Performance modifications
Discussion in '2nd Gen Tundras (2007-2013)' started by atacorion, Feb 13, 2022.
  1. Feb 15, 2022 at 6:40 AM
    shannon
    shannon New Member
    shannon
    Asheville, NC
    2010 DC
    Your passive agressive-ness reminds me of my mother in law. Is that you, Grace?
  2. Feb 15, 2022 at 6:41 AM
    poop_bubbles
    poop_bubbles New Member
    You’re overly simplifying my post.
    You 100% lose power at the same rate. By rate I mean % of power decline with every drop in ambient pressure due to elevation.
    I already stated that a boosted vehicle indeed still makes more power than NA but it does not make the same power at elevation that it would at sea level.
    10 Psi In Denver is not the same 10 psi elsewhere.
  3. Feb 15, 2022 at 6:47 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    Vizsla likes this.
  4. Feb 15, 2022 at 6:48 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    We stand in agreement.
  5. Feb 15, 2022 at 7:15 AM
    shannon
    shannon New Member
    shannon
    Asheville, NC
    2010 DC
    ah....there's the texas
    Vizsla and nobodyintexas[QUOTED] like this.
  6. Feb 15, 2022 at 10:32 AM
    poop_bubbles
    I was the one that stated ATRAC is 90% as useful as LSD.
    LSD is not a locker, and a locker is not an LSD.
    ATRAC is 0% useful as a locker.
    You keep mincing my words. Slow down and read, cowboy.
  7. Feb 15, 2022 at 10:44 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    listen pooper...i never said "LSD is not a locker, and a locker is not an LSD."
    how about you slow down & read. Mr. Shit.
    I was fairly f'ing clear. I guess MY education level is not the problem here.
    mince words.....GTFOH
    how's that for passive?:hattip:
    Larly5000, Cg13055 and Vizsla like this.
  8. Feb 15, 2022 at 10:51 AM
    poop_bubbles
    Ok, try and follow…
    Wrong.
    I never said you did. Those were literally my words, not yours. You’re quote of my post is the first factual thing you’ve stated.
    Man did you make it past 3rd grade?
  9. Feb 15, 2022 at 1:02 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Exterior: Toytec ultimate 3" lift level, Total Chaos Uniball UCA's, Total Chaos Cam Tab Gusset kit, AcanII smoked headlights, AcanII smoke Tail lights (2.5 gen style), DV8 front winch bumper , Badlands 12k winch with Apex Synthetic, White AUTMATCH Shackles 3/4" D Ring Shackle, Apex Winch shackle, Trail Ridge mirrors ,Icon Rebound Pro 17"x8.5" +25, Cooper Discovery STT Pro 285/70R17, PowerStop drilled n slotted rotors W/Carbon pads, Rigid flood flush mounts rear bumper , WeatherTec rain guards , OEM black side badges , Rigid Amber Radiance Pods. Energy Suspension Red Rack and Pinion Bushings, EAG front mesh Grille, RCI HighLift bed mounts. Rough Country DS2 Steps, A.R.E OverLand Canopy with Ascend basket, Stickers: ToyTec lifts windshield banner, Red Strange Music window sticker(back cab), White Strange Music sticker(back canopy), White Rigid sticker x2 (canopy sides), white Official BigFoot Research Team (Back Canopy) Interior: Alpine double din touch iLX-650 , JL C5-653's (front) JL C1-650x (rear) , JL JX400 4 channel amp , JL JX500 mono amp , 2 JL 12" subs , WeatherTec floor mats, Kenwood F/R Dash Cams, Black steering wheel emblem overlay, Tekonsha P3 Brake controller, ToyTec "Fresh" Scent coilover air freshener, Under the Hood: Koyo all aluminum radiator, Mishimoto red silicon hoses , XS Power 3000 amp battery , LAlectric 300 amp Alternator , K&N replacement filter. Online LED store accessories Fuse/relay box. (Identified) Dirty Deeds 8" Cat back exhaust with DD resonator delete/axel over converted into dump. Coming soon:
    Stickers cause they give +5 hp per sticker and they're light ;)
    but on a real note regaining MPG isn't really a thing other than D-mod'ing.
    1.) A good match gear set would be great to restore power lost form weight and slightly pick up MPG in lower band/stop and go.
    2.) Would be a good flowing Cat back with what ever sound or loudness you can can/want to live with (would avoid a turn down unless you want to hear it 24/7 (a side note in bottom)
    3.) A actual intake system I.E a TRD or equivalent of a sealed box using factory cold air pick up location, a TRD filter will do fine.
    4.) A super charger is a great option also (if you need help I gladly do a write up or video call if send a spare one to me :D)
    as for Carbon fiber, yes its light weight and can help shed a few pounds and clime back towards stock weight (which stock weight is what the stock MPG is rated at), wouldn't recommend it just for that with out considering the amount of work to maintain it, the increased engine noise due to less sound deadening and thickness and the extra safety hood pins as some super light weight hoods have thin layers holding hoop to the hood and with air ramming into the grill can cause it rip and the hood to fly open and smash the windshield . So having to deal with hood pins whether the stand up pin or sleek flush mount latches every time you want to service or check fluids is a thing.
    would only recommend if all these boxes are checked:
    1.) you love the look of carbon fiber
    2.) the inconveniences of it don't bother you
    3.) you have extra money that's falling out of your pockets
    4.) you hand wash and detail you truck no less than once a week using at least 6 different products per outside and inside
    5.) you don't mind the added care and products needed to maintain carbon fiber and understand in not taking care of it, it will look like trash in a year
    6.) every few years you don't mind doing smoothing and having it re-top coated.
