Possible paint issue.
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tyman, Apr 8, 2021.
  1. Apr 8, 2021 at 3:48 AM
    Tyman
    Tyman [OP] Isaiah 41:10
    Tyler
    Indiana
    2020 Tundra Sport 4wd MGM
    On my Tundra I noticed this on the paint protector sticker that is in front of the rear wheels.
    Is this just a sticker they forgot to remove when it was delivered or should I take it to the dealer?
    It looks like air bubbles. It's on both sides of the truck.
  2. Apr 8, 2021 at 3:49 AM
    18" TRD Off Road Wheels
    The texture you see is the chip guard that Toyota has on all Tundras. It's completely normal. The clear stickers are added protection.
  3. Apr 8, 2021 at 3:50 AM
    Tyman
    Tyler
    Indiana
    I can push the bubbles around with my finger. Seems like it should all be the same color.
  4. Apr 8, 2021 at 3:53 AM
    The sticker is intentional and not meant to be removed. The texture under the paint is caused by the chip guard. The air bubbles in the sticker are caused by the textured surface they are applied to. IIRC you can even order replacement stickers to replace worn out/damaged ones.
    This is normal.
  5. Apr 8, 2021 at 3:58 AM
    You're not the first to see this, and there have been some issues with white tundras, and some discoloration on Cement, Cavalry Blue, and other flatter/less glossy colors. Nothing on black or MGM that I am aware of. See the linked threads that come up when searching "paint issue" and "Chip guard".
    https://www.tundras.com/threads/new-tundra-paint-issue.56483/
    https://www.tundras.com/threads/factory-paint-issue.81289/
    https://www.tundras.com/threads/cavalry-blue-rock-chip-guard-discoloration.58963/
    Saltyhero13, Tyman[OP] and Black Wolf like this.
  6. Apr 8, 2021 at 4:46 AM
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    Well. MGM is a real color, and it makes it go faster!!!
  7. Apr 8, 2021 at 4:57 AM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    I’d get a vinyl squeegee and try to push the bubbles out while applying heat from a heat gun or hair dryer. Looks like it wasn’t smoothed out all the way when it was applied. The summer heat might even take care of the bubbles for you on its own.
    Black Wolf and Tyman[OP] like this.
  8. Apr 8, 2021 at 5:15 AM
    Willard
    Willard New Member
    2024 F250
    It’s the texture/depth of the chip guard areas preventing the protection film from laying completely flush. You see air bubbles wherever the film can’t adhere.
    My truck has the same thing, as do a few of my friends. Doesn’t really matter.
  9. Mar 20, 2022 at 8:21 AM
    PaulSidiro
    PaulSidiro New Member
    2020 Crewmax
    Hi everyone, bumping this thread on another paint issue question for Cavalry Blue.
    On my 2020 Off-road, the paint almost seems "soft" for lack of a better word. It scratches so easily compared to my last Gen 2 tundras that were white and another black.
    Also, the couple drops of tree sap seem to have dissolved the paint after a recent trip to the mountains. Like it was acid...
    Anyone else seen this on their beautiful Cavalry Blue trucks?
    Paul
  10. Mar 20, 2022 at 8:26 AM
    NWPirate
    Zach
    WA
    @GODZILLA
  11. Mar 20, 2022 at 8:46 AM
    PaulSidiro
    2020 Crewmax
    Yup, and I've also got the grey discoloring on the rocker panels.
  12. Mar 20, 2022 at 9:51 AM
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    Normal. Difficult to have ppf lay flat over a textured surface, that's the reason you see some air pockets.
