Roadmaster Active suspension review
Discussion in 'Suspension' started by thedonn, Feb 25, 2022.
  1. Mar 15, 2022 at 6:50 PM
    WinterWarlock21
    WinterWarlock21 New Member
    South Jersey
    2016 Quicksand TRD Pro CrewMax
    https://gearproject.co/profile/SandShark21
    hey, did you go with the standard or heavy duty? I also tow a boat in the summer and the sag was bothering me as well.
  2. Mar 15, 2022 at 7:04 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Forum10 for 10% off
    ChrisTRDPro, 831mic, BLONGTX and 2 others like this.
  3. Mar 15, 2022 at 7:06 PM
    Mobeyk
    Mobeyk New Member
    Oshawa Ontario Canada
    2012 Tundra TRD pro, 2018 SR5
    Vland headlights, LED fogs, Rough country lower bumper LED bar, third light switch to LED, ICL ceramic coating, hood fender
    Have it on now 5-6 weeks and towed quite a bit and no settling at all.
  4. Mar 15, 2022 at 7:07 PM
    Mobeyk
    Mobeyk New Member
    Tundra = Heavy Duty
  5. Mar 15, 2022 at 7:10 PM
    Mobeyk
    Mobeyk New Member
    Added today Eibachs front and rear to the RAS. The Eibachs are so much smoother than the stock shocks especially on bumpy roads. I was surprised how much better the truck handles now.IMG_0871.jpg
    Oey12 likes this.
  6. Mar 15, 2022 at 8:19 PM
    Darren509
    Darren509 New Member
    Darren
    Dayton NV
    2016 White Tundra TRD
    Am I that tired or is that 2 bushings on top of the shock?
  7. Mar 15, 2022 at 8:22 PM
    Mobeyk
    Mobeyk New Member
    Its one.
  8. Mar 15, 2022 at 8:31 PM
    16CMTXED
    16CMTXED New Member
    Gary
    Central Texas
    2016 Tundra CM
    Eibach Pro Sport Shocks (1.25in), RAS HD, Sumo Springs, HAWK Talon Rotors, OEM Tow Mirrows, Lund Hard Fold Tonneau, ESP Storage, Stampede Flares, Husky xAct Fit liners, General Grabber ATX 275/60R20
    Mobeyk, what clip setting did you set the front Eibach's at? I'm going to install mine within the next week or so and going back and forth between the 1.2 and 1.8in clip settings. Any pics after shock install?
  9. Mar 15, 2022 at 8:41 PM
    Mobeyk
    Mobeyk New Member
    But you are right. There are cases with two bushings , not mine though. Here the before and same bushing was installed on the eibachs.D129C5F5-1F2B-476D-BDCD-74B340E7AD71.jpg
  10. Mar 15, 2022 at 8:45 PM
    Mobeyk
    Mobeyk New Member
    I went with the 2.5” lift (max) as i had before a 3” rake (2” to start then 1” additional from RAS). Truck sits pretty much level now. Here pic with a full trailerE15D8A2E-11C2-4689-B778-ED89678933A4.jpgB49CE07D-AA55-4B33-9701-638C0DEFE2BF.jpg
    Oey12 and 16CMTXED[QUOTED] like this.
  11. Mar 15, 2022 at 8:57 PM
    Mobeyk
    Mobeyk New Member
    Best is measure hight from fender to ground at rear and compare with fender to ground at front. Decide how much rake you want empty. Consider sag if you do towing. Things will settle a bit after install over time, not sure how much but the ride is so kuch better compared to stocks.
  12. Mar 15, 2022 at 9:13 PM
    16CMTXED
    16CMTXED New Member
    Gary
    Central Texas
    2016 Tundra CM
    I have RAS HD on now and I'm at around 3.5 in rake measuring from ground to fender. I do tow a 7k lb travel trailer around 8-10 times a year. When I hooked it up recently with RAS installed, I still had 1in rake. I'm installing Eibach's on stock coils, not on Eibach coils like you have. So I'm thinking if I want to be level when towing, I should set clip to 1.2in. I'd really like the overall look of having them set to 1.8in, but I'd have some squat when towing.
    Chucho and r1-superstar like this.
