Official Tundra Wheel and Tire Setups - Pics and Info
Discussion in 'Wheels & Tires' started by csuviper, Jan 10, 2014.
  1. Feb 2, 2022 at 5:40 AM
    #2701
    easleycrawler
    Travis
    Easley, South Carolina
    19 TRD SPORT CM MGM 4WD
    Shouldn't be allowed anywhere.
    Wahayes likes this.
  2. Feb 3, 2022 at 9:20 PM
    #2702
    Mfanatic22
    Mfanatic22 New Member
    2019 CM White SR5 Sport 4x4
    Looks sooooooo good! In this picture…Have you done anything else to suspension besides 3/1 leveling kit? To fit those tires and rims?
  3. Feb 4, 2022 at 7:01 AM
    #2703
    AT x AT
    AT x AT Trooper Transport
    Jimmy
    State 48 - East Basin of Arizona
    2021 Wind Chill Pearl Platinum
    Mods, what mods?
    406Michael, D4x4TRD, dpast88 and 2 others like this.
  4. Feb 6, 2022 at 6:27 PM
    #2704
    Sheepdog2018
    Sheepdog2018 New Member
    Ron
    Alabama
    2018 SR5 DC 4x4
    6” Maxtrac Lift 35x12.5r18 Atturo M/T Vision Rocker 18x9 +12 Tech 12 volt Sound Borla Cat Back
    2018 SR5 4x4 DC
    Maxtrac 6” lift
    RC 6” coil overs
    D4x4TRD, Luna Pandorum, ATV25 and 2 others like this.
  5. Feb 10, 2022 at 9:59 AM
    #2705
    BuildFunction
    BuildFunction New Member
    Here's a recent photo of mine.
    TRD PRO BBS 18x8 +60
    Falken Wildpeak AT3W - 295-70-18
    Eibach Pro lift 2inch in front.
  6. Feb 15, 2022 at 4:15 PM
    #2706
    1bad10tacoma
    1bad10tacoma New Member
    Mark
    2019 Tundra
    I have a set of nitto ridge grappler 265/70/18s on stock rims and stock height, I'm looking at some method 317s that are 18x9+18offset . Would my nittos work and look ok on these rims? I'm going to lift the truck later when I can afford bigger tires. Thanks
  7. Feb 19, 2022 at 7:10 AM
    #2707
    TownTRD
    TownTRD New Member
    Cris
    Bay Area, CA
    2020 Army Green TRD PRO CM
    Are these Mag Blue?!
  8. Feb 22, 2022 at 1:33 PM
    #2708
    fmscott2
    fmscott2 New Member
    Do I need anything else to run 18" Method NV 305s on my 2014 other than extended thread lug nuts? I see plenty of folks running those wheels and haven't noted anything that needs to be done before installing them.
    I just went down the rabbit hole of hub-centric vs. lug centric and want to make sure I'm safe...
  9. Feb 22, 2022 at 5:24 PM
    #2709
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    @fmscott2 I noticed the hub bore of 305s is 116.5- your Tundra has 110.5. I would research the hub bore piece a bit or maybe go with hub centric Methods - there are some good ones.
    The lugs will be 14 x 1.5 et lug nuts. Also, Method rep stated, "torque 85-95 ft-lb at least 7.5 turns; I constantly struggle with Discount Tire when Im getting balanced about the torque- they tell me they have to do 100ft-lbs, but I show them the email from Method and tell them over tightening "could" cause studs to break. I have hasd them re-torque every time while I watch.o_O
    What size tire will you be running?
    https://www.tundras.com/threads/extended-thread-et-lug-nuts-for-aftermarket-wheels.29521/
  10. Feb 22, 2022 at 5:34 PM
    #2710
    thedonn
    thedonn New Member
    i agonized over what wheels and tires to get and I love the combo i went with. Falken At3 295 70 18 on Method 305 w +25 offset. 6112s at +1.9 front. removed mudflaps and installed CB bumper shims - no rubbing and no BMC. needs a little lift in rear - this pic is stock and looks fine but sqats w any load. Roadmaster Active suspension will be installed any day now.
    lowball, Uturn09, JPB_VT and 4 others like this.
  11. Feb 22, 2022 at 5:58 PM
    #2711
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    @thedonn -Sick Tundra! Do you tow? Do you take it off road? Looking forward to hear your thoughts about the RAS once installed. Where are you located?
  12. Feb 22, 2022 at 6:08 PM
    #2712
    fmscott2
    fmscott2 New Member
    I've actually been running my Method NV 305s since September. I kept the stock size tires 255/70-R18. Haven't had any issues with the wheels since then but I did some research today and hub-centric/lug-centric came up regarding aftermarket wheels and I did a tailspin thinking I've been driving with a dangerous setup for the last few months. I called Method this afternoon and they verified I only need to use extended thread lug nuts for the NV 305s. With the center push-through hub cap the wheels come with, you can't install any spacers to force the wheels to be hub-centric again anyways. The wheels can be a little finicky to mount up though. At first the wheels rest directly on the studs so you have to carefully thread all five lug nuts on until the wheel sits on the shank of the extended lug nuts. Then slowly tighten them all in a star pattern.
