Blue Ribbon 4x4 Build Thread
Discussion in '2.5 Gen Builds (2014-2021)' started by BlueRibbon4x4, Jul 25, 2020.
  1. Jan 25, 2022 at 12:56 PM
    #511
    Bappa
    Bappa Off the grid
    Bo
    Arizona
    2018 Tundra CrewMax
    Coil overs (3”) and 295 tires, ESP storage, grab bar; RCI skids; tinted windows; rear air bags
    i was looking under the rear left door sill, but then how do you run the wire through the cab wall and the bed wall?
  2. Jan 25, 2022 at 1:00 PM
    #512
    2mchfun
    There is a hole under that sill toward the rear, stick a 5/16" drill in it and drill a hole. Use silicone and a straw or small plastic or rubber hose to protect against sharp edge in the hole, silicone wire in the tube. The bed has a grommet in the front at the bottom, poke a hole.
  3. Jan 25, 2022 at 3:29 PM
    #513
    BlueRibbon4x4
    BlueRibbon4x4 [OP] Let’s color match it
    Geno
    2015 Blue Ribbon 4x4
    Yeah. What @2mchfun said. That will work. :thumbsup:
    RobertD and 2mchfun like this.
  4. Feb 4, 2022 at 4:32 PM
    #514
    BlueRibbon4x4
    Geno
    New Morimoto HIDs going in. Got a pic of all my cleaned up wiring. No more T-taps, all soldered and shrink tubed. Looked like a ton of wire before. BE6C2002-C1E4-4718-8B59-42A0FEB58D96.jpgE6EF7540-4B80-4C2C-B0DD-3752AB71646B.jpg7FE0347A-BF76-4C13-9A59-44A265D17E5C.jpg
    GAknight, Patch999 and RobertD like this.
  5. Feb 4, 2022 at 4:33 PM
    #515
    BlueRibbon4x4
    Geno
    Also install coming soon. Gotta fab up some mounts for the deck rails. 6DC919D8-6368-4B00-98D9-1A597F4FE090.jpg
  6. Feb 4, 2022 at 7:34 PM
    #516
    Wakekid686
    Wakekid686 New Member
    Hey what kind of running boards do you have on your truck? I think they look sick and was trying to find a set myself. Any help?
    BlueRibbon4x4[OP] likes this.
  7. Feb 4, 2022 at 7:47 PM
    #517
    RobertD
    Robert
    DFW, Texas
    TRDFerguson likes this.
  8. Feb 4, 2022 at 7:56 PM
    #518
    Joro43
    Joro43 New Member
    2018 TRD Sport 4x4 quicksand crewmax
    1st tundra nautical blue 4x4 5.7l DC TRD had oracle custom color shift halo projector headlights, Fab4 bumper with 12k winch. RBP RX3 Grill Pro Comp stage 1 with bilstein 6112 coil overs SPC UCAs BFG KM3 35x12.5x20 with Moto metal 959s NFab running boards TRD LED DRL pioneer avh 4200nex with Polk speakers and JL 600w amp with JL audio stealth box 196k miles and running strong ready for another 200k until I wrecked it on 2/26/21 Just bought 2018 CM 4x4 5.7l quicksand TRD package upgraded headlights and adaptive CC Trifold bed cover, blacked out badges, KMC wheels BFG KO2 tires, 3/1 pro Comp lift FAB4 front bumper with rigid lights and fab4rear bumper.
    Man that blue bronze color combo looks sweet
  9. Feb 4, 2022 at 8:43 PM
    #519
    BlueRibbon4x4
    Geno
    Yep, @RobertD is correct. White Knuckle off-road steps, the larger DOM 1.88, and top step plates. Color matched Raptor liner.
    TRDFerguson and RobertD like this.
  10. Feb 4, 2022 at 8:44 PM
    #520
    BlueRibbon4x4
    Geno
    Thanks!!
    Joro43[QUOTED] likes this.
  11. Feb 5, 2022 at 3:30 AM
    #521
    t.friddy
    t.friddy New Member
    Charlotte, NC
    2019 Tundra SR5 DC
    Love the color. I hope some day I can actually pick the color I want on a vehicle.
  12. Feb 5, 2022 at 4:36 AM
    #522
    BlueRibbon4x4
    Geno
    Thanks! And don’t feel bad, my wife picked this color! She just has good taste.
  13. Feb 5, 2022 at 7:25 AM
    #523
    BlueRibbon4x4
    Geno
    Got a supervisor watching over the solder joints. Check out the back of the retrofit headlights. No bare wire, all harnesses and loomed. No extra openings and headlight boot is in place. There’s no need for patches that let moisture in/out if everything is sealed correctly. The stock turn signal and side market get connected back on the truck.D1CEDBBC-51B0-4261-8FF8-0B1A2002E1CA.jpg2032604F-3742-40F6-A4AE-8024CC9CE96C.jpg39364CB6-D111-4A16-88A9-9AB3B1675321.jpg
  14. Feb 10, 2022 at 7:44 AM
    #524
    tinman10101
    tinman10101 Ah cha cha cha
    Tinman
    2016 MGM Crewmax
    frickin love the puppy geno! man you killing it again with your craftsmanship.
    BlueRibbon4x4[OP] and RobertD like this.
