GEN 3 (2022+) Wheels and Tires Photo thread
Discussion in 'Wheels & Tires' started by Tsquare, Jan 16, 2022.
  1. Mar 8, 2022 at 3:15 PM
    #271
    Rwaters
    Rwaters New Member
    2022 Tundra TRD SR5 Crewmax
    Finally, here it is. 2” old Gen leveling kit. Dual layer ceramic tint is scheduled for Friday.
  2. Mar 8, 2022 at 3:21 PM
    #272
    KroppDuster
    Here. There. Everywhere.
    Bilstein 5100s
    Looks solid! Great work!
    Side note...that field reminds me of growing up in Oklahoma. haha.
    Rwaters[QUOTED] likes this.
  3. Mar 8, 2022 at 3:22 PM
    #273
    ToyoTundra89
    ToyoTundra89 Member
    Seattle, WA
    2022 Tundra SR5 TRD OR CM 6.5
    That looks so good! I like the 275's and that lift, plenty of wheel well and shows off the lift/level.
    PapaDave418 and Rwaters[QUOTED] like this.
  4. Mar 8, 2022 at 3:39 PM
    #274
    Rwaters
    Rwaters New Member
    Thanks y’all and it’s definitely nice not having houses next to me that I can pee on from my house. @KroppDuster i didn’t beat beat your time. The sway bar gave me some trouble so it took me approximately 2hrs.
    PapaDave418 likes this.
  5. Mar 8, 2022 at 3:42 PM
    #275
    KroppDuster
    Bilstein 5100s
    Boo. I probably should've mentioned a pro tip on the sway bar. Disconnect it while on the ground and then reconnect it once you drop the truck. Using the weight of the truck makes quick work of disconnecting/reconnecting it.
    Sharing for others now, I guess.
    Also...I really like the look of the 275's with the leveling kit. Makes me think about going down to 275's once I burn the rubber off these 295's.
  6. Mar 8, 2022 at 3:52 PM
    #276
    bigjuice
    bigjuice Spring hath arrived…
    WA State
    2024 Terra TRD Pro
    I was thinking the same thing on how those 275’s look…save some weight from my 295’s indeed.
    KroppDuster[QUOTED] likes this.
  7. Mar 8, 2022 at 3:54 PM
    #277
    Rwaters
    Rwaters New Member
    275/70r18 on 18x9 +18 is perfect in my opinion. It’s not too small or over stuffed
    LunarRockTundra17 and FortyNorth like this.
  8. Mar 8, 2022 at 4:15 PM
    #278
    Krusher22plat
    Krusher22plat New Member
    22plat
    I had Pirellis on order but was told may be back in stock April 29th. I canceled order and went to one of the lighter LT tires in the Firestone Destination XT, 275/65-20 on stock Plat rims (which I actually like)
    The tires along with moving the AVS height setting has really changed the look of the truck. Ride is still pretty good and don’t notice any sluggishness or much change in gas mileage though I am not threw this tank with the new setup to fully compare.
    jachal, BrianRogers, Eagleye and 11 others like this.
  9. Mar 8, 2022 at 8:07 PM
    #279
    Breathing Borla
    AZ
    I haven’t seen any flush , no poke 18”s black yet, or did I miss it?
    I wonder if any other tundra model has that or other Toyota model that fits .
    I’m eyeing a platinum and not crazy about the grey 20”s
    something not heavier than stock would be a winner
    prosledder likes this.
  10. Mar 9, 2022 at 6:58 AM
    #280
    -Mike-
    -Mike- New Member
    2022 Tundra SR5 TRD Off-Road
    TRD Air filters. New pass side turbo : )
    Chevy/GMC has the same bolt pattern if you wanted to be so bold as to look for something off their line lol
  11. Mar 9, 2022 at 7:13 AM
    #281
    Rwaters
    Rwaters New Member
    That’s what I did if there wasn’t a bolt pattern and offset filter. I shared the wealth and used Ram/Titan XD from time to time lol. The issue he’ll run into (imo) is there isn’t a huge market for high positive off-road wheels. He wants no poke so that has to be around a +30 or so for our truck.
    You could always get the current wheels repainted or powder coated to fit what you’re wanting. Plenty of folks are running skinny 35’s on the factory wheels no problem. That’s on factory suspension and I believe removing the mud guards
  12. Mar 9, 2022 at 7:19 AM
    #282
    Tundra-G
    Tundra-G New Member
    2022 Tundra Ltd 4x4 TRD Off-road
    Does anyone know the exact diameter of of the hub bore on the new Tundra?
  13. Mar 9, 2022 at 7:30 AM
    #283
    Breathing Borla
    AZ
    ya, its more of the 20" thing, I would like an 18" if possible. right now I have 18" +35 and its flush on everything except the one rear since we have an off-set axle a bit. sounds like the new one is the same one for off-set
  14. Mar 9, 2022 at 7:42 AM
    #284
    -Mike-
    -Mike- New Member
    Looks like it still the same 110mm as the old ones
    HARPER306 likes this.
