2012 Tundra DC - aftermarket Stereo Nav - no power
Discussion in 'Audio & Video' started by Drkdaiz, Jun 4, 2017.
  1. Jun 4, 2017 at 6:43 PM
    Drkdaiz
    Drkdaiz [OP] New Member
    2012 Tundra DC SR5
    I have a 2012 Tundra and I had installed an Axxera Nav headunit about 8 months ago. About a week ago I heard some popping and thought one of my connections was not crimped well like it would if you had a speaker terminal miscrimped.
    Anyway, I opened up the dash, pulled the unit out and when I had the key and radio on I was checking all the connections. Next thing I know the head quit working.
    I checked all the connections and none were loose. I checked the 15a fuse in the head and it was fine but I replaced it anyway.
    I checked the fuse box under the driver dash/floor area, pulled the 7.5a for ACC and it was fine.
    I don't know what else I could check or replace to get it working. I pulled the unit from the dash today, ran a voltmeter and it's not getting power at all. I'm certain it's a blown fuse somewhere but I don't know what else to check.
    I don't have a system in my truck so I know it's not anything related to that.
    Anyone ever have this problem? If yes, what should I do to fix it?
  2. Jun 12, 2017 at 12:09 PM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Based on the diagram for 2012 Tundras, it looks like there might be another 15A fuse labeled Rad. No. 1. Perhaps in the engine bay fuse box? I don't have a 2012 so I'm not sure where it would be exactly. Drawing key indicates Left (drivers) side of the engine bay.
