General Supercharger Thread
  1. Feb 20, 2022 at 5:28 PM
    #1441
    HonorNotInner
    HonorNotInner I speak the 3rd most eyetalian
    Alex
    Fort Worth
    Added money to it.
    Yes ok, so I went to best buy and bought the adapter so I could plug my laptop into the gauge. upload_2022-2-20_19-20-50.jpg
    The Boost cut pressure was at 8 which makes sense because when I specifically paid attention today I saw the "B cut" pop up when my boost PSI hit 8 or above. So it appears it's 8 PSI by default. BUT My gauge still said the peak PSI was 10.7. I did really notice it suck the power out of the truck when WOT that time. But the manual say's "the relay will interrupt all solenoid control and boost will default to spring pressure."
    snivilous[OP] likes this.
  2. Feb 20, 2022 at 6:27 PM
    #1442
    snivilous
    SW UT
    300k+ Supercharged 2008
    Yes sir. I got the boost/AFR when I installed the blower a few years ago, never had a single issue and I suggest it to everyone. As far as I know it's the only gauge that does dual duty of showing AFR and boost pressure, which is why I got it. You can see peak boost, and a combination or single display of boost and AFR and it has little buttons to quickly switch between the displays. Its backlit and plenty bright during the day and you can tie it into your running lights so it dims. It's not cheap, but it seems to be really good quality and doesn't look like some janky aftermarket gauge. The only thing that could be "better" is since it's digital it's measuring everything at intervals, so reading boost for instance it could be jumping from 4.5-5.5psi in decimal increments hopping around depending on what the instantaneous reading is (same with afr), where as an analog boost gauge would be locked in at 5psi since it's more of averaging the data and has inertia so can't be instantly hopping around. Nothing wrong with it, just how the data is being read, but worth noting (I bought an analog gauge just to verify the Innov8 since the boost numbers jumping around slightly concerned me the first time).
  3. Feb 20, 2022 at 7:29 PM
    #1443
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    He convinced me to get the same gauge. I've had zero issues with and am very happy with it.
  4. Feb 20, 2022 at 7:40 PM
    #1444
    AZTundra
    Paul
    Phoenix, AZ
    How easy/hard was the install?
  5. Feb 20, 2022 at 7:43 PM
    #1445
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I struggled just a bit with getting the wideband sensor wire through the firewall grommet due to all the other things I have stuffed through there. :(:D
  6. Feb 20, 2022 at 7:47 PM
    #1446
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Thanks for the info. I’ll be buying one now.
    snivilous[QUOTED][OP] likes this.
  7. Feb 20, 2022 at 7:49 PM
    #1447
    ZPhilip
    Philip
    West Chester, PA
    Does spring pressure apply with superchargers?
  8. Feb 20, 2022 at 9:09 PM
    #1448
    snivilous
    SW UT
    No none of that applies to us, plus you'd need the gauge hooked into some auxillary system to have anything happen. I'm not sure what the end of dudes post was referring to.
    mustang67408 and ViktorG like this.
  9. Feb 21, 2022 at 5:08 AM
    #1449
    ZPhilip
    Philip
    West Chester, PA
    Same. I was trying to phase it nicely.
  10. Feb 21, 2022 at 7:02 PM
    #1450
    HonorNotInner
    Alex
    Fort Worth
    Added money to it.
    I didn’t know what that meant. I was just quoting what it said in the manual. So it really has no affect then? It’s basically just indicating it’s past 8PSI essentially?
  11. Feb 22, 2022 at 6:09 AM
    #1451
    snivilous
    SW UT
    Correct, it's just a warning
    mustang67408 likes this.
  12. Feb 26, 2022 at 9:46 PM
    #1452
    BigAl
    BigAl New Member
    2014 SR5 Magnuson SC
    AZTundra likes this.
  13. Mar 3, 2022 at 1:07 PM
    #1453
    NIOSH
    NIOSH New Member
    2021 1794 CrewMax Army Green
    ELKA, 35", Harrop, lockers w 4.88
    I appreciate everyone's comments regarding through this thread. I going to make the jump to stage 2 and looking for suggestions on who's tune to use. Current setup is a 2021, harrop, 4.88 gears, on 35's. Thanks
  14. Mar 4, 2022 at 5:10 AM
    #1454
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    I'm stock suspension/tires.
    80mm griptec
    DW650cc's injectors
    I used D3 Performance (they are local to me). They did ~18 runs to tune mine. I don't know if that is good or bad. but, my truck runs great. Dennis & Dinesh are great guys & only tune Toyotas. they are always available by email/text.
    I have not participated in remote tuning, so I can't speak to it. @ViktorG is the point man on that.
    this is like ugly baby syndrome/buyers remorse (myself included) - as most folks will cheer what they have, as few have run multiple brand tunes.
    I'm hitting the 5 volt limit of our MAF. and chose not to go higher. which I believe to mean - I stopped at a fairly unsophisticated tune.
    I love it. my major decision point....nothing has broken yet.
    my truck still gets 18mpg cruising on the highway & boogies when I hit the go pedal.
    In short - IF YOU CAN - get a tune done on a dyno.
    Wynnded likes this.
  15. Mar 4, 2022 at 6:19 AM
    #1455
    Saltyhero13
    Saltyhero13 Throbbing Member
    Orange Virus and D3 are the only tunes available last I checked. It will come down to finding a shop that is comfortable with the specific software.
    From @nobodyintexas 's description D3 is newer and can get it done, they also seem to be very customer oriented. OV's vF Tuner has been around longer but has been banned from these forums.
    nobodyintexas likes this.
  16. Mar 4, 2022 at 6:49 AM
    #1456
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    I think D3 is the only one right now with a stage 2 tune, I have D3 on my truck with magnuson, he was able to get it work on 2021s before it was available, and has been great so far on working with me to make minor changes (speed limiter removed), give them a shout.