  13. Mar 15, 2022 at 9:36 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    if it does, hypothetically you could crank it a little tighter right? I wish i had done an RAS, i just didn’t want more lift after the shackles too
  14. Mar 16, 2022 at 11:29 AM
    tlpru
    tlpru New Member
    trent
    Southlake, Texas
    2016 Trd Pro
    added power mirrors, auto fold mirror, 2019 TRD head and FOG lights, FORTIN remote start, retrax tonneau cover, 18" fuel BFGK02, TRD sway bar, TRD intake
    I ordered the HD version.... probably overkill..
  15. Mar 16, 2022 at 11:32 AM
    MadMaxCanon
    I got the HD too but i pretty much get my truck fully loaded with 5 or 6 ppl in it and a full bed of gear. I think the website said if you are around 500 lbs or less to get the standard but I dont see why you would even need this for that weight. Plus with the HD i figure you can just back off on the spring tension if needed if its too stiff or you get too much lift.
    Chucho likes this.
  16. Mar 16, 2022 at 1:52 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    HD kit for me. Pairs nicely with Eibach pro truck stage 2 and rear TRD sway. I set the HD RAS with a quarter, which is sized between the smaller white disk and larger black disk. Gave one inch of lift to the rear.
    Mobeyk and Chucho like this.
  17. Mar 17, 2022 at 7:39 AM
    lakedrum03
    lakedrum03 New Member
    Seth
    2021 Tundra Platinum
    Working on it.
    Pressed the order button today.
  18. Mar 17, 2022 at 7:47 AM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    Overkill = yes if you set it with the black spacer. I set mine with the white spacer and it's nice to have the option to set it more later. You can't do that with the SD set.
  19. Mar 19, 2022 at 7:11 PM
    Mobeyk
    Mobeyk New Member
    Did you go with aftermarket shackles? Does anybody have RAS combined with Coachbuilder shackles and poly bushings on here?
    DiamondW likes this.
  20. Mar 19, 2022 at 8:22 PM
    #50
    MadMaxCanon
    I an going to have this setup, planning to install next weekend hopefully.
  21. Mar 22, 2022 at 10:34 AM
    #51
    Explorer
    Explorer New Member
    Battle Ground WA
    2019 Silver Tundra SR5 TRD Offroad
    Has anyone used this system with the Ironman Foam Cell Pro suspension? I've been thinking about getting this but was wondering if anyone has the same type of setup.
  22. Mar 22, 2022 at 10:37 AM
    #52
    r1-superstar
    DB
    UTAH
    I have the RAS with @BOSS4x4s shackles. Please see my build thread below. vvv
  23. Mar 22, 2022 at 2:03 PM
    #53
    DiamondW
    DiamondW Stockblocker
    Kent
    CenTex
    ‘17 CM
    Keep us posted, think I’m gonna go the +1 and RAS too.
    MadMaxCanon[QUOTED] likes this.
  24. Mar 22, 2022 at 4:43 PM
    #54
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  25. Mar 22, 2022 at 5:34 PM
    #55
    Bradleybb
    Bradleybb New Member
    Georgia
    2021 CM TRD OR
    Transmission cooler TRD REAR SWAY RCI front skid
    If you go with +1 CB with the RAS there’s interference with the cb brace , works fine with +2
    batman900 and DiamondW[QUOTED] like this.
  26. Mar 22, 2022 at 5:38 PM
    #56
    DiamondW
    Kent
    CenTex
    ‘17 CM
    Thanks for the heads up, “2 it is lol.
  27. Mar 22, 2022 at 5:52 PM
    #57
    MadMaxCanon
    You absolutely sure about this? How bad?
  28. Mar 22, 2022 at 6:48 PM
    #58
    Bradleybb
    Georgia
    2021 CM TRD OR
    Had +2 and went with +1 had to mill the brace down still rubbed , afraid if I went any
    Further it would get to the threads
  29. Mar 22, 2022 at 6:54 PM
    #59
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I was actually thinking about and RAS until those pics lol
  30. Mar 22, 2022 at 7:21 PM
    #60
    MadMaxCanon
    Damn this sucks. Guess I'm going to stick with stock shackles since I want the ras more. I'll just crank the ras more for the extra half inch lift.
    AggiePhil likes this.