  15. Mar 9, 2022 at 7:49 AM
    #285
    Dmon187
    Dmon187 New Member
    DFW
    2022 Tundra SR5 TRD OFF ROAD
    18x9 Method 316 wheels, TRD skid plate, Cat plate, Heritage grill with color match front end, TRD suspension OEM Lift kit with Toyo Open country At3
    The skinny look it was bugs me the most. The truck looks weird with skinny tires. That’s my only complaint.
    Toyota10s likes this.
  16. Mar 9, 2022 at 8:50 AM
    #286
    ToyoTundra89
    ToyoTundra89 Member
    Seattle, WA
    ryanwgregg likes this.
  17. Mar 9, 2022 at 9:41 AM
    #287
    Rwaters
    Rwaters New Member
    No, 106.1 will fit. Same as GM, Ram and others
  18. Mar 9, 2022 at 9:46 AM
    #288
    Rwaters
    Rwaters New Member
    I’d prefer a 285 but with a leveling and offset wheels the aesthetics look great. Especially in person. Also to each their own. Some people like 12.5” wide tires on 7” wheels for the bubble look. I love my setup and we’ll see what tire I go with next, I have a long time before then.
    Before the level
  19. Mar 9, 2022 at 10:21 AM
    #289
    Breathing Borla
    AZ
    those wheels are nice, I like those, I would get a less aggressive tire though,
    can you take a down the truck angle to really show the poke? it almost looks flush there but I know =+18 isnt
  20. Mar 9, 2022 at 10:23 AM
    #290
    Breathing Borla
    AZ
    that slightly bigger tire makes those look a lot better, I have to say. stock is 265/60/20, right?
    so how much bigger is a 275/65? are those 33"s?
  21. Mar 9, 2022 at 12:05 PM
    #291
    Rwaters
    Rwaters New Member
    Before the level
  22. Mar 9, 2022 at 12:07 PM
    #292
    Breathing Borla
    AZ
    thank you, not bad, I thought it would be more for +18
  23. Mar 9, 2022 at 12:19 PM
    #293
    Tundra-G
    Tundra-G New Member
    It is a big tire. 275/65R20 is 34”
    For comparison:
    Stock 265/60R20 is 32.5”
    Most 35x12.5x20 are 34.5”
  24. Mar 9, 2022 at 12:25 PM
    #294
    Breathing Borla
    AZ
    ok thanks, maybe that works or something in between then, its tough to get it big enough so it looks good but not too big and heavy so it kills the ride (LOAD E) and the MPG.
    if I go with the platinum this time around I want to get away from the Load E aggressive and just want a decent size AT or something that looks a little better than a highway tire.
    tipsyuncle likes this.
  25. Mar 9, 2022 at 12:37 PM
    #295
    Rwaters
    Rwaters New Member
    I’m also running a non super wide tire. It’s almost no tire shine sling lol
  26. Mar 9, 2022 at 12:40 PM
    #296
    Breathing Borla
    AZ
    ya man, thats what I need for winter here, poke = side of truck Phucked...
  27. Mar 9, 2022 at 2:12 PM
    #297
    Dmon187
    Dmon187 New Member
    DFW
    This looks great! It has a more aggressive look with the offset.
  28. Mar 9, 2022 at 2:31 PM
    #298
    TJD1776
    TJD1776 New Member
    So I've finally made my full decision on my '22 SR5 TRD OF CrewMax in MGM...
    Build date is 3/17 so hopefully have it early April.
    I'm in Evergreen, Colorado, snows a lot, so I'm with you on the poke and the paint. I want a tiny bit of poke, so just a little more aggressive look.
    Going with:
    295/70/18 - Toyo OC AT3
    KMC Grenade Off Road 18x8.5 +35
    I've been digging into the tiresize.com offset calculator and using everyone specs in here that have posted to try to dial in what I think would be practical and look great for my tastes. I think I'll get very close to what I want with that size tire and the +35.
    https://www.kmcwheels.com/kmc-grenade-off-road
    I do not want a bubble look, like RJ mentioned, so I pray it doesn't have that too much with the 8.5" width...oh sweet baby Jesus please no.
    I think the weight is 30lbs, so they have to be very close or lighter than the 20's... I think stock 18's are like 28lbs.
    Not sure if this helps, but those wheels probably help you with your flush desire. I'll certainly post pictures when I get it all done.
  29. Mar 9, 2022 at 2:45 PM
    #299
    Chris083
    Chris083 New Member
    2022 Gray Tundra SR5
    I have rear air suspension. Does anyone know when a 3 inch lift will be available
  30. Mar 9, 2022 at 2:49 PM
    #300
    TJD1776
    TJD1776 New Member
    Randomly just came across something saying Summer 2022... "TRD Pro 3" Lift"