    Saltyhero13 and nobodyintexas like this.
  17. Mar 4, 2022 at 7:12 AM
    #1457
    NIOSH
    NIOSH New Member
    Thanks for the replies, Ordered the D3 with pro tuning software yesterday. So far great communication they Answered the phone and responded back with a Human created email after I placed the order online. This forum is AWESOME.
  18. Mar 4, 2022 at 7:31 AM
    #1458
    Saltyhero13
    OV covers up to '21s as well. Maggie started using them as a tune of choice for a while. It was listed on their website at one point but I am happy to hear they moved to use D3's tuner if that is the case.
    The shop I use pivoted from HP tuner to OV tuner since HP hasn't been able to crack the 19's and above. I've been nudging them to use D3, so far they haven't budged.
  19. Mar 4, 2022 at 7:46 AM
    #1459
    Downytide
    GTA
    I think Magnuson still uses VFtuner for 2020+, I was waiting for VFtuner for a long time with 2020+ since I have headers and gears (on 2020+ once you do gears, you get top speed limiter kick in at 91mph), but then when I got into touch with D3, Dinesh was able to get 2020+ to work back in August of 2021 and I was one of the earlier ones to get one of their hand held tuner, I was happy with the tune and I told him I was gonna go s/c sooner or later and at that time Magnuson didn't have 2020+ yet, so he worked with me and developed a tuned for it, I bit the bullet and bought a kit and got it to work.
    I think if I was ever to go all out, I'll probably go the Prospeed Haltech route.
    Saltyhero13[QUOTED] likes this.
  20. Mar 4, 2022 at 8:27 AM
    #1460
    Saltyhero13
    What years do they support?
  21. Mar 4, 2022 at 12:27 PM
    #1461
    Downytide
    GTA
  22. Mar 4, 2022 at 1:09 PM
    #1462
    Saltyhero13
    Thanks. Holy that is not cheap and "This kit still uses the factory ecu to control the throttle body and transmission, HPTuners is required for tuning the trans on the 2007-2018 models, 2019-2020 VFTuner is required."
    I'll need to look at this more but it has a lot of interesting features:
    - Allows full control of the engine, with a factory ecu you are relying on company’s to define all the tables in the ecu, but the reality is this is rarely the case. Often times there will always be something doing weird things in the background affecting the end tune due to missed tables, this can cause weird running issues or engine damage if someone is not familiar with the platform. The Motec ecu will 100% do exactly what you tell it to, there are no hidden or missed tables.
    - It opens up the pool of tuners who can dyno tune the vehicle, the amount of tuners who can know the in’s and out’s of the factory Tundra ecu and know the issues and work arounds is small, but by utilizing a Motec you know longer need someone who knows all these issues and fixes.
    - Our Motec package has factory CAN system integration, allowing driven and non-driven wheel speeds from the ABS module for traction control and shift detection for pulling power at the shifts for prolonged transmission life, etc.
    - Has full time O2 correction with reliable Bosch NTK wideband sensors
    - Utilizes a 150psi fuel pressure sensor for true VE based tuning, using this, if the fuel pressure rises or falls it will maintain a constant air fuel ratio, it will also do an RPM cut if the fuel pressure drops too low to prevent engine damage in the event of a faulty fuel pump.
    - Uses a 5 bar MAP sensor for speed density control
    - This works in conjunction with the factory ecu making sure everything still works in the vehicle such as factory dash.
    - Has better VVT control than the factory ecu, the cams will track faster.
    - Has boost control for turbo applications
  23. Mar 4, 2022 at 3:00 PM
    #1463
    Saltyhero13
    @Downytide So if I understand that device correctly its a type of middleware that lets you connect sensor that normally wouldn't be integrated into a host vehicle in addition to carrying the tune. If so its worth the steep cost. That is some cool kit right there.
    Thanks for sharing this.
  24. Mar 4, 2022 at 3:24 PM
    #1464
    Saltyhero13
    concise
  25. Mar 4, 2022 at 5:49 PM
    #1465
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I would imagine, once you did rings,rods & bearings....this is the ticket.
    maybe a forged block as well.
    damn it, y'all need to stop.
  26. Mar 5, 2022 at 6:06 AM
    #1466
    nags
    nags New Member
    Almost ready to join this post. Although not entirely sure what stage 1 specifies...
    MGeuwuwfERx6VryC-t9o9BxSkBGsP2F-XUypMsPF_50cdd69aece341dfda40e523155508fbbfcfb9a3.jpg
  27. Mar 5, 2022 at 10:09 AM
    #1467
    Downytide
    GTA
    My knowledge on this is little, but my understanding is the engine would be control by the motec ecu, injectors, pump, etc, while stock pcm and other modules *think they still do, almost like a virtual machine on PC, I may well be very wrong, but that's my understanding.
  28. Mar 5, 2022 at 10:40 AM
    #1468
    Saltyhero13
    Stage 1 is Harrop with no tune and the larger pulley and stock injectors.
    Post what you got. It doesn't matter as most of the people on this thread upgraded their S/C to the Stage 2. People are posting their Maggies here too.
  29. Mar 5, 2022 at 12:16 PM
    #1469
    nags
    nags New Member
    Got the Harrop, obviously, 80mm pulley. Full ProSpeed fuel system including billet fuel rails, ProSpeed Intake and will be fully tuned with HP Tuners
    snivilous[OP] and Jbehredt like this.
  30. Mar 8, 2022 at 8:31 AM
    #1470
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    So has HP Tuners unlocked the Tundras up to the 2021s??? Does anyone know?? What tunes is HP Tuners writing??
