Let’s see pics stock height Pro with 295/70r18
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by jordanpop1, Sep 11, 2018.
  1. Feb 18, 2022 at 9:08 AM
    #421
    ackthresher
    ackthresher New Member
    Jamie
    2017 cement crew max tundra pro
    Have pics of your truck?thanks I’m thinking the same route!!!
    RoniusMaximus[QUOTED] likes this.
  2. Feb 18, 2022 at 9:13 AM
    #422
    MistrRoboto
    MistrRoboto '17 MGM SR5 TRD CrewMax
    Virginia Beach, VA
    If you add spacers, will you rub the body mount or other spots? My 295/70/18 Mickey Thompson Baja Boss are millimeters away from the control arms at the moment.
  3. Feb 18, 2022 at 7:08 PM
    #423
    RoniusMaximus
    RoniusMaximus The One and Only
    J
    Tri-Cities, Washington
    2020 MGM Toyota Tundra TRD PRO
    Synthetic Blinker Fluid
    Yeah of course. Here you go.
  4. Feb 19, 2022 at 3:58 AM
    #424
    ackthresher
    Jamie
    Looks great!!!!any issues with the front mud flaps?im also looking at the toyo at3 !!thank you!
  5. Feb 19, 2022 at 4:13 AM
    #425
    thedonn
    thedonn New Member
    not a pro but a SR5 with just +1.9 front so very close to stock pro stance. these wheels have +25 offset so basically the look you would have with 1.5" spacers if you used the factory pro wheel. used coachbuilder bumper shims and removed mudflaps. no bmc no rubbing. i originally wanted a raptor or TRX but when i realized much of that was the look I decided to build my own
  6. Feb 19, 2022 at 4:37 AM
    #426
    Canadian Army TRD Pro
    Canadian Army TRD Pro New Member
    Canada
    2020 Army Green Tundra TRD Pro
    Haven't put them on yet, but doesn't look like it at all. I'll confirm when they're on. I do also have the bumper spacers but it doesn't look like I'll need them (I was debating going larger so ordered them in case)
  7. May 13, 2022 at 2:03 PM
    #427
    PhoenixSR5
    PhoenixSR5 New Member
    Brandon
    Gilbert, Az
    2016 Tundra SR5 work in progress
    Front: King 2.5 EXT RR, Freedom Offroad Uniball UCA, Sway Bar Delete, BMC and Pinch weld mod. Rear King 2.5 RR shocks, Icon AAL. Fuel Zephyr 18x9 +1 w/ Dirty Seven Maxxis RAZR MT
    So another non TRD Pro. I have the Bilstein 5100s on the top setting which puts me about where you guys are. My question is about offsets though. The wheel I found is a +1. I don't mind the tires poking out some but I also don't want to hack up my truck too much. I don't mind some trimming here and there. Is anybody running an offset close to that?
  8. Jun 17, 2022 at 11:00 AM
    #428
    contenderv07
    contenderv07 New Member
    Will
    I've gotten a killer deal on some Yokohoma Geolander MT's in 295/70/18. I've got a 3/2 spacer lift and stock wheels(2019 limited), so I think it will fit but is the general consensus for 1" spacers? or 1.25??
  9. Sep 4, 2022 at 2:25 PM
    #429
    COTundra23
    COTundra23 New Member
    this looks so good. Stock suspension?
  10. Sep 4, 2022 at 2:50 PM
    #430
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Harrop w/ Prospeed goods & Kooks LTs
    Yessir... stock at that time. :thumbsup:
    COTundra23[QUOTED] likes this.
  11. Nov 17, 2022 at 3:52 PM
    #431
    B3TundraPro
    B3TundraPro New Member
    Derek
    2019 TRD PRO aka Big Beautiful Beast
    Backflip toneau cover, bed liner, LaminX
    This might be reviving a dead thread and a little redundant but I’m just exercising caution before dropping nearly $2K on new tires but 295/70/18 WILL fit on stock Pro’s WITHOUT any additional lift or mod?? FlYhanks in advance for your time guys!
