2022 Tonneau covers
Discussion in 'Tonneau Covers, Caps and Shells' started by ak407, Jan 22, 2022.
  1. Mar 15, 2022 at 7:43 PM
    #151
    TSS Army Green
    TSS Army Green New Member
    How do you like the OEM tonneau cover so far? How much water get inside the bed with it? Is it easy to take off the whole set up and put back on?
  2. Mar 16, 2022 at 4:49 AM
    #152
    bigjuice
    bigjuice Spring hath arrived…
    WA State
    2024 Terra TRD Pro
    There has been some small amounts of water ingress at the front where the bed design has that natural channel (they provide a putty type material to plug it with) and there’s a gap at the back corner where the cover meets the top corner of the tailgate that are the water ingress points.
    Since my driveway is angled up I usually get some seeping through one of these during periods of heavy/consistent rains (which can be for days around here).
    I don’t plan to take it off for use (never needed to with the Bakflip either on the last truck)…just fold up, load up and go as you get to use the full bed.
    …but it would be some work (and annoying) trying to remove and re-attach it on a regular basis if that’s your thought process…45min to 2 hrs for each procedure depending on your skill level, tools and help available.
  3. Mar 16, 2022 at 4:57 AM
    #153
    sparky412
    sparky412 New Member
    SW Pennsylvania
    22 SR5 OR CM 6.5 MGM
    Really? To remove mine its two knobs by the cab on the small section that doesn’t fold and then lift off. Maybe 10 minutes if you are distracted. Also no tools to remove mine. Oh forgot pop drain tubes off.
    DBamaC and bigjuice[QUOTED] like this.
  4. Mar 16, 2022 at 5:06 AM
    #154
    bigjuice
    WA State
    2024 Terra TRD Pro
    Oh ok…I stand corrected then (never tried so thanks for confirming/answering).
    Somehow I was thinking about removing the entire thing…drains, reattach rails and all so totally misunderstood
    …what you explained makes sense though as that’s all one would need to do.
  5. Mar 16, 2022 at 5:11 AM
    #155
    sparky412
    SW Pennsylvania
    Yes but that being said it is not something that I personally am going to be removing and installing on a regular basis. One improvement I would like to see is a way to secure the cover not all the way open. Like if I wanted to just flip the rear section up and drive like that. Not sure what would be functional and aesthetically pleasing.
  6. Mar 16, 2022 at 5:52 AM
    #156
    TSS Army Green
    Thank you guys for the perspective. I guess I will pull the trigger and buy an OEM bed cover then.
  7. Mar 16, 2022 at 12:34 PM
    #157
    molson7
    molson7 New Member
    How's your cover when traveling? Is it holding tight or flapping from the wind? I'm torn between soft and hard cover. Don't really store valuables back there but had a soft cover on a Tacoma years ago and the movement from the wind always bothered me. I get it ther's going to be some movement but curious about your take on it.
  8. Mar 17, 2022 at 7:00 AM
    #158
    molson7
    molson7 New Member
    Anyone else running a soft rollup on a short bed? Looking for thoughts on how it performs (flapping or noise). Brand and model #'s appreciated.
  9. Mar 17, 2022 at 7:40 AM
    #159
    theripper
    theripper New Member
    Oregon
    2022 MGM Tundra Platinum
    You and me both man, I think I've spent more time on tonneaus than the truck + wheels/tires combined :rofl:
  10. Mar 17, 2022 at 12:05 PM
    #160
    rizico
    rizico New Member
    Johnny-Don
    Luling, Tx
    '22 Capstone 4x4
    Which of the folding covers still allows the camera view of the bed when fully folded open? As I understand it, the OEM one does... any others?
  11. Mar 17, 2022 at 12:20 PM
    #161
    DesmoDoe
    DesmoDoe New Member
    Canada
    22 SO TRD Pro
    Any updates on the Retrax covers yet? Anyone had one shipped or delivered?
