
  9. Dec 28, 2021 at 5:39 PM
    #579
    NWPirate
    Zach
    WA
    :thumbsup:
  10. Jan 3, 2022 at 3:41 PM
    #580
    NWPirate
    Zach
    WA
    Question for anyone that assembled their own coilovers:
    I bought new Moog tophats specific for my Sequoia, for the Foam Cell Pros.
    The bottom side of the tophat that sits inside the coil is too wide, by a 1/4". IM doesn't make a tophat for the Sequoia. Anyone got any ideas? :help:
  11. Jan 3, 2022 at 6:23 PM
    #581
    rruff
    rruff New Member
    Use your stock ones?
  12. Jan 3, 2022 at 7:03 PM
    #582
    NWPirate
    Zach
    WA
    Their shitty and old, not oem either.
    Weird because I confirmed the Moog part number and they should fit the same as OEM Toyota.
  13. Jan 19, 2022 at 1:55 PM
    #583
    Cavalry5.7
    Cavalry5.7 New Member
    21 cavalry crewmax
    Stock
    Keep us updated. I was planning to use OEM wheels as well . Worried about rubbing
  14. Jan 20, 2022 at 6:05 PM
    #584
    SimpleMan
    SimpleMan New Member
    Chuck
    2021 SR5 TRD OR 4x4
    Diamondback HD
    Got my Foam Cell Pro suspension installed over the weekend. I went with the assembled struts, medium load front and rear. Haven't had a chance to really drive it but it looks great and what I have driven is tight; no dip in the front end even on hard braking, cornering is great.
    Skew12, AggiePhil and Elduder like this.
  15. Mar 18, 2022 at 8:27 PM
    #585
    rruff
    rruff New Member
    Ya... anyone? Surely someone has at least tried. If you can do it with aluminum Eibachs, you should be able to with the these steel beasts!
    Also, any new reports are welcome!
  16. Mar 18, 2022 at 8:33 PM
    #586
    rruff
    rruff New Member
    25% off sitewide til Sun, code green25. First sitewide sale since BF times I believe.
    AggiePhil likes this.
  17. Mar 19, 2022 at 5:22 AM
    #587
    Elduder
    Elduder New Member
    Yes, I’ve done it multiple times. Tires have to be completely off the ground, even then at the preset height from IM there’s enough preload to make it quite difficult. It’s possible just not easy. Eibachs move much easier, probably in part due to the bottom of their spring being flat and being shorter with less preload.
    The main reason Fox and King need to be removed is because their upper adjustment collars are split and retained with a hex cap screw. Without using a compressor, which is probably impossible on the truck, there’s a chance the collar could slip a thread with the tension of the spring pressing against the now loose collar. People still do it though, I can’t speak to the actual risk though, I’ve never had those COs.
    rruff[QUOTED] and Wallygator like this.
  18. Mar 19, 2022 at 5:24 AM
    #588
    Elduder
    Elduder New Member
    Get on their text list. I’ve gotten a sale text from them almost every other month. Can be frustrating though.
  19. Mar 20, 2022 at 12:56 AM
    #589
    SK_Tundra
    SK_Tundra New Member
    Stockton Ca
    2015 Tundra Mall Rated
    How are you doing it?
  20. Mar 20, 2022 at 7:28 AM
    #590
    Elduder
    Elduder New Member
    Jack up the side you’re working on, remove the 3 locking screws in the collar. Spray with WD40.
    The tire has to be off the ground. I tried it once with it still contacting but still lifted and it was dangerously difficult. Basically say goodbye to your knuckles.
    Removing the wheel would help a ton but it’s not required. Break to tension between the two collars with a small hammer. Once they’re separated either lower the lowest collar to the desired position if lowering, or just lower it some to get it out of the way. After that I rotate the upper collar from the position of laying on my back and the spanner wrench on the front side of the lca, but behind the tie rod. It’s a small rotation repeated many times.
    SK_Tundra[QUOTED] and rruff like this.
  21. Mar 20, 2022 at 7:31 AM
    #591
    rruff
    rruff New Member
    If you preload the Eibachs to get you the same lift as the Ironmans, they'll have about the same force on them. I'd guess they have better threads.
  22. Mar 20, 2022 at 7:49 AM
    #592
    Elduder
    Elduder New Member
    Its complicated, the IMs are 583 lb/in, the Eibachs are 650 lb/in.
    The Eibachs if I remember correctly are a 16" coil, the Ironmans are the 18", which I believe makes them the longest mid travel coil and lifts primarily on coil length rather than tension.
    If all things were equal and the Eibachs and Ironmans were both positioned to the same height on their perches, the Ironmans would be compressed more and the resulting loss in free coil height would be converted to constant tension or preload.
    The Ironmans ride changes dramatically once you lower them, as you're removing that immense preload.
    I cant say for sure right now since I no longer have the Eibachs on hand, but if you measured your coils on the Ironmans at stock and subtracted the length you measure from 18", then multiplied the remaining value by 580 you'd has a rough estimate on preload.
    I'd gamble to say though, the Eibachs have less preload. I can confirm though as well, you are correct in saying the Eibachs also have better threads. The pitch on the Eibachs is more coarse and makes movement easier.
