  1. Mar 23, 2022 at 12:49 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Yup! That's the one. I don't have space for a floor setup and that seems to be the best option for me.
    FrenchToasty and des2mtn[QUOTED] like this.
  2. Mar 23, 2022 at 1:58 PM
    MagneticPro
    MagneticPro New Member
    Alabama
    2005 SR5, 2025 Platinum
    Olive drab final color.
  3. Mar 23, 2022 at 1:59 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    If I ever repaint my truck, thats the color I would go to.
  4. Mar 23, 2022 at 8:11 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Got the new driver window regulator in today. (Forgot the pics) Window closes perfect now. Gonna get the topper put on when the rain clears up and I can drive in my yard to get it.
    Also did the passenger side front diff axle seal again the other day. Had a set of dial calipers this time around and got it pretty close to where it belongs. So far no leaks.
    Would be interested to see pics of these when you get them. Seems like someone was saying that the tracmotive ones changed model numbers but it's still the same part. I got the Trakmotive ones but the model I got doesn't seem to show up anymore.
    Only thing I'm not a big fan of is that the outer part of the diff seal is pretty exposed with them VS the OEM.
    NUDRAT, oscardog86, shifty` and 3 others like this.
  5. Mar 23, 2022 at 8:28 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    between the mr2 and the tundra interior i've blown 3 grand this past month... oof.. LOL still need a bit for the tundra interior. and about 3k more for the mr2 to be running
    Voss, KingSequioa007, txagg and 4 others like this.
  6. Mar 23, 2022 at 9:23 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    :yes:
  7. Mar 23, 2022 at 9:24 PM
    bmf4069 Captain wtf
    I thought I remembered somebody having them. I'll get some pics when I get em out.
  8. Mar 23, 2022 at 11:03 PM
    Orange devil
    Orange devil New Member
    Added some DRL headlights to 20220323_203332.jpg the tundra
    Voss, RUSTYNUTS, KNABORES and 10 others like this.
  9. Mar 23, 2022 at 11:05 PM
    alb1k
    Left Coast
    It's good
    Those look pretty sweet.
    Voss and Orange devil[QUOTED] like this.
  10. Mar 24, 2022 at 12:42 PM
    Dannydirtyfingers
    Dannydirtyfingers New Member
    Texas RR
    2004 Tundra AC SR5 2wd
    5100 Bilsteins 4th notch, JBA uppers
    my neighborhood was hit by the tornado. had a lot of cleanup and calls to make. while waiting for contractors did an oil change and a diff fluid change.
    NUDRAT, Voss, tacoguybill and 2 others like this.
  11. Mar 24, 2022 at 12:57 PM
    oscardog86
    oscardog86 New Member
    Southern California
    Damn, sorry to hear that man. Hope all is well! At least you still ended up getting some work done on your Tundra!
  12. Mar 24, 2022 at 1:25 PM
    shifty` You can call 1 (800) PP5-1-DooDoo
    Hell yeah this right here is how you make hard lemonade from lemons.
  13. Mar 24, 2022 at 2:01 PM
    805Tundra
    805Tundra New Member
    Ben
    Central Coast
    2004 White 4x4 Double Cab
    Got the UCAs in, aiming to get started on the front next weekend!
    jerryallday, Voss, RUSTYNUTS and 4 others like this.
  14. Mar 24, 2022 at 2:04 PM
    alb1k
    Left Coast
    It's good
    Well those will be great.
    Voss and 805Tundra[QUOTED] like this.
  15. Mar 24, 2022 at 2:05 PM
    alb1k
    Left Coast
    It's good
    What's the front? Oh - you mean in hand. Install this weekend.
  16. Mar 24, 2022 at 2:19 PM
    805Tundra
    Ben
    Central Coast
    No Total Chaos ;) but they will work just fine
    Yes sir, coilovers and UCAs are in - front install next weekend hopefully
    Voss likes this.
  17. Mar 24, 2022 at 2:29 PM
    alb1k
    Left Coast
    It's good
    Pretty much the same arms with a tad of geometry change as far as I can tell. I don't think I've heard complaints about either.
  18. Mar 24, 2022 at 2:34 PM
    805Tundra
    Ben
    Central Coast
    Me neither, Camburgs were more up my alley price wise
    RUSTYNUTS and alb1k[QUOTED] like this.
  19. Mar 24, 2022 at 2:40 PM
    Trailscape
    Trailscape Zip Tie Wizard
    Alabama
    2006 Tundra SR5
    Those look killer. Where did you find those?
  20. Mar 24, 2022 at 4:25 PM
    Orange devil
    Voss, Trailscape[QUOTED] and 5N0W808 like this.
