A.I.P. code
Discussion in '2nd Gen Tundras (2007-2013)' started by zombie, Feb 4, 2020.
  1. Feb 4, 2020 at 3:43 AM
    zombie
    zombie [OP] Master at Something
    paul
    Rhode Island
    2007 Black DC 4x4
    Yesterday check engine light came on, A.I.P. code 2124. (I think) No Limp mode. I want to do the bypass. Question, If I clear the code for now can I avoid the limp mode? BTW my top speed on the Island is 45, but mostly it's 25-30 mph, so at least I can limp home if I have to. I known about the problem in the 07 before I bought it, I was prepared.............still love the truck. There was a humming noise coming from the intake..........I'm guessing it's the pump behind the intake causing the problem.
  2. Feb 6, 2020 at 3:57 AM
    zombie
    paul
    Rhode Island
    2007 Black DC 4x4
    Self says to self, after further investigation it is code 2441. Exhaust port to the pump is stuck shut. This will not cause a limp mode. Good for me because dont have the time and energy to fix this asap. I will eventually fix this with 1 RELAY, 4 PIECES of WIRE, a DIODE and 4 CONNECTORS, and some BLACK TAPE. :pccoffee: Thank of very much. :bowdown:
  3. Mar 16, 2022 at 4:57 PM
    Thomas4x4
    Thomas4x4 New Member
    Thomas
    2008 Toyota Tundra SR5
    Did your pumps make a high pitched noise?
  4. Mar 17, 2022 at 2:27 PM
    Thomas4x4
    Thomas
    Do you know the parts that make up the whole Secondary Air Injection System. Is there two pumps for the 5.7L?
  5. Mar 17, 2022 at 2:34 PM
    AZTundra
    Paul
    Phoenix, AZ
    The original poster hasn't been seen in almost 2 years now. Maybe another member can chime in regarding their AIP experience.
  6. Mar 17, 2022 at 2:39 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Yes two, one for each bank
    HewittTech01 likes this.
  7. Mar 20, 2022 at 1:51 AM
    Thomas4x4
    Thomas
    When I went to the dealership the other day, the service advisor discouraged me from considering the bypass kit. Some how they believe that it would cause more harm than good. How is this so when the air pump that they replace could fail again at some point? Spending this type of $$$ on something that can fail again
  8. Sep 28, 2022 at 11:29 AM
    HewittTech01
    HewittTech01 Dont Replace SAIS, Bypass It!
    Lexington, SC
    Secondary Air Injection System Bypass Kit
    @Thomas4x4 I do not blame you. The most expensive option is taking it to the Dealership and replacing with Factory/OEM Components. On average, most Dealerships will quote between $2,000 – $3,000 for parts and labor. Depending on your engine size, you may need to replace both Air Switching Valves and could involve removal of the intake. However, replacing the Air Switching Valve only partially addresses the Secondary Air Injection System and even worse may only be temporary. This option does not prevent the other Air Pumps or Valves from failing or even guarantee the new Air Switching Valve from failing again in the future.
    We are more than happy to answer any question you may have about the Hewitt Technologies SAIS Bypass Kits. I have also included some additional resources for any one looking for more information about this issue.
    What Does the Secondary Air Injection System Do?
    https://www.tundras.com/threads/what-does-the-secondary-air-injection-system-do.113683/
    What Do My Secondary Air Injection Error Codes Mean?
    https://www.tundras.com/threads/what-do-my-secondary-air-injection-error-codes-mean.113686/
    How to Fix Secondary Air Injection System?
    https://www.tundras.com/threads/how-do-you-fix-the-secondary-air-injection-system.113688/
