Help! Bilstein 5100 leveling kit questions.
Discussion in 'Suspension' started by Darthinvader48, Mar 25, 2019.
  1. Apr 2, 2019 at 8:56 PM
    Looks great.
    Love those TSS wheels!
  2. Apr 2, 2019 at 9:41 PM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    :yes::cheers: Looks Great!!!
  3. Apr 3, 2019 at 4:18 PM
    thornjude89
    thornjude89 New Member
    South Louisiana
    2019 Tundra Black SR5 Crewmax 4x4
    Stock
    Damn I have same exact truck! Well any pcs sensor going off since level? What exactly did you go with?
  4. Apr 3, 2019 at 5:56 PM
    r1-superstar
    DB
    UTAH
    Don't forget to install those large washers on the factory bump stops. Two on each side.
  5. Apr 4, 2019 at 8:02 AM
    Sephon
    Sephon Don't be an American't
    Northwest PA
    2020 Black Tundra TRD Pro
    Icon Rebounds w/285/75 BFG KO2’s, Coachbuilder +2
    How does the ride compare to stock? I'm about to pull the trigger on this EXACT setup.
    Thanks!!
  6. Apr 4, 2019 at 8:39 AM
    ncorry
    ncorry New Member
    Nic
    Little Rock, AR
    2019 CM SR5 TSS
    Me too. Trying to decide between one spacer on Driver's side or two on Driver's and one on Passenger.
  7. Apr 4, 2019 at 11:19 AM
    Darthinvader48
    Darthinvader48 [OP] New Member
    2019 Black tundra SR5 TSS 4x4
    No pcm or traction control issues. I didn’t know about the two washers. The drive is almost exactly the same a little stiffer than before but not bad at all. Do the two driver side shims it will be almost perfectly level. It has between a half and 3/4 rake I’m not sure if that helps the pcm issues
    Sephon likes this.
  8. Apr 4, 2019 at 11:38 AM
    Darthinvader48
    Is this something easy I can do in an hour or so or is it something I’m gonna have to realign afterwards?
  9. Apr 4, 2019 at 11:50 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    10 minutes and no alignment needed. It just keeps the lower control arm from moving up too high and bottoming out the shock.
  10. Apr 4, 2019 at 11:55 AM
    Darthinvader48
    I’ll do it this weekend
    Boerseun[QUOTED] likes this.
  11. Apr 4, 2019 at 1:07 PM
    Boerseun
    Ferdie
    Sarasota Florida
  12. Apr 4, 2019 at 1:15 PM
    Darthinvader48
    Thankyou I thought this was something else entirely
  13. Apr 4, 2019 at 3:05 PM
    Mfdsneed
    Mfdsneed New Member
    Go dawgs. Georgia.
    2015 MGM Tundra Xp
    Bilstein 5100,toytec. Fuel D671
    I just did my 2015. Ordered it from boss4x4 5100’s and a diff drop. Super cheap and rides great. Ended up finding a busted shock in the back. My set up 5100 on the top setting and a toytec 1” block in the rear. Could t be happier. 6793D72B-FF15-4F5F-8E87-BE85F87A569D.jpg
    matrdguy, Boerseun, Hol Milk and 2 others like this.
  14. Apr 4, 2019 at 3:45 PM
    Darthinvader48
    I’m curious as to why the shop told me I didn’t need the differential drop and the angle doesn’t look bad at all but I see a lot of members here installed the diff drop on leveling kits
  15. Apr 4, 2019 at 3:46 PM
    Darthinvader48
    Looks great
  16. Apr 4, 2019 at 3:53 PM
    Mfdsneed
    Mfdsneed New Member
    Go dawgs. Georgia.
    2015 MGM Tundra Xp
    The kit I ordered came with it. It was a little bit of a pita to install no room for hands to put the nut one the bolt. But otherwise I did the whole install myself in about 2.5 hours. Just needed a spring compressor. I did the diff drop just to save the boots. I really don’t know it it helps but I had it. Can’t see it hurting other then my hand to install it.
  17. Apr 4, 2019 at 3:53 PM
    Mfdsneed
    Mfdsneed New Member
    Go dawgs. Georgia.
    2015 MGM Tundra Xp
    Oh and thanks darth.
    Darthinvader48[OP] likes this.
  18. Apr 4, 2019 at 4:11 PM
    Mfdsneed
    Mfdsneed New Member
    Go dawgs. Georgia.
    2015 MGM Tundra Xp
    Looks great.
    phogallen likes this.
  19. Apr 4, 2019 at 4:31 PM
    thornjude89
    South Louisiana
    Stock
    nice!
  20. Apr 6, 2019 at 1:11 AM
    #50
    Cdorman
    Cdorman New Member
    Oklahoma
    2015 - SR5 - CM - MGM
    Color match MGM Bulge/Grille Trim Pro Grille TRD Pro Headlights(black) OEM led fog lights upgrade Headlight Revolution HID upgrade TVD vinyl decals Fog lights Always MOD Bilstein 5100’s 12Volts remote start kit PowerBass plug/play speaker upgrade
    This has helped me tremendously. Does anyone have the links to purchase the 5100’s and shackles?
  21. Apr 6, 2019 at 6:15 AM
    #51
    Mfdsneed
    Mfdsneed New Member
    Go dawgs. Georgia.
    2015 MGM Tundra Xp
  22. Apr 7, 2019 at 7:17 PM
    #52
    r1-superstar
    DB
    UTAH
  23. Apr 9, 2019 at 7:17 AM
    #53
    Darthinvader48
    That looks amazing I want that cover too!
  24. May 30, 2019 at 4:12 PM
    #54
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    2016 Toyota Tundra SR5 TSS Off Road
    TTC MEMBER #0193 2.5 Bilsteins struts (front) JDMstar led lighting inside Lazarstar spot lights Auxbeam LED headlight bulbs Auxbeam LED fog light bulbs 1.25” Spidertrax wheel spacers OEM fender flares
    I have the Bilsteins 5100 as well front setting only at 2.5”. Perfectly aligned with the back. Love the ride. Still doing research on getting taller wheels. Im currently running 285/55/20 but want 285/65/20. Does anyone know if UCA’s add a bit of a lift?
    thornjude89 likes this.
  25. Feb 25, 2022 at 6:48 PM
    #55
    Playfast12
    Playfast12 New Member
    Would this all apply for a 1st gen tundra v8 2 wheel drive? Thanks
