Diff and T-case fluid brand preference
Discussion in '1st Gen Tundras (2000-2006)' started by Casper421, Oct 30, 2021.
  1. Nov 1, 2021 at 6:34 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I run the Lucas conventional in my rear diff with lsd, no additional additives.
  2. Nov 1, 2021 at 11:50 AM
    I don't have an opinion on it per se. But the viscosity of synthetic is the same as the viscosity of conventional if they are rated the same. The explanation they give seems to be an opinion unique to them and certain applications and not shared by a majority of the information available.
    https://www.machinerylubrication.com/Read/1290/synthetic-conventional-oils
    https://www.haldimandsyntheticoil.ca/amsoil-science/motor-oil-properties/conventional-vs-synthetic/
    Perhaps this is where the conventional is better than synthetic gear oil arose. Specialty application, specifically for the Ford 9" rear end with high pinion off-set that requires GL-6 rated oil. Of course the underlying theme is that conventional oil manufacturers think theirs is better and synthetic manufacturers think theirs is better.
    https://www.currieenterprises.com/why-run-conventional-gear-oil
  3. Nov 1, 2021 at 2:31 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    I used (I've only done it once in my 2017 (at 55k, it has 77k now) once and did Ravenol 75W in the transfer case. Next time I'll just use the Red Line the transfer case too.
  4. Nov 1, 2021 at 10:31 PM
    wandering_boy
    wandering_boy Junior Tech Wizard
    California
    2005 AC SR5 TRD
    Don't let a kid out smart you.
    Been lovin the Ams Oil over here too. I only have it in my rear diff but its goin in the other holes when I'm back home for thanksgiving. And some fresh trans fluid.
  5. Nov 1, 2021 at 10:45 PM
    wandering_boy
    California
    2005 AC SR5 TRD
  6. Nov 1, 2021 at 11:57 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Lucas severe duty in the rear (only stuff that doesn’t chatter) and mobil 1 synthetic in the front and t case
  7. Mar 18, 2022 at 3:41 PM
    tacoguybill
    tacoguybill The Burrito Bandido
    Saaaan Diaaago
    06 DC SR5 4x4 174k, 04 Sequoia SR5 4x4 105k
    Well like my wife, from time to time, I too like to bring up old shit….so from what I gather, synthetic 75w90 is fine in front diff and transfer case but the rear diff in an 06 with LSD needs to be non synthetic with additives? Is this the general consensus? Does it need to be the extra tube of additives or if the bottle says “with additives” it should be fine? “Are you even listening or just staring off into space thinking about doing stuff to your truck again?!” :rofl:
  8. Mar 18, 2022 at 4:58 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    I learned this the hard way. I just drained the Mobil1 from my LSD rear and replace it with Lucas. The Land Cruiser runs Mobil1 all around and doesn't complain, the 4Runner runs Mobil1 all around and doesn't complain, but the Tundra seems to be very picky...
    tacoguybill and FrenchToasty like this.
