  1. Feb 19, 2022 at 9:39 AM
    Tundra3k
    Tundra3k New Member
    Kansas
    2012 Crew Max
    The one I grabbed was from a 2WD, not sure if it's the same as 4WD.
    Retroboy1989[QUOTED] likes this.
  2. Feb 19, 2022 at 9:50 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    It probably won't have the indicators for 4WD hi/lo, naturally.
  3. Feb 19, 2022 at 9:53 AM
    20GR8 Super
    Corey
    PNW Outskirts
    2007 Super White CM Limited
    :rofl:I’m so glad mine came with Optitron. My brain hurts from the last couple of days and I have only been skim reading.
    joseph_womack and Shanet421 like this.
  4. Feb 19, 2022 at 10:08 AM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    I got something else going on in the journey converting the dash to black. Climate controls came in yesterday and looking closer the defrost button on the black knobs compared to my grey knob button looks different. The black appears to be a side view mirror defrost only. I’m assuming these controls are for a DC without the defrosters on the rear glass. I’m thinking about just swapping the knobs to avoid losing defrost on the back glass. Does anyone have any experience on these climate controls. TIA!
    B85AC12E-B2AB-470B-9C1C-02DB430A292F.jpg F6F9E4C4-8EC6-4AA0-95E5-0EC81DDDBF64.jpg
  5. Feb 19, 2022 at 10:10 AM
    Retroboy1989
    Northern Utah
    The fact that it specifies makes me think there is a difference. Probably just the indicators.
  6. Feb 19, 2022 at 10:11 AM
    oogabooga289
    oogabooga289 New Member
    How would you swap the fan ring? I haven't taken my climate control unit out in awhile. Can the fan-strength ring be removed without breakage?
  7. Feb 19, 2022 at 10:18 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Roll the dice and swap it like it's hot!
    Obviously I have no skin in the game, but my virtual money is on the button activating both the side mirrors and rear glass in a CM
    Let us know?
  8. Feb 19, 2022 at 10:20 AM
    Shanet421
    San Diego,CA
    This guys just fell out in a YouTube video I was watching.
  9. Feb 19, 2022 at 10:22 AM
    Shanet421
    San Diego,CA
    Swap it like it’s HOT! I love it!
    I may just do that so we can have a definitive answer here. However the fascia on my current one has a bit less scratches. So I may try the dial swap after the first plug in attempt.
    joseph_womack likes this.
  10. Feb 19, 2022 at 10:25 AM
    COTundie
    Trey
    Pretty things
    Ah. That makes sense.
    Was going to say, why risk breakage swapping the dials, but it sounds like it will be of use/worth the risk.
  11. Feb 19, 2022 at 10:31 AM
    oogabooga289
    Oh. Nice! Thank you!
    Shanet421[QUOTED] likes this.
  12. Feb 19, 2022 at 11:41 AM
    Tundra3k
    Tundra3k New Member
    Kansas
    2012 Crew Max
    New to the group so I just wanted to slowly update on the upgrades I've done to the truck.
    Retrofitted some projectors from the Retrofit Source. It leaked the first time sealing it and I put it all back to stock after the frustration. After some time, I took them apart again and re-sealed it with a thick layer of butyl rubber instead of stretching it out like how they were in the instruction videos. Took it to the car wash and it didn't show any signs of a water leak so they're staying on the truck lol.
    If I had to do it all over again, I'd fork out the money for a set of Morimoto's and a really good explanation to the wife on why I needed them haha.
    Oh yeah, don't be a dummy like me and paint your hi beam reflector bowl. I had to find a projector type bulb to fit in there as my hi beam, along with the bi-xenon function of the projectors.
    Cheers
    273877045_4907430069303647_2021475618321256298_n.jpg 273759362_315269933773638_4693776130530852211_n.jpg 273553548_638253320836997_7573734097862703732_n.jpg
    D4x4TRD, wv00097, Skew12 and 12 others like this.
  13. Feb 19, 2022 at 3:15 PM
    Shanet421
    San Diego,CA
    Here’s an update for this. There is 3 plastic welded tabs holding the fan speed ring in place.
    074615F5-43A3-4A60-83EF-6A8A9BF877FB.jpg B9244520-D832-4E75-9387-657930398CEE.jpg
  14. Feb 19, 2022 at 3:25 PM
    oogabooga289
    Interesting. Looks like drilling/dremeling the backside of those plastic welds and using a few dabs of epoxy after the swap would probably do the trick. Bummer it wasn't just clipped in. Thanks for the update!
    joseph_womack and 20GR8 Super like this.
  15. Feb 19, 2022 at 3:49 PM
    Shanet421
    San Diego,CA
    Yes I think you are probably right on the epoxy. I am going to try to polish up the front fascia before I try to remove the ring.
