5.7 idle fuel consumption per hour?
Discussion in '2.5 Gen Tundras (2014-2021)' started by mountainpete, Feb 9, 2022.
  1. Feb 10, 2022 at 4:19 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    is this the proper point in time that we inject:
    if you use 0w-20 you could probably lower your idle GPH?
    or is it too soon? :anonymous:
    move along....nothing to see here....
  2. Feb 10, 2022 at 5:35 AM
    xc_tc
    xc_tc New Member
    5.85 g/sec * 3.6 kg-sec/g-hr / (14.5 afr * 0.7 kg/L * 3.785 L/gal) = 0.548 gal/hr
    rough calculation it doesn’t take into account the fluctuation in afr and maf.
  3. Feb 10, 2022 at 6:12 AM
    mountainpete
    mountainpete [OP] Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    That would be a very frugal 2.1L per hour.
  4. Feb 10, 2022 at 6:59 AM
    WXman
    WXman New Member
    Kentucky
    2016 Tundra SR5 Crew Max 4x4 5.7L
    45F ambient, sitting at stop light, HVAC off, mine reads 0.42 gallons per hour.
    AZBoatHauler likes this.
  5. Feb 11, 2022 at 1:57 PM
    AZBoatHauler
    So.Arizona
    I pulled MAF data this morning and used this equation and the one linked. Both indicate .4 gph. This was engine at operating temp hvac off.
    https://www.windmill.co.uk/fuel.html
  6. Feb 11, 2022 at 2:10 PM
    Seafury
    Seafury Kickin names, and takin ass!
    Agent K
    SC Low Country
    2014 White 1794 "SnowWhite aka the Frost Queen"
    Bilstein 6112/5160, 3 CB front shims, SPC UCA's, CB +3 rear Shackles, total 3/2 lift, Dif drop, CB Carrier bearing drop, Fortin Evo One remote start from Tech12volts PnP, AMP research Powersteps PnP, Vent shades, Tinted windows, Black/Red lined cupholder inserts, Proclip USA dash phone mount with Scosche Magic Mount wireless magnetic phone charger, Stock wheels/tires for now.
    All this math makes my head hurt.
    Very cool regardless.
    All I can really say is my truck is a thirsty bitch.
  7. Feb 11, 2022 at 3:55 PM
    mountainpete
    That’s 1.5 l an hour. Much less than my initial estimate, although hvac off as you noted.
  8. Feb 11, 2022 at 5:49 PM
    xc_tc
    xc_tc New Member
    Ah yes the maths work. Now someone should check AC on and try to capture maf and afr when the compressor is cycling.
  9. Feb 11, 2022 at 7:09 PM
    AZBoatHauler
    So.Arizona
    Heat didn’t seem to have much impact. A/C full blast bumped it to just over .6gph. Again, engine was at full operating temp. Consumption seems to nearly double while warming up.
    14burrito likes this.
  10. Feb 13, 2022 at 12:40 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    2007 RCSB 2014+ TRD Pro Conversion 5.7 4x4
    Full 2014+ Conversion Regular Cab Short Bed 4X4 2019 TRD Pro Grill, 2014+ Front End Swap 2014+ Interior/Dash Swap with TRD Pro Leather Seats, 2014+ Bed Swap with TRD Pro Stamping SOS 2/4 Drop Kit
    The hunt for answers continues...
    I got out my laptop with a copy of Techstream and started data logging on my truck through Toyotas software.
    Here is the log screen in Techstream. I logged Coolant Temp, RPM, Injector Fuel Volume in Cylinder #1, Injector Port time, and MAF
    Here is the same data in a spreadsheet. I logged 5 minutes worth of data and show the avg value for each at the bottom of the list. This photo shows the last 15 or so seconds of data. As you can see almost all values are stable at this point.
    The truck was warmed up at normal operating temp when I started logging. Coolant temp was 187 the entire time. RPM 600-700 Rpm.
    Fuel flow into cylinder #1 was pretty steady at 0.110 ml per second. That would mean 0.880 ml per second across all 8 cylinders every second.
    52.8 Ml per Minute
    3168 Ml per Hour which equates to 0.85 Gallons per Hour
    I have read online that the factory fuel injectors are in the range of 370 CC/min. This would mean at idle and 0.85 gallons per hour the injectors are operating at 1.7% of total capacity.
    I found a second source to try to verify the data further. Using the fuel consumption logger inside Techstream I logged that it took 6 minutes and 35 seconds at warmed up idle to burn 0.1 gallons of gas. This was at the same 600-700 Rpm and about 0.115 ml per second on Injector #1.
    If it takes 6 minutes 35 seconds to burn 0.10 gallons then total gallons burned in an hour would be about 0.90 Gallons per hour very close to the number above including minimal error.
    JRS, 14burrito, Wynnded and 2 others like this.
  11. Feb 13, 2022 at 12:48 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    A few other things to note from my newly logged data.
    On startup and a cold engine the truck defiantly burns 1.6 - 2.0 gallons per hour, however as the truck starts to warm up this number comes down significantly to stabilize about 0.80 gal/hr. I know at 3 minutes into warmup the truck was down to 1.1 gallons per hour. (This was from an earlier log today when the truck was started cold)
    The other interesting thing was that using the MAF values as others have suggested in the post doesn't seem to give accurate results. However I’m not entirely sure as to why yet.
    My MAF was steady at 4.77 Gm/Sec, according to the math calculations this would be about 0.40 gallons per hour. However the raw data from the fuel injector is telling me the real number is significantly higher than this. Seems most people with Scangauge are calculating fuel burn based on MAF values and I am not convinced this is giving accurate results.