  12. Mar 17, 2022 at 12:59 PM
    #162
    TundraTun
    TundraTun New Member
    i just called the local dealer. He said it should be a few weeks (groan…I’m sure that means months) until they are in. The good news is the retrax website now lists 2022 tundra.
    DesmoDoe[QUOTED] likes this.
  13. Mar 17, 2022 at 1:02 PM
    #163
    TSS Army Green
    I just ordered an OEM tonneau cover through Bam Whole Sale and they ended up canceling the order. They said that it is due to the cover being backorder and they don't know when they will get anymore. With that being said, do any body know who I can successfully order it through?
  14. Mar 17, 2022 at 1:35 PM
    #164
    Toyota1234
    Toyota1234 New Member
    Jack
    2022, army green limited, off road, DC
    Installed one of these last week. Seems nicer then my old tonnopro. Getting a decent amount of water in the front by the cab that I’ll have to figure out .
  15. Mar 17, 2022 at 6:28 PM
    #165
    Maharisc
    Maharisc w/Patty
    Karl
    Build date: 12/05/22
    realtrucks.com has covers for the Tundra, plus running a deal for St Patrick's day.
  16. Mar 17, 2022 at 9:14 PM
    #166
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    I bought my Extang Exceed from RealTrucks.com; they gave me 10% off just cause I asked. I'll post picks of it installed soon.
  17. Mar 18, 2022 at 2:57 AM
    #167
    ThePolak
    ThePolak 2022 Platinum hunt/tow/haul/family ride on order!
    The Land of the Cobra Chicken
    most quad folds probably will. Bakflip mx4, undercover ultra/armour flex, oem…
    rizico[QUOTED] likes this.
  18. Mar 18, 2022 at 6:23 AM
    #168
    lsuwalt
    lsuwalt New Member
    I'm running a Truxedo Truxsport soft rollup - after installation, water at front of bed behind cab. Went to Lowe's and purchased a roll of rubber weatherstripping and attached it (stickon) to top of bed behind cab.....no more water.
    Believe that is the key as just the weatherstripping attached to the top is not sufficient. Very pleased with the product. 10% off till Tuesday makes it an even better deal!
  19. Mar 19, 2022 at 1:28 PM
    #169
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    Here is the Extang Exceed. So far, I really like it. I'm overly particular about my covers and water getting in, I know some is expected, but I do my best to mitigate all of it. With a little caulk, the bed stays 100% dry going through a commercial car wash.
    The biggest pros are the one piece cover over the metal panels eliminates any possibility of seams leaking and the unique release on the first panel is a turn handle that isn't exposed to access from the tailgate, eliminating the ease of coat hanger access.
    The biggest con is it covers the rear camera when folded all the way up. If I road like this a lot, it could have been a deal breaker. But, as it stands right now, water resistance is a bigger concern.
  20. Mar 19, 2022 at 1:32 PM
    #170
    bigjuice
    WA State
    2024 Terra TRD Pro
    Is
    This a soft-feel tri-fold? I can barely see the seems.
    ThePolak likes this.
  21. Mar 19, 2022 at 1:33 PM
    #171
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    I’m sure Diamondbacks have a cover for it
  22. Mar 19, 2022 at 1:35 PM
    #172
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    It's metal/aluminum panels same as backflip etc but has their "proprietary" cover over all the panels, eliminating the seams from view and water exposure. The cover can support 500lbs evenly distributed .....so they say.
    Not that it matters, but not seeing the seams kinda gives it a sleak look which sold me when I saw it, lol.
  23. Mar 19, 2022 at 1:38 PM
    #173
    bigjuice
    WA State
    2024 Terra TRD Pro
    Yes that’s a very sleek look indeed…I like it.
  24. Mar 21, 2022 at 12:26 AM
    #174
    tropro
    tropro New Member
    Troy
    MN
    2022 Blueprint Platinum
    realtrucks.com for me as well. I went with the Truxedo Centry CT roll upIMG_20220320_163652.jpg . It's their new heavy duty woven material fused to aluminum slats. Material is differernt from traditional vinyl.