  15. Feb 10, 2022 at 12:52 PM
    #525
    BlueRibbon4x4
    Geno
    Thanks Tin! Still waiting on your retros!!!!!
  16. Feb 12, 2022 at 11:43 AM
    #526
    BlueRibbon4x4
    Geno
    Am I a welder? Hell no, but I think I’m getting better. Started on the mounts for the Rotopax canisters. They’ll get mounted to the deck rails. They have to be pushed out from the rails a bit to clear the brackets of the tonneau cover. D5BCBCCD-5163-476A-801B-E1CE67B2DD5F.jpg84F106A4-50B8-4A68-9AF7-D2F2B5801F99.jpg1D0BB100-7D08-4032-A5A2-3D0530CE3B62.jpg
    GAknight, tinman10101 and TRDFerguson like this.
  17. Feb 13, 2022 at 11:32 AM
    #527
    BlueRibbon4x4
    Geno
    Fabbed up some mounts for the Rotopax I got a while back. Had to be made to push past the tonneau brackets and wheel arches. 90BBC749-A17E-4120-8B61-4707E20A36BE.jpg 633C4B8D-C30D-4E78-8DC0-E62008622D8D.jpg 53EF576E-0783-4460-A5B3-EA7852F478D7.jpg 96E61CE3-D7D7-496B-BC23-97138B3F709F.jpg 116BACE3-2C49-465B-94F9-4D5DDC5D08B8.jpg 8EF42551-4299-4D4E-BB61-7DB9CE20E745.jpg
  18. Feb 13, 2022 at 4:15 PM
    #528
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Pimpin' ain't easy but it sho' is fun! You're doing the best DIY out there Geno! Keep it up!
    tinman10101 likes this.
  19. Feb 13, 2022 at 5:46 PM
    #529
    BlueRibbon4x4
    Geno
    Thanks so much!! Much appreciated!!
  20. Feb 14, 2022 at 6:13 PM
    #530
    BlueRibbon4x4
    Geno
    The wife gave me a little gift today. C5DF1AB7-73F6-41B1-83D9-806663588BAA.jpg
  21. Feb 18, 2022 at 5:50 PM
    #531
    parkerbows
    parkerbows New Member
    Jack
    2017 crew max sr5 trd off road
    Firestone air ride air bags
    Cool looking dog, almost looks like a goat
  22. Feb 18, 2022 at 7:51 PM
    #532
    BlueRibbon4x4
    Geno
    :rofl: Thanks!
  23. Feb 22, 2022 at 11:00 AM
    #533
    BlueRibbon4x4
    Geno
    Took the dawgs on a dirt run. First time for little Zach. He did great. Dig having road dogs.F138B3B3-6083-41CA-9B02-48EE106BB6BC.jpgD79F4A8D-57C4-427B-BD8B-EF6D3875C5AB.jpgA3FBBBF4-343F-43ED-9476-34C05311F82F.jpg
  24. Mar 6, 2022 at 5:15 PM
    #534
    BlueRibbon4x4
    Geno
    Third time is thr charm for this damn steering wheel. I’ve tried two other times sewing the Lonky cover on. I’m horrible at it. I don’t have the patience for it, but man did I want a leather covered wheel. I hunkered down and did it today. Is it perfect? Nope. I’m happy with it though. I stripped the trim pieces and repainted them, and plastidipped the logo. I’ll reassemble them tonight, and tomorrow the truck goes in the shop for a damn front end clunk that I can’t locate.
    B15DE0C3-D80C-43B4-B460-6F5BCF1528BF.jpg 1E13C57D-EB8A-48A8-B1FA-7FC6170B1233.jpg A12DF6F9-D79D-44F8-B2DE-3FFB4B15014B.jpg E90CA2CD-C52F-49C8-A3E6-1E717281D076.jpg 11AFF9E6-898D-448A-A923-989568B7108A.jpg
  25. Mar 6, 2022 at 5:59 PM
    #535
    RobertD
    Robert
    DFW, Texas
    Looks good! Makes me want it even more now. Can't wait to see it all back together :thumbsup:
  26. Mar 6, 2022 at 6:41 PM
    #536
    BlueRibbon4x4
    Geno
    Thanks Robert! Got her back in. Looks as good as I thought I’d be able to get it. Haha!
  27. Mar 7, 2022 at 5:29 PM
    #537
    BlueRibbon4x4
    Geno
    Just a friendly PSA. I took the truck in to a shop because I’ve had a mean clunk every time I go over a hump or crest or driveway. I thought something was busted so I looked at everything that could leak or break. Turns out it was the bump stop extension on the front side of the LCA. Both were hitting going over the smallest bumps. They were hitting so much that they wouldn’t come out, they just broke off and left the threaded pin. So I’ll replace the back ones with duro bumps, and it should be good to go. Photo is not my truck.
  28. Mar 7, 2022 at 5:37 PM
    #538
    RobertD
    Robert
    DFW, Texas
    I was going to say, none of those parts are Blue Ribbon!
  29. Mar 7, 2022 at 5:38 PM
    #539
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    How big of a lift are you running? Those are huge bump stop spacers.
  30. Mar 7, 2022 at 5:46 PM
    #540
    BlueRibbon4x4
    Geno
    I’m at 2-1/2” lift. But these are what were recommended to me by the guy at Boss 4x4. I believed him, who knew?
