3rd Gen Accessory Thread
Discussion in '3rd Gen Tundras (2022+)' started by jimfish98, Dec 17, 2021.
  1. Mar 12, 2022 at 6:39 AM
    #931
    FortyNorth
    FortyNorth New Member
    Northern ON
    2014 Tundra Super White SR5
    Haha thanks, moot point for me, personally, at least for a while, but thinking it would be a popular mod for those looking for a pro-type look without all the off road bells and whistles.
  2. Mar 12, 2022 at 6:53 AM
    #932
    bigjuice
    bigjuice Spring hath arrived…
    WA State
    2024 Terra TRD Pro
    Aren’t we gonna need that entire Heritage/Pro grill though? I don’t see a convenient ‘spot’ for this to slip right in on the current TRD OR honeycomb grill without some modifications.
    I myself might wait and check out the upcoming Heretic light bar as seen here
    BigArt, TheRooster, jpod and 2 others like this.
  3. Mar 12, 2022 at 12:34 PM
    #933
    Bman95
    Bman95 New Member
    Has anyone found grill marker lights for the 2022 Tundras yet?
  4. Mar 12, 2022 at 1:33 PM
    #934
    Hadelson
    Hadelson New Member
    Allentown - Pennsylvania
    23 Tundra TRD Pro. Fun Ride 2019 RS3 Roush SC Mustang
    Help, can anyone confirm Toyota Bed Matt part number. Limited 6.5 bed Crew Max
    Is it Part PT318-34221-LB
    Or
    Part PT318-34221
  5. Mar 13, 2022 at 12:45 PM
    #935
    vichmr
    vichmr New Member
    Scott
    Suwanee, GA & Highlands, NC
    '25 MGM Platinum TRD OR 6.5 w/ factory lift
    Go Rhino Dominator D6, Diamondback HD
    Thanks for the detailed info. It definitely looks badass. Enjoy your ride!
  6. Mar 13, 2022 at 1:26 PM
    #936
    vichmr
    vichmr New Member
    Scott
    I was about to post a question here: has anyone found a good amber LED fog light setup for the '22 Tundra? This looks pretty good. If anyone has more infor on this or any other options, I'd love to hear about them. Thanks
  7. Mar 13, 2022 at 2:50 PM
    #937
    Toyota1234
    Toyota1234 New Member
    Jack
    2022, army green limited, off road, DC
    Installed the Extang trifecta 2.0. Looks nice and functions well. There’s water getting in mostly by the cab. I’m hoping it seals better as it gets broken it more.
    roboots21 likes this.
  8. Mar 13, 2022 at 4:57 PM
    #938
    RevereOverland
    RevereOverland New Member
    Rob
    2022 Tundra Limited TRD OR
    Details, pics, and video are here: https://www.tundras.com/threads/revere-overland-22-tundra-build.103743/
    They should be out by the end of the month.
    vichmr[QUOTED] and Outbound like this.
  9. Mar 13, 2022 at 5:56 PM
    #939
    Dmon187
    Dmon187 New Member
    DFW
    2022 Tundra SR5 TRD OFF ROAD
    18x9 Method 316 wheels, TRD skid plate, Cat plate, Heritage grill with color match front end, TRD suspension OEM Lift kit with Toyo Open country At3
    Installed my TRD plate this morning. Being down there got me thinking I may get a taco then shield for the cat! Really exposed down there. 1F070D2C-B308-47C3-BE3E-3811D13E1C60.jpg
  10. Mar 13, 2022 at 6:12 PM
    #940
    Jbeans691981
    Jbeans691981 New Member
    2022 Tundra Sport Lunar Rock
    n/a
    That’s not really all
    The way true. It’s requires some modifications. The top hat is slightly tapered. It’s requires the billet to be machined
  11. Mar 13, 2022 at 6:12 PM
    #941
    Jbeans691981
    n/a
    Anyone know where we can find matte black
    Door handle for dbl cab or crew max?
  12. Mar 13, 2022 at 8:38 PM
    #942
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    When I install my tonneau covers, I put a bright work light in the bed, usually facing one front corner then the other. From the outside, I look for light leakage, then some black caulk solves the problem, usually 100%. There's always a spot on each corner that needs it, but the caulk can be concealed under the cover, can't even tell it's there. My only issue I haven't resolved with the 22 cover is the huge gap on each side of the tailgate.
    Toyota1234[QUOTED] likes this.
  13. Mar 14, 2022 at 6:36 AM
    #943
    21CGtundra
    21CGtundra New Member
    Robbie
    SLC, UT
    2022 Midnight Black Tundra SR5
    2" front level, 1" Cornfed rear spacer, Rally Armor flaps, Method Con-6 wheels, 285/75 Duratrac
  14. Mar 14, 2022 at 1:21 PM
    #944
    sspen003
    sspen003 New Member
    How did you mount the device and route the wiring? Does it only work with the USB port on the dash?
  15. Mar 14, 2022 at 1:43 PM
    #945
    ToyoTundra89
    ToyoTundra89 Member
    Seattle, WA
    2022 Tundra SR5 TRD OR CM 6.5
    Only works with the usb on the dash next to the screen. The usb in the center armrest only supplies power, and not connected to your media screen. I just plugged the supplied usb in. Mounted with some velcro next to screen.