    Patch999 likes this.
  12. Nov 17, 2022 at 4:04 PM
    #432
    taylunatic
    taylunatic New Member
    Central MA
    2020 TRD PRO
    Got front windows tinted today. Went 20% so she ain’t exactly street legal anymore
  13. Nov 17, 2022 at 4:06 PM
    #433
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    The ultimate answer is “it depends”
    It depends on the actual tire you get. Not all tires with that nominal size come out to the same actual dimensions from different manufacturers. Some have large sidewall lugs that may hit your UCA. Some are a bit bigger in diameter and may hit your front sway bar at full lock or your fender liner. Run through this thread and note each response with what actual tire make/model they referred to.
    Personally, with the Falken Wildpeak AT3W, I had rubbing on my little front mudflap screws and I had a very slight rub on my front sway bar at full lock in a turn. I removed the little mudflap and don’t care around the little shiny spot on my sway bar. I clear my UCA with about 3/4” to spare. Done.
    A buddy with an SR5 got the same tires after getting the Iron Man 3” lift with new UCAs and they wouldn’t clear the UCAs he got so he had to get wheels with a bigger offset that then necessitated him getting a body mount chop. So if you’re thinking of changing UCAs you’ll need to consider that.
    bulldog93 and Patch999 like this.
  14. Nov 17, 2022 at 5:40 PM
    #434
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Aren't you sitting on a Wescott lift also?? Or, was your feedback in reference to your 'pre-lifted' self???
  15. Nov 17, 2022 at 7:01 PM
    #435
    RainMan_PNW
    Casey
    Clark County, WA
    Correct - I now have the Westcott lift as well. But my feedback was referencing "pre-lift"
    Good memory!
  16. Nov 17, 2022 at 8:00 PM
    #436
    Tripleconpanna
    Thanks! But, now you have me 2nd guessing my replacement tire choice... :mad::mad::mad:
    I'll probably just step it down to 285/70s :(
  17. Nov 17, 2022 at 8:34 PM
    #437
    RainMan_PNW
    Casey
    Clark County, WA
    I would’ve gone that size if I could’ve found the tire I wanted in it. Not as many options for some reason
  18. Nov 17, 2022 at 8:52 PM
    #438
    Tripleconpanna
    That's the struggle... I want the Wildpeaks, but it's either the 295/70 or 285/75s; both of which I believe will rub a stock PRO. I don't mind removing the front flap, but don't want rubbing on the sway bar or UCA. Ugghhhhh!!!!
  19. Nov 17, 2022 at 9:16 PM
    #439
    RainMan_PNW
    Casey
    Clark County, WA
    Your UCA clearance should be fine with both of those sizes of Falkens - the 285 is a tad narrower even. And for the 295’s, the sway bar is barely a rub at a full hard turn on a stock TRD Pro. Lots of people have them in that setup.
  20. Nov 18, 2022 at 6:49 AM
    #440
    B3TundraPro
    Derek
    I’m strongly considering the Cooper XLTs. I’ve had the Falkens on my 4Runner before the Tundra and they were a great tire but 90% of my driving is pavement 9% fire roads and probably 1% hard rocky/crawling. I’ve read every page through here and feel fairly confident they’ll fit and work great with removing the front mud flap. I just wanted to double triple check before moving forward. Telling the wife we need new tires is easy enough, convincing her we then “need” a lift to make them work wouldn’t fair so we’ll haha.
  21. Nov 18, 2022 at 8:29 AM
    #441
    AsThe_SkyFalls
    AsThe_SkyFalls New Member
    2020 Black Tundra TRD Pro
    295s should work out fine for you. I run the same and there is only rubbing on the passenger side swaybar at full lock. I suspect there will be absolutely zero rub with 285s
  22. Nov 18, 2022 at 8:46 AM
    #442
    RegGex
    RegGex I noticed you copied my beard
    Oregon
    2021 TRD Pro CM
    Any strong opposition for you tossing on some spacers?