    Side Note: My story about my exhaust I am the second owner of this Tundra (as of 3 years ago) it came with a unknown exhaust I honestly thought it was stock for a while and wanted to get a exhaust for it, It started making clunking noises and I noticed the tip would rock up into the bed denting it. I stuck it up on my lift and saw a long piece of tube attached to over axel that would act as a counter weight since there was only one hanger it would swing on I retightened the clamp clocking the tip correctly retighten the flange bolts and asked my self if some one really put that pipe on there as a resonator :notsure: that also would on occasion smack the bed and burned through my air lines for my bags :annoyed: so I cut the Axel over portion out :sawzall: and flipped the piece for a turn down so I could use my air bags again for towing, I would buy a new cat back later the whole thing seemed like hot mess. I don't mind the mild loudness in the cab with a turn down for 80% of the time I'm a Audiophile so normally have music going but when I take trips with family the stereo's off to talk and going up long hills the loudness of drone bouncing off the road is annoying. So that's something to keep in mind about a Turn down, now if that exhaust wasn't cut with a hole in it and had the tip denting my bed and the long added pipe burning a hole in air line (good thine the gas lines are out of reach) I maybe wouldn't mind it...... But as of now I personally want to go with long headers and V band clamps with Magnaflow Cats and Muffler a exit out the bed side and also a electronically controlled valve for by passing muffler when I feel NasTundra'ie.:burnrubber: I honestly thought this was a back yard no name exhaust weld up :welder:until I found out through this forum and looking on there site and it exactly matched and is the $800 8" budget system. :ohsnap: I will *Redact* the said name But I will say "Don't drink the kool-aid pour your self a glass of Cognac" when it comes the Exhaust system especially since you drive it very day and will be the one living with it.:anonymous:
    Cg13055 likes this.
  10. Feb 16, 2022 at 7:20 AM
    Cg13055
    Cg13055 @yota.parts.distributor
    South Florida
    Mcfly Tundra @yota.parts.distributor
    2012’4.0 Tundra-2004’4.7 crewcab-2021 2.7 Tacoma
    I’ve heard the stock intake is as good as it gets. Especially with the tundras and Tacoma’s. You have a 5.7 I believe so you should have some tuning options. Best thing to do considering price tag would be 5.29 gears and a tune. This is definitely subjective though. Magnaflow two chamber would be awesome too. Oh also you can do headers they will have a small yield though.
  11. Feb 16, 2022 at 7:22 AM
    Cg13055
    South Florida
    Carbon fiber is iffy especially on our trucks. Same for fiberglass hoods, unless you put pins on them there’s a good chance it could fly open. Also in a accident from what ive heard fiberglass can do some damage to the truck. All subjective but personally if I had the money main things I’d look into would be the s/c, gears, computer tune, and the exhaust is more for personal enjoyment
  12. Feb 16, 2022 at 8:52 AM
    mattyd170
    mattyd170 New Member
    Albuquerque, NM
    2020 Tundra Limited Crewmax with Leer shell. Calvary Blue
    TRD Front Suspension, Bilstein Rear, TRD rear sway bar kit, 35" tires, working on stereo.
    WOW! Quite the statement there.
    Cg13055 likes this.
  13. Feb 16, 2022 at 9:35 AM
    SAGE63
    San Diego County
    There is a stock Resonator? where?
    Cg13055 and Sundog like this.
  14. Feb 16, 2022 at 9:52 AM
    17TundraDCEd
    17TundraDCEd New Member
    Ed
    SE Pa
    2018 White SR5 Crewmax
    Rear Sway Bar
    The OP has a 2012 - if memory serves me, I believe they still used a resonator (looked like a really small canister muffler) right after the tailpipe flange that connects to the muffler outlet.
  15. Feb 16, 2022 at 9:57 AM
    SAGE63
    San Diego County
    ah got ya... not my 21...lol
  16. Feb 16, 2022 at 10:05 AM
    SAGE63
    San Diego County
    So this a question not a statement... doesn't the Auto LSD turn off in 4 hi and 4lo? well unless we are only talking about 2 wheel drive trucks then it is the ATRAC System
  17. Feb 16, 2022 at 10:11 AM
    17TundraDCEd
    Ed
    SE Pa
    Rear Sway Bar
    No. Not you’re 21.
  18. Feb 16, 2022 at 3:27 PM
    poop_bubbles
    In simplest terms, VSC is for pavement and ATRAC is for dirt.
    I have read that Auto LSD is only on certain 2WD models but I am fairly certain my 4x4 has it, as I have seen the light come on when in 2WD and 4HI.
    Far as I know ATRAC works the same in all trucks. ATRAC can be turned off too but you have to push a button. It is generally advantageous to have it on in 4x4.
    VSC likely goes a step further and keeps tabs on YAW and steering angle as it's more for high speed scenarios. I believe VSC turns off in 4x4.
    Regardless, all these systems are really just different ways of controlling traction through the ABS module. The newer TRD Pros have more advanced tech like crawl control, etc.
    SAGE63[QUOTED] likes this.