    Rwaters and sspen003[QUOTED] like this.
  16. Mar 14, 2022 at 8:28 PM
    #946
    Jbeans691981
    n/a
  17. Mar 14, 2022 at 10:22 PM
    #947
    Frozen.Tundra
    Frozen.Tundra New Member
    2022 Army Green 1794 6.5 TRD
    Has anyone found a part number for a mechanical (not electric) bed step?
    This bed is so dang high I could really use it, TIA
    Schak, dekeman and Troyboy84 like this.
  18. Mar 15, 2022 at 6:40 AM
    #948
    bigjuice
    WA State
    2024 Terra TRD Pro
    For those of you who know suspension…is this a good buy?
    I don’t know much about ProComp but like my previous 2015 Bilsteins it lifts the truck using the new hardware in front and allow full suspension travel.
    So is the $2K (less the control arms) a good investment?
  19. Mar 15, 2022 at 7:22 AM
    #949
    -Mike-
    -Mike- New Member
    2022 Tundra SR5 TRD Off-Road
    TRD Air filters. New pass side turbo : )
    5 days from order to my door. That’s great service especially these days. Long list of honey do’s around here so it’ll probably be this weekend before I plug it in.
  20. Mar 15, 2022 at 7:31 AM
    #950
    RevereOverland
    Rob
    It seems like a lot of money for a very basic lift. I'll be waiting for something a little better (and probably better priced) to come out.
  21. Mar 15, 2022 at 7:33 AM
    #951
    21CGtundra
    Robbie
    SLC, UT
    I've never used ProComp's stuff but they have been in the game a loooong time so I'm sure its good stuff. Especially considering there isn't much available right now. If you were wanting a better than stock setup right away I think this would be the way to go! Plus the fronts are adjustable so you could probably get 3-3.5" with adjusting the preload collars.
    If I had the cash floating around I'd jump all over the kit with the UCA's.
    bigjuice[QUOTED] likes this.
  22. Mar 15, 2022 at 7:34 AM
    #952
    bigjuice
    WA State
    2024 Terra TRD Pro
    Ok…thanks guys.
  23. Mar 15, 2022 at 8:00 AM
    #953
    DesmoDoe
    DesmoDoe New Member
    Canada
    22 SO TRD Pro
    I've got one of these on a BMW, you're going to love it.
  24. Mar 15, 2022 at 8:33 AM
    #954
    21CGtundra
    Robbie
    SLC, UT
    I ordered some Rally Armor mud flaps to try out. They are the longer universal fit ones. I like the way these look on the Raptors so hopefully they compliment the new Tundra the same way. My only concern is the way the back of the rear fender liner isn't square with the body so the flap will sit crooked. I'll have to play around with this but will post pics once they show up and I get them installed. If they turn out nice I'll upgrade to the UR version.
    https://www.amazon.com/gp/product/B07D73PHQX?ie=UTF8
    https://www.amazon.com/dp/B086353Y2T/?coliid=I3QXOIQRYOIPIT&colid=2BM7SF9RGWMJW&ref_=lv_ov_lig_dp_it
    Tundrastruck91 likes this.
  25. Mar 15, 2022 at 9:38 AM
    #955
    ToyoTundra89
    ToyoTundra89 Member
    Seattle, WA
    Saw this on facebook earlier, so I'm giving it a shot.
  26. Mar 15, 2022 at 10:24 AM
    #956
    21CGtundra
    Robbie
    SLC, UT
    Pro Comp just responded to my meassage about their UCA's. You can get them through 4 Wheel Parts (just the UCA's), part # is EXP57023B.
    Dmon187 and bigjuice like this.
  27. Mar 15, 2022 at 11:32 AM
    #957
    Dmon187
    Dmon187 New Member
    DFW
    4WP owns Pro comp. I had a 6inch lift on my 2.5 gen. It was okay but it was the basic bracket lift and it used the stock struts with spacers. I eventually ended up replacing to struts to get rid of the spacers and it drove a lot better. I had their wheels too. Not bad but I purchased it that way and I’d prefer to go a bit different this time around. I may just wait for the TRD lift. Still undecided but got time.
    bigjuice likes this.
  28. Mar 15, 2022 at 11:36 AM
    #958
    21CGtundra
    Robbie
    SLC, UT
    Ya they kind of seem in the realm of Tuff Country and Rough Country. More of a low budget component company rather than a performance company like say Icon, Fox or Bilstein. Hopefully Dobinsons gets there struts and shocks out sooner rather than later! The SR5 stock shocks seem awfully bouncy, to me anyway. Would be nice to upgrade those to something more slow and stout.
    bigjuice and Dmon187 like this.
  29. Mar 15, 2022 at 12:01 PM
    #959
    ToyoTundra89
    ToyoTundra89 Member
    Seattle, WA
    ryanwgregg likes this.
  30. Mar 15, 2022 at 5:41 PM
    #960
    Jbeans691981
    n/a
    N
    Not in my opinion. And only 2.5 inches. Kinda silly if you ask me
