Alpharex USA headlights
Discussion in '2nd Gen Tundras (2007-2013)' started by TheBeast, Sep 17, 2019.
  1. Jan 31, 2022 at 8:33 PM
    #811
    iNKBOi
    iNKBOi Colorado Boi
    Ben
    Vail, CO
    2008 Radiant Red Double Cab SR5 TRD Off-road and now 2020 TRD Pro Army Green Crew
    Ok, I’ll have to look at it tomorrow, thanks!
  2. Feb 1, 2022 at 5:20 AM
    #812
    PhotoNerd
    PhotoNerd New Member
    Tony
    Waterford, CT
    And make sure every harness on the headlight is connected. I had left a couple of harnesses unused thinking they were for other models because I watched the wrong YouTube video. My symptoms were similar to yours.
  3. Feb 3, 2022 at 6:37 AM
    #813
    FredB32
    FredB32 New Member
    Fred
    2011 TRD RW
    Has anyone with the non-leveling headlights looked at or attempted to swap over the leveling motors? I've seen a couple people who said they've done it with some Spyder headlights, and the Alpharex would seem to have the same type of single up/down adjustment screw, although there may be some minor modification required on the tabs to hold the motor in? I'd like to keep my leveling...but it's also not required. If I can figure out a way to do it though...
    Also, anyone WITH the levels...is it an actual motor that comes with the headlight, or did they modify the back of the headlight so you can swap it over?
  4. Feb 3, 2022 at 7:03 AM
    #814
    iNKBOi
    iNKBOi Colorado Boi
    Ben
    Vail, CO
    thanks a lot, that was it! I was thinking my lights didn’t come with the sequential blinkers for some reason so I ended up plugging them into themselves. I will make a note if anyone wants to drive around with the amber halo on all the time, just plug the light into itself(of course you’ll have some other issues along with it)
    Jedidanno and Shanet421[QUOTED] like this.
  5. Feb 3, 2022 at 4:58 PM
    #815
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    This is the same thing that happened to me. The listing from alpha when I bought was vague. I ended up retaining my leveling feature also. Very happy with mine so far
  6. Feb 3, 2022 at 5:14 PM
    #816
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    5 month of having the Pro's and they are both leaking.. FYI
    RToad likes this.
  7. Feb 4, 2022 at 2:43 AM
    #817
    RToad
    RToad New Member
    I've had Pros for 5 months no issues.
    Let us know how customer service is.
  8. Feb 4, 2022 at 5:59 AM
    #818
    FredB32
    FredB32 New Member
    Fred
    2011 TRD RW
    Do you know where they're leaking from? Or into, I guess? I just ordered a set last night and had a good discussion with their rep about a few things.
    What type of lighting are you using? There are known issues with HIDs, which is my plan for them. He was helpful enough to share some images of the engine bay of a Tundra and how it tends to channel water (basically, straight on top of the headlight and connections!).
  9. Feb 4, 2022 at 6:40 AM
    #819
    FredB32
    FredB32 New Member
    Fred
    2011 TRD RW
    I will add here, for anyone contemplating them - they do have some of the old stock units left WITH the leveling motor. I ordered the black; they didn't have the jet black (my first preference, but after looking at pics online the black actually looks pretty sharp), and I'm not sure on the chrome.
  10. Feb 4, 2022 at 6:50 AM
    #820
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    What bulbs are you using with the Pros?
  11. Feb 5, 2022 at 5:26 PM
    #821
    Rodtheviking
    Vancouver, WA
    Sequoia
    If they ever respond, I will.
    RToad[QUOTED] likes this.
  12. Feb 5, 2022 at 5:28 PM
    #822
    Rodtheviking
    Vancouver, WA
    Sequoia
    omgboost[QUOTED] likes this.
  13. Feb 6, 2022 at 4:12 AM
    #823
    RToad
    RToad New Member
    Already got your answer lol.
    I paid $300 for the set. I'll just replace them if they fail early. So far so good though.
  14. Feb 7, 2022 at 2:25 PM
    #824
    Jedidanno
    Jedidanno New Member
    2013 Black Tundra TSS/SR5
    Alpharex Correct Wiring.jpg [​IMG]
    I did not see anyone post a picture of how to wire the harness for the Alpharex Pro's. If it has been posted I apologize for a repeat. I just installed mine yesterday and started searching the Tundras.com forums to figure out why I was getting the dreaded amber halo instead of the bright white. Lo and behold I found my answer on this thread back in the 453 and 454 thread I think it was :monocle:.
    The instructions, as been discussed, are a little vague. It needs a diagram of this photo in them as well, in my opinion. To my point, the RED circles are the harness attached to the Alpharex assembly, the BLUE circle is the harness from the truck. The picture shows the grey plug from the assembly going to the bulb, and the black plug from the assembly going to the grey plug from the truck. This is the way.
    Another issue I have seen, is the yellow plug it says that is not used. If you read the instructions it does indeed tell you to plug in the yellow plug on the side closest to the DRL module as you can't plug in the other side as shown in my picture. I hope this helps, thanks!
    Rozr1 likes this.