  23. Mar 20, 2022 at 4:24 PM
    #593
    rruff
    rruff New Member
    I'll see if I can avoid confusing myself. If it's the same truck (same weight) then the force on the spring when installed in the truck and loaded must be the same... doesn't matter what spring or shock it is. This will vary slightly with ride height, but not much. If we had precise measurements on the Tundra suspension geometry and front axle weight we could use this number, but for talking purposes let's say it's 2500 lbs (which is close). Also, let's say the leverage ratio (wheel vertical movement to shock change in length) is 1.7.
    A lift can be achieved 3 ways... increasing the strut length, changing the spring preload (with a longer coil in the same space, or adjustment collars moved up), or increasing the spring rate.
    I asked Ironman for the length of the front shock and they didn't have this info, but we know they are longer than stock (photo at post #574). OME and Bilstein 5100 are both about .5" longer, and I'm going to guess it's around that. Eibach is likely similar, but I really don't know. Per the 1.7 ratio, this would yield ~.85" of lift on its own.
    Now lets look at getting lift from the spring. The spring force is composed of two parts, the initial preload + the additional force (compression) due to weighting. Note that the total amount is a fixed quantity... for instance if you have 4" of total spring compression in the loaded condition, and 3" of this is preload, then you only have 1" of additional compression. Per the 2500 lb spring force with the truck on the ground, the IM coil would be compressed 4.29" (2500/583), and the Eibach coil 3.85" (2500/650). This doesn't tell us the preload though... how much the spring is compressed before installation vs weighted. But since we know that the lift is the same, and I'm guessing the strut length is the same, then the travel from fully extended to final loaded length must be the same. For instance say they both have 1.5" of strut compression with a load (x1.7= 2.55" of wheel down travel) the Eibach coil would have 3.85"-1.5"= 2.35" of preload compression (x 650 lb/in = 1530 lb of force) and the IM would have 4.29"-1.5"= 2.79" of preload (x 583 = 1630 lb of force). That's 6.5% more.
    So the IM would have a bit higher preload force because of its weaker spring, but I don't think that is enough difference to really notice.
    Also, if the Eibach has coarser threads that should make them harder to turn, right? Each full turn would result in a greater linear change in length anyway.
  24. Mar 24, 2022 at 12:57 PM
    #594
    SK_Tundra
    Stockton Ca
    Thanks for the reply. I installed my Ironman coilovers how they came from Ironman. To me the truck feels a bit stiff and bumpy. Going to try and lower the front to see if that’ll help.
    Wallygator and Elduder[QUOTED] like this.
  25. Mar 24, 2022 at 7:23 PM
    #595
    rruff
    rruff New Member
    I bought shocks, springs, tophats, and the wrench last Sun. Need to get a spring compressor so I'll be ready. I'll try to take good measurements of max and min length.
    I want to adjust mine to ~2" with no extra load.
    Has anyone overhauled theirs yet? Interesting video here where they took one apart:
    https://www.youtube.com/watch?v=JrL3ks7BmnQ
  26. Mar 30, 2022 at 6:46 PM
    #596
    rruff
    rruff New Member
    If you can give some guidance on proper measurements for a 2" lift I'd appreciate it! Or any specific lift for that matter. Got the stuff, and getting ready for the death defying spring compression!
    Wallygator and Cavalry5.7 like this.
  27. Mar 30, 2022 at 7:08 PM
    #597
    Elduder
    Elduder New Member
    30 MM of exposed thread from the bottom of the collar resulted in a 2.5" lift for me. Also, if you havent gotten compressors check out the Orion Tech ones, got them for ~50 I think. Worked great, just some adjusting since they coils are close together and getting any decent compressor in there would be hard. These did not flex at all, no issues.
    Based off 30mm netting 2.5" I'd suggest going with about 25mm showing if you want to be on the high side of 2" (like just above it) or 24mm would technically net another 1/2" drop on my truck. But I'd recommend going less at first, then adjusting further on the truck if needed. Its easier to adjust them down on the truck than it is to move them up.
    Also, for adjusting on the truck, buy Eibachs coilover spanner wrench:
    https://eibach.com/us/2209/ETCO2.0-TOYOTA-Tundra-pro-truck-coilover-spanner-wrench
    It fits, has a shorter handle so it can be done with the wheel still on. May need a small hammer for motivation though.
  28. Mar 30, 2022 at 7:26 PM
    #598
    rruff
    rruff New Member
    Thanks a lot! Those are the standard coils, and no extra front weight? I have the longer heavy duty coils, so I'll need to account for that also.
    I got clones of the very same compressors since they looked the best. Seem sturdy. Greased them up good and taped over the hooks. One thing that concerned me is the ball bearing thrust plate which looks like a weak point, but I'll see how it goes. I already bought the super expensive Ironman lockring tool, so I'm set there.
    Elduder likes this.
  29. Mar 30, 2022 at 7:40 PM
    #599
    rruff
    rruff New Member
    I see that the heavy coils are only 5mm longer and have the same spring rate. So if you got 2.5" of lift at 30mm, I'd need to go to 25mm to match your lift. To drop it another .5" (~12mm) and assuming a 1.7/1 ratio I'd be at 25-(12/1.7) or 18mm.
    Is that going to be close to interfering with anything? Hope not...
  30. Mar 30, 2022 at 7:53 PM
    #600
    Elduder
    Elduder New Member
    No promises, but based off the math, and what you saw on their site, yes 18mm would be correct.
    Im on the standard springs, no extra weight.
    rruff[QUOTED] likes this.