  23. Nov 18, 2022 at 10:22 AM
    #443
    RainMan_PNW
    Casey
    Clark County, WA
    higher likelihood of rubbing or cab mount interference. For sure the front fender liner. You're pushing things farther from the rotation point, which means the circle needs to be bigger for the whole thing to turn.
    bulldog93 and Tripleconpanna like this.
  24. Nov 18, 2022 at 11:08 AM
    #444
    Tripleconpanna
    Spacers can cause rubbing issues in other places, plus I don't want the extra wear and tear on the hubs. I'm just trying to keep it simple and clean but add a bit more to the tire.
    I'm a bit of a purest in the sense that I bought the PRO to use it and enjoy it as it was engineered; for the most part the truck's design exceeds my needs! But, the factory tire size is a bit small in the wheel wells, and I want a bit more durability in the sidewalls. If my intention was to make mods to the suspension, etc. I would have opted for a lower trim level and spent the extra money on upgrades in the suspension, wheels, etc...
    On the other hand, if my Secret Santa comes through and I get a SC for Christmas, all that might change!!!! :santa2:
    RainMan_PNW likes this.
  25. Nov 18, 2022 at 12:59 PM
    #445
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    I’m almost went with 295’s when I first got my Pro. But decided on the 285’s. When ever SCS releases the new F5’s for our tundra’s that wheel will fill out my 285 much better. As much as I thought about going with 33x12:50 on that wheel I think I will stay with the size I have now. Unless I decide to have my tire owner who I deal with mount me a tire on the new wheel to take home and fit test.
  26. Dec 6, 2022 at 10:55 AM
    #446
    Badknees
    Badknees New Member
    2016 White Tundra 1794 CM 4X4
    TRD Pro BBS Wheels, TRD LED Headlights, Rigid LED Fog lights, 040 TRD Grille, 040 Hood Bulge, Black Center Valence, Driver's Grab Handle, TRD Pro Fox Suspension, 1.00" BORA Wheel Spacers, 1.5" Rear Shackles, TRD Front and Rear Sway bars, 295/70 R18 Cooper Discoverer AT3 XLTs, Full Size Spare, TRD Dual Exhaust, Console cover, Console Organizer, Husky Liner X-act Contours, Tinted Front Windows, Stubby Antenna, Autoventshade Deflectors, Duplicolor Painted Calipers, 040 Painted Front End Caps, Undercover Armor Flex Bed Cover
    I have a 2016 1794 running Cooper 295/70 - 18 XLT AT3 with TRD Pro Fox lift, TRD Pro wheels, and 1" BORA wheels spacers. I also had 1.25" spacers before the 1". Removed the front flaps and used a heat gun / small dead blow hammer to shape the $35 inner fender liners toward the front fender caps (and mud flaps) a bit to eliminate the slight rubbing - easy work. No factory UCA issues and slight rub at full turn on the TRD front sway bar - but not enough to worry about. I wouldn't fret over going this direction too much. Best.
    COTundra23 likes this.
  27. Dec 6, 2022 at 11:12 AM
    #447
    SaintofDespair
    SaintofDespair New Member
    21 TRD PRO Black
    295/70/18.. No rubbing..truck.jpg
    Chowdah, FISHN43, Badknees and 2 others like this.
  28. Dec 6, 2022 at 11:22 AM
    #448
    Tripleconpanna
    Wildpeaks??
  29. Dec 6, 2022 at 11:36 AM
    #449
    COTundra23
    looks great. What roof rack is that in the topper?
    Badknees[QUOTED] likes this.
  30. Dec 6, 2022 at 11:46 AM
    #450
    SaintofDespair
    21 TRD PRO Black
    Nitto ridge grapples