  16. Feb 19, 2022 at 5:17 PM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    2013 Platinum-SOLD 2022 Sequoia, Celestial Silver Metallic
    Today I replaced the bad lock motor in my rear passenger door, and changed the oil and filter.
  17. Feb 19, 2022 at 6:23 PM
    Retroboy1989
    Northern Utah
    Checked the torque on my rear sway bar and U-bolts from my sumo spring install. The only thing that budged were the little U-bolts on the sway bar mounts. Changed the oil on the tundra and the sienna.
    I went with this on the tundra:
    My wife rolled her eyes when she saw it was for "hard working engines". My truck only gets a real workout a few times a year.
  18. Feb 19, 2022 at 6:36 PM
    20GR8 Super
    Corey
    PNW Outskirts
    I put Schaffer’s in my truck. By the time I buy the oil and filter I think it’s as much as someone would charge to do it but as far as the Mrs. is concerned we are saving money cause I am doing it. :D
    joseph_womack and Ohannon7 like this.
  19. Feb 19, 2022 at 6:50 PM
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    Wired up my inverter and have a tie-down track ready to be installed, but I ran out of daylight to install it. Unfortunately, as seen by the voltage meter my battery no longer wants to play nice. That picture was taken right after I shut my truck off so the readout should be closer to 12.6 and if I run the lights in my bed I can watch the voltage tick down like a countdown which is not good. I have not had any problems with starting the truck yet but I have a feeling it is only a matter of time at this point. The battery is about 5 years old now so it is the right time for me to be in the market for a new one.
    Most exciting of all though, I replaced a burnt out brake light!! :rofl:
    Trooper2, D4x4TRD, wv00097 and 8 others like this.
  20. Feb 19, 2022 at 9:28 PM
    Retroboy1989
    Northern Utah
    I did my own as well, and made a huge mess when the oil bounced off the pan and into the left wheel. I actually had oil splatter through the spokes and onto the ground in front of the wheel. :annoyed:
  21. Feb 19, 2022 at 9:36 PM
    Windsor
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    I'm sitting here imagining that but my tired mind is making it quite comical. Kind of like a Tom and Jerry skit.
  22. Feb 19, 2022 at 9:45 PM
    20GR8 Super
    Corey
    PNW Outskirts
    I think I am going to install a Fumoto valve next time I do it to make it easier and mess free.
  23. Feb 19, 2022 at 9:49 PM
    Retroboy1989
    Northern Utah
    It was ridiculous to watch it unfold. My garage floor absorbed alot of oil today between that and the sienna blunder with the new oil filter housing drain tool. (The hose was too long and ended up out of the pan)
    Yeah, that crossed my mind. Not sure how I could have prevented what happened yet (and this isn't even my first Tundra oil change:confused:). That oil comes out quick for the first few seconds, and laterally. It skipped right off the pan. And into the lower ball joint area. I had oil streaming down the sidewall of my tire.
  24. Feb 19, 2022 at 9:50 PM
    COTundie
    Trey
    Pretty things
    I keep my empty shop towel rolls for just this reason. Makes a nice funnel to guide the oil into its receptacle.
    Works better than my hand, which i used the first time i changed the tundras oil and realized it was a problem.
  25. Feb 19, 2022 at 9:52 PM
    Retroboy1989
    Northern Utah
    Great thought. I also wonder if the last time I changed it, unused a simple pan instead of the reservoir type with a really shallow lip like I used today.
  26. Feb 20, 2022 at 2:43 AM
    1eyedclyde
    1eyedclyde New Member
    Clyde
    NewCastle CO
    21 SC Pearl Platinum
    Those are some battery terminals. NICE
  27. Feb 20, 2022 at 5:05 AM
    Ohannon7
    Ohannon7 New Member
    Central Fl
    2013 5.7 4WD CM Bench-Seat Silver
    6” Pro Comp 37’s Custom audio and interior Off road capability is current focus
    is it safe to assume you are prepping your truck for a ghostbusters sequel or are there other valid uses for that equipment that I’m unaware of :confused:
  28. Feb 20, 2022 at 6:47 AM
    Bucks04
    Bucks04 New Member
    2013 TRD Tundra
    Working on it
    Just cut the drain hose so it hits the pan. Do you have the valve to screw into housing, easy open and close to drain , no fuss no mess at all.
  29. Feb 20, 2022 at 9:14 AM
    BoysandHisToys
    BoysandHisToys New Member
    Central Virginia
    2013 Tundra Crewmax Limited
    Just changed the oil myself for the first time this morning. Used the same oil!
    This is the first vehicle I’ve had where changing the oil wasn’t a PIA to get under, so I did it myself.
    WVI and joseph_womack like this.
  30. Feb 20, 2022 at 9:55 AM
    Retroboy1989
    Northern Utah
    I cut it way down after my little adventure.
    How much did you put in? I put in a little over 8qts. It's right below the full mark on the dipstick after sitting all night.