  13. Feb 22, 2022 at 6:20 PM
    #2713
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    I have read that many people do the same. All the best man.
  14. Feb 23, 2022 at 3:18 AM
    #2714
    thedonn
    thedonn New Member
    thank you - I am having fun with this build! im building the truck for beach driving in the outerbanks in North Carolina. also to tow jetskis and a 5-6k boat
  15. Feb 23, 2022 at 6:10 AM
    #2715
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    Nice. I lived in KDH for a few years or so- over on Suffolk St across the way from the pier. Still have buddies out there. I Miss the slow pace... Rat race gone awry out here in San Diego!
  16. Feb 24, 2022 at 2:32 PM
    #2716
    zasdds
    zasdds New Member
    2021 Platinum Crewmax
    Did a search but didn't find anything. Have a 2021 Platinum Crewmax 4x4. Recently purchased the Toytec Aluma Boss 2-3" lift with rear 1.5" blocks, SPC UCAs, diff drop, duro bumps front and rear. I have the OEM Off-road wheels (+60 offset and 8" wide). The shop is telling me the biggest tire I can run is 265/70/18 and I am worried that these will look too small with the lift. They say 285/65/18 will rub on the UCAs. Is the only way to avoid this by using wheel spacers or aftermarket wheels? Anyone run 265/70/18 on a lifted truck? My use will daily driving and light trails. TIA!!
  17. Feb 24, 2022 at 2:52 PM
    #2717
    mceagle555
    mceagle555 New Member
    How do you like the ride of the WildPeaks compared to the stock Michelin's? (I'm assuming you had the Michelin LTX from the BBS TRD Pro takeoffs?)
  18. Feb 28, 2022 at 7:55 PM
    #2718
    dvs_one_76
    dvs_one_76 New Member
    Ken
    2017 Platinum
    Did you end up pulling the trigger and installing these? If so do you have a pic?
  19. Feb 28, 2022 at 8:45 PM
    #2719
    malibu dan
    malibu dan GSZILLA
    Daniel
    Phoenix
    2020 SR5 TRD offroad
    6 inch lift. 35x12.5. On 22’s
    2010bigdog likes this.
  20. Mar 3, 2022 at 12:30 PM
    #2720
    justfortun
    justfortun New Member
    James
    Boston
    2016 SR5
    This.
    Do you have a shot down the line? Looking to see the poke. Thanks and awesome looking.
  21. Mar 3, 2022 at 12:37 PM
    #2721
    medic_84
    medic_84 New Member
    2022 GMC Sierra 1500 Duramax 4x4 with a bench!!!!
    https://www.tundras.com/threads/285-75r18lt-ridge-grapplers.101783/
    here is a link to a previous thread I started which I talked about the tires, lift, and minor mods to keep tires from rubbing…… any other questions please ask sir!
  22. Mar 8, 2022 at 6:29 AM
    #2722
    BuildFunction
    bought wheels only, no tires. but i've had tundra with stock michelins before, don't mean to give a bland response, but stock tires are quiet and good for highway lol. a little more noise maybe with wildpeaks, but the looks and capability takes the W.
  23. Mar 11, 2022 at 3:36 PM
    #2723
    TFTundra
    TFTundra New Member
  24. Mar 15, 2022 at 5:14 AM
    #2724
    Kmoose35
    Kmoose35 New Member
    Ken
    2017 Limited Crewmax
    B3AE8754-0952-4495-89B5-45B317F819B2.jpg Yes they do!
  25. Mar 17, 2022 at 10:44 AM
    #2725
    Luna Pandorum
    Luna Pandorum Make footsteps, never follow them.
    2021 LR Tundra Turd Pro CM
    Suspension, 35s and various things to interior
    Hello everyone
    DeesCrewMax, Mattyc, D4x4TRD and 6 others like this.
  26. Mar 17, 2022 at 11:00 AM
    #2726
    TFTundra
    TFTundra New Member
    Welcome!
    Luna Pandorum[QUOTED] likes this.
  27. Mar 18, 2022 at 9:36 PM
    #2727
    Tundra9880
    Tundra9880 New Member
    2019 Cement CrewMax SR5
    Leveled, wheels and tires, Line X on the grille surround and bulge, Line X in the bed, Retrax rolling Tonneau cover, Flowmaster Outlaw cat back exhaust.
    Just did the 314’s myself a week ago! Wanted something different. Love them!
  28. Mar 18, 2022 at 10:13 PM
    #2728
    Luna Pandorum
    I wanted those same wheels but couldn't find them in red at the time, good choice looks awesome!
    Tundra9880[QUOTED] likes this.
  29. Mar 18, 2022 at 10:21 PM
    #2729
    Notlimitedbutclose
    Notlimitedbutclose New Member
    Sam
    Black Toyota Tundra
    Tires, Rims, Lift, color swap, bull bar, camper shell, storage rack.
    20220316_203721.jpg Some 20" Wicked Rims with some BFG K02s
    D4x4TRD and WVI like this.
  30. Mar 18, 2022 at 11:02 PM
    #2730
    Tundra9880
    thank you!