    TundraRyan and elgreco like this.
  25. Mar 21, 2022 at 6:03 AM
    #175
    gmcguire7220
    gmcguire7220 New Member
    Ontario Canada
    2022 Limited TRD OR Crewmax - WCP- 2019 Toyota RAV4 Hybrid XSE
    TRD running boards & Bridgestone Dueller Ascent tires
    Has anyone considered drilling a new drain hole for the tonneau drains on the sidewall of the bed above the tie down cleat? It would be straight down and out of the way, leaving the floor drains all open for water drainage.
    I suspect the cleat area ( triangular part outlined in blue) is reinforced somewhat due to the cleat. I wonder if a small hole drilled above that (circled in red) would just be the composite bed to drill into & then the drain tube could run out between the composite & outer bed wall of the box?
    Thoughts?
  26. Mar 21, 2022 at 8:20 AM
    #176
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    Yes, I considered doing exactly this, but got lazy and figured it was easier just to go straight in a hole already there, lol. I also don't have the best of luck with stuff like that; with the way things go for me, that small area would be 99% of the structural integrity of the bed and it would collapse after my small hole.
    Looks like a ton of water in the bed, hope the cover doesn't leak that bad!
  27. Mar 21, 2022 at 9:51 AM
    #177
    gmcguire7220
    Ontario Canada
    Haha, you & me both! My luck there would be some obscure electrical wire, or I would hit the gas filler tube! :eek2:
    That pic was someone else’s from elsewhere on here. I forget where I grabbed it from, but it was the best one to illustrate where I was referring.
  28. Mar 21, 2022 at 9:55 AM
    #178
    kstateskier
    kstateskier New Member
    Bradley
    Kansas City, MO
    2022 Tunda 1794 - Dark Metallic Grey
    I ended up drilling out the original drain holes and tapping them for a 1/2" plug and used clear hose and stainless hose clamps. If its any consolation these don't interfere with the bed mat. The angle of the photo makes it seem like it interferes with the tie down but it really won't.
  29. Mar 21, 2022 at 10:05 AM
    #179
    Bradanglin22
    Bradanglin22 New Member
    Brad
    Has anyone been able to get ahold of softopper for fitment/availability for the new Tundra? I’ve been trying to get in contact with them for over a month now with no luck… Their customer service is the best (said no one ever.)
  30. Mar 21, 2022 at 10:12 AM
    #180
    KroppDuster
    Here. There. Everywhere.
    Bilstein 5100s
    I have to say, reading back through the various threads, that I'm a little surprised at the amount of owners who expect their bed cover to be (basically) water tight. It seems I have different expectations out of my bed covers. I buy a bed cover to keep the majority of weather out, but my other reason is to prevent any easy "target of opportunity" theft. Out of sight, out of mind type of theft, ya know?
    If I was super serious about both waterproofing & security, I would've spend the $2k on a Diamondback cover. If I was less concerned about security and my primary concern was waterproofing, then I would probably go with a shell.
    I have done nothing to my OEM tri-fold cover and I get very little water intrusion during car washes. It keeps 95% of the water out. It's also aluminum so it resists cutting and theft. I always keep a cooler & two Dewalt tool pack out boxes under the bed cover. It keeps the bulk of the water off my stuff and prevents anyone from stealing so I've been happy with its performance in those respects. It might be worth mentioning that I'm coming from cheap vinyl roll up covers. This is my first venture into a hard, tri-fold type of cover.
    It just surprised me because on one of these threads, I read of an owner that ran caulking along his bed cap to "seal" his bed cover. Nothing wrong with the liberal use of RTV...lord knows I've used it plenty for weatherproofing & sealing...but never thought about running a bead of caulk on my truck bed.
    Not saying this to poo poo anyone's efforts in the chase create a waterproof bed cover. Truly. Just surprised.
    Krusher22plat and kstateskier like this.