  21. Mar 24, 2022 at 4:35 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Link?
  22. Mar 24, 2022 at 5:38 PM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    Got the valve cover bolts taken care of today. Buddy brought over his mig welder. Welded a nut to the bolt, went to try and get it turning and it snapped off. Did two nuts on each side and the bolt just turned and snapped right off. These things are made out of a veal alloy or something. Decided to go full mangle as a last resort, never fails. Got those hookers drilled out, will figure out the rest later. I'm sure @shifty` has been driving around all cocky with his fresh new valve cover seals.
    oscardog86, bmf4069, des2mtn and 2 others like this.
  23. Mar 24, 2022 at 5:49 PM
    Yeah, I mean ... I've been driving around, not because I want to. I may still have a teeny, tiny dribble in the corner that meets the cam shaft, but I don't think it's because of any of my work. I'm going to re-torque everything this weekend, then follow-up again the next weekend.
    Glad to hear you at least made some progress, but WTF? Previous owner must've used red threadlock? But who the hell does that?
  24. Mar 24, 2022 at 6:06 PM
    empty_lord
    05 rollover special
    Checked with parts today on availability on parts for the interior. Unfortunately the b pillars, door sills, rear plastic and the rear carpet are 100% NLA. Oof.
  25. Mar 24, 2022 at 6:06 PM
    tacoguybill
    tacoguybill The Burrito Bandido
    Saaaan Diaaago
    06 DC SR5 4x4 174k, 04 Sequoia SR5 4x4 105k
    I was watching a YouTube video on this today because I have an oil leak as well, buddy thinks it’s rear main seal, toyota guys said they suspect camshaft seal, and I’ve never checked or changed valve cover gaskets nor changed PCV valve, so I plan on trying to get everything cleaned up as best I can to get a really good look. Did you use RTV in the corners of the gasket? I thought it was strange in the YT video but I’ve never done it before so what the hell do I know :rofl:
  26. Mar 24, 2022 at 6:39 PM
    The manual calls for RTV on those spots. I did mine that way and haven’t had any leaks. I may have a rear main seal leak though :anonymous:
    tacoguybill[QUOTED] likes this.
  27. Mar 24, 2022 at 6:44 PM
    bmf4069 Captain wtf
    I bought some spacers, a head unit, some front components, and rear speakers. List is almost complete. I just need various interior bulbs and coils.
    oscardog86, Voss, abcinv and 5 others like this.
  28. Mar 24, 2022 at 7:04 PM
    Yes, get the Toyota FIPG for the job, and know the box says it has a 10-15min working time. Part number in pic below.
    For the driver side, consider zip-tie'ing the fuel lines and other line to pull them towards the MC and give yourself more space. Also, there's something that grounds to the front part of the head I pulled off temporarily. On the passenger side, I removed two vacuum hoses coming from the back side of the head and I unbolted my PS resevoir to move it out of the way, then zip-tied its lines to the A/C pipes, pulling it towards the air filter.
    Do one side at a time. After pulling your valve cover and each pair of "half moons" (two per side) from the side of the head facing the firewall, clean all the leftover gasket material off the block and moons. You'll notice on each head/valve cover, on the cam side, there are two very sharp right angles (see pic below). That's what the FIPG is needed for.
    Spend the time to really clear the previous gasket material at that specific spot. Make sure you get all residual oil off the mating surface all the way around, then the channel of the valve cover. I posted instructions over here on how to do the coil tube gaskets here, mine were hard as a rock.
    Once you're ready to reassemble, check for any extra oil that may've leaked over things interim. The new valve cover gasket has wings, so you can press it into the cover ahead of time and it'll stay, work from the middle of the short ends and work outward. Then install the half moons with FIPG as such, then check FSM page below with where to put FIPG before you drop on the cover and torque down as described in FSM below, multiple passes. I paid attention to the FIPG setup time instructions and torqued immediately, I didn't listen to internet mechanics on this who say to wait 1-6 hours before torquing down.
    It's really not a difficult job. More complicated than this really needed to be, but ... whatever. Repair is a repair is a repair. Do it right the first time, take your time and you hopefully won't need to do it again soon.
    Here's the FSM with the spots to do up and the part number for OEM FIPG - for the half moons sealing show, like the link up there says, you'll push the extra you need up when you install the moons, use that for what the FSM shows over those.
    Here's a super-zoom-in on where you need to put the FIPG. Obviously, for the half-moons, you'll be installing the half moon, and using whatever oozes up at the seam, then flattening it out. A simple blob in the two corners near the cam tower is sufficient, per their instruction.
  29. Mar 24, 2022 at 7:04 PM
    bmf4069 Captain wtf
    Well shit. I forgot I needed a skid plate. So I bought a skid plate.
    oscardog86 and RUSTYNUTS like this.
  30. Mar 24, 2022 at 7:09 PM
    Orange devil
    Had this cover chromed about 20 years ago now. still cleans up nice.20220324_190429.jpg