  12. Feb 13, 2022 at 4:42 PM
    mountainpete
    0.90 US gallons is 3.42 liters. Which also was my post 1 napkin math. :eek2:
    Jeff_5_7[QUOTED] likes this.
  13. Feb 13, 2022 at 11:13 PM
    xc_tc
    xc_tc New Member
    Can you send the TSE file? I have Techstream too and I’m curious to see. Technically, maf*afr is correct… the ECM judges injection amount based on maf and afr.
  14. Feb 14, 2022 at 2:59 AM
    MT Madman
    MT Madman Just an ordinary guy
    Hawk Point MO
    2020 Silver Platinum
    TRD dual exhaust TRD Rear Sway Bar SnugTop Hi-Liner
    My head hurts, time to Unwatch this thread.
    WXman and nobodyintexas like this.
  15. Mar 2, 2022 at 5:13 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    Just for fun.
    I logged the entire startup fuel curve on my truck just now. Truck had been parked for over 24Hrs here in Texas. Outside Air Temp about 70F. I just turned on the data logger and THEN started the truck. You can clearly see a spike it fuel flow on start up and as the engine warms up it starts to plane out.
    Coolant Temps were 70F on startup and I turned the logger off at about 170F.
    I logged a data signal on the CAN (communication network) bus coming from the Engine ECU to the Cluster, this is the value used to calculate MPG info on your instrument cluster. (Shown in Orange)
    At the same time I logged fuel use data through an OBD2 software. It uses MAF readings to calculate what it thinks the fuel rate is assuming 14.7 grams of air to every gram of gasoline. (Shown in blue)
    Both signals spike up to just over 2 gallons per hour on start up. Then they both slowly start to come down.
    The CAN ECU signal level off about .71 Gal/Hr and when I turned the AC on at the end it jumped to about .81 Gal/Hr.
    The OBD MAF signal level off about .45 Gal/Hr and when I turned the AC on at the end it jumped to about .58 Gal/Hr.
    Personally, I really think the MAF values are too low. The other logs I did in Techstream line up really well with the CAN ECU signal. (Orange Line). Assuming it is accurate, In the 12 Mins of running to warm up the truck burned 0.18 gallons of fuel. As stated already avg burn rate is 0.80-0.90 Gal/Hr with AC on but now you can see the actual curve as the truck adds fuel for cold starts.
    ZappBrannigan and 14burrito like this.
  16. Mar 2, 2022 at 5:22 PM
    TundyMcTunra
    TundyMcTunra Irrational people are not often convinced by facts
    Lost in the PNW
    2010 Tundra Limited Crew Max 4x4, 2018 Tacoma Inferno TRDORDCSB, 2019 Rav4 Lunar Rock, 1991 4Runner Crawler. Ivan Stewart Edition
    This is good to know. I sit in the parking lot with the engine running when I'm at the mountain waiting for the lifts to open. Not sure if the colder temps effect the GPH but its usually between 20-30°f
  17. Mar 2, 2022 at 5:28 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    My first thought is the colder air is more dense, more oxygen. I would think the colder it is the more fuel added earlier, harder cold start. When the truck is warm it might still burn a little more fuel with thicker air but next time a cold front blows through and it’s 30 F here I will log it again.
    I think from here on out I will only log the ECU signal on the CAN bus. I really don’t trust the error in the MAF calculations. This is what Scangauge is doing btw.
    I think I’m about to go do a quick log at highway speed for fun. Set the cruise at 70Mph then turn the logger on. It’s a nice day for a drive.
    TundyMcTunra[QUOTED] likes this.
  18. Mar 2, 2022 at 5:30 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Same time, you'll be removing heat from the cooling circuit to keep cabin temp up. This might cause the engine to possible increase fuel consumption to make up for lack of "operating temp" coolant temp.
  19. Mar 2, 2022 at 5:32 PM
    AZBoatHauler
    So.Arizona
    Similarly, I watched MAF data towing through the mountains last weekend. In 3rd gear at 4,500ish RPM it was pulling 220 grams of air per second - nearly half a pound. :eek: That works out to 20gallons/hour.
  20. Mar 2, 2022 at 5:38 PM
    #50
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    Hahaha I went ahead and logged the MAF and Coolant Temp also via OBD. Here is the graph, MAF in Green using the vertical axis on the right.
    MAF spiked to 17 G/Sec on start up, leveled out at about 5 G/Sec and jumped to 6.5 G/Sec when the AC came on. Funny thing is Toyota uses the MAF signal and several other sensors to calculate injector pulse time. It seems using MAF calculation only is not accurate for fuel consumption as it is ignoring the Short and Long term fuel trim values the ECU is calculating and factoring into fuel rate.
  21. Mar 2, 2022 at 6:03 PM
    #51
    TundyMcTunra
    Lost in the PNW
    Do it
  22. Sep 5, 2022 at 1:30 PM
    #52
    stewie476
    stewie476 New Member
    2021 TRD Off Road
    Body colour grille, BedStep, Sentry CT tonneau cover, body colour tow hooks
    3.42L/hr? I don’t think so. I used to be a trucker, and the 15L Caterpillar engine in my tractor would burn about a gallon an hour idling. There’s no way a Tundra burns that much idling.
  23. Sep 5, 2022 at 4:27 PM
    #53
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    I have a OBDlink MX+ and it shows the fuel rate. Its .4-.5 gal/hr at idle.