  15. Feb 7, 2022 at 2:59 PM
    #825
    omgboost
    East Coast
    can't remember if I posted it here already but I really considered getting the Alpharex but I'm sure glad I spent a little extra and got the Morimoto XB when they were on sale black Friday. The major red flag was how many people were complaining about condensation. Another was the need to buy H7 LEDs and still using the halogen turn signal bulbs. Those two, with the cost of the Alpharex and risk of condensation equates to almost as much as the Morimoto. I really had hoped the Alpharex had solved their issue but it's been a good year since I really considered buying it and it does not seem like the problem has been solved.
  16. Feb 7, 2022 at 3:21 PM
    #826
    RToad
    RToad New Member
    I'm not sure who said you had to have the H7 LED's that's false. I am running the halogens and they are more than sufficient. I could buy 3+ sets of Alpha's over 1 set of Morimoto's I got my Rex's for 289. They were easy to install, work great and I love the look. I haven't had a single issue with them. Most people only log on to complain there are far more of us without any problems.
    SuperWhite4x4 likes this.
  17. Feb 7, 2022 at 3:23 PM
    #827
    omgboost
    East Coast
    I'm sure halogen is more than sufficient but the mod bug will catch on with me and want to get LEDs.
  18. Feb 8, 2022 at 9:15 AM
    #828
    Rodtheviking
    Vancouver, WA
    Sequoia
    The halogen bulbs were terrible, I had to replace them just to see the road.
  19. Feb 8, 2022 at 9:22 AM
    #829
    FredB32
    FredB32 New Member
    Fred
    2011 TRD RW
    Keep in mind that there are LOTS of LED lights available out there...I've been running a set of LED bulbs I got from Amazon 2+ years ago (Beamtech) that I probably paid $30 for and have been more than happy with in the stock housing. I got them when they were the relatively new style where they upgraded the chip placement to better mimic halogen light output. I'm planning on putting HIDs in the Alpharex when they arrive though. From reading online...LED setups run hotter (hence the giant heat sinks) and the HIDs should match up with the projectors better.
    Alpharex did warn me there are potential issues with the HIDs as well though, since drilling the dust cap on the back can open them up to potential moisture issues if not sealed back up properly. And by "moisture issues", they showed me some videos of how the Tundra tends to channel water...by dumping it from different directions right on top of the headlight assembly :|
  20. Feb 9, 2022 at 4:47 AM
    #830
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    I put Sealight LED’s in my new stock housings and couldn’t be happier. So happy, that I put them in the wife’s minivan and kids cars. As of yet, none of us has been flashed by oncoming cars. For $36 a set, it was much cheaper than the expensive halogens and last longer. The expensive halogens never seem to last longer than a year if you’re lucky.
    gkelm likes this.
  21. Feb 9, 2022 at 5:22 AM
    #831
    FredB32
    FredB32 New Member
    Fred
    2011 TRD RW
    I have a pair of older Beamtech bulbs in currently and the results have been solid (2+ years without issue). They're older but the newer "style" blade setup designed to more closely mimic the light output of halogens, so they work quite well with no real glare to speak of. My driver for the Alpharex were really just updating the look of the truck overall. I am hoping the projector with a good bulb setup will provide better lighting as well, with a cleaner cutoff. While I am happy with the current LEDs, projectors should be better if done right.
  22. Feb 9, 2022 at 2:58 PM
    #832
    RToad
    RToad New Member
    Sorry, zero issues with mine. I took the time to properly aim them. Work great.
  23. Feb 10, 2022 at 5:28 AM
    #833
    FredB32
    FredB32 New Member
    Fred
    2011 TRD RW
    I tried a set of them once when I had my Acura RSX (circa 2005ish) - the first set I had blew when I turned the headlights on the first time. Which was a blast, because that meant I drove back to the store to get them replaced in the dark...basically drove around with my high beams on for a few miles lol...the second set lasted about 3-4 months, and I've never gone back to them since. Since the wattage is the same, they just make the filament thinner so it burns hotter/brighter...but yeah, they last nowhere near as long in my experience.
  24. Feb 10, 2022 at 10:42 AM
    #834
    Rodtheviking
    Vancouver, WA
    Sequoia
    Okay
  25. Feb 10, 2022 at 11:35 AM
    #835
    MTRock
    MTRock 1889
    Montana
    2024 Tacoma TRD Off Road
    Katzkin Leather seats, JRI shocks, Rival aluminum skids, 285/70/17 outpost nat, Berger catch can, icon rear +.5 springs, gator trifold bed cover, Perry parts bump stops, switchback turn signals,
    FWIW..Update..No problems
    RToad likes this.
  26. Feb 16, 2022 at 9:52 AM
    #836
    iNKBOi
    iNKBOi Colorado Boi
    Ben
    Vail, CO
    Finally had some time to get the lights installed, definitely looks better. I took them out the box and resealed them, not gonna take any chances on condensation.
    RToad, MTRock, Shanet421 and 2 others like this.
  27. Feb 20, 2022 at 5:33 PM
    #837
    Rozr1
    Rozr1 New Member
    2008 SR5 DC
    My harness must be different because no way I can hook it up like that. The arex connectors can only go together and won't fit my turn signal connector or vice versa. Not sure if there if the instructions are different for the sequential and non sequential turn but I have the sequential or I should have the sequential assembly.
    Man not sure why I can't get this high beam to properly click in place.. already spread the pins out and still won't turn on. On pic it looks like it should be fine to connect.. my old spyders click in fine and also have the the lines to align with the factory connector 2 slits.
  28. Feb 20, 2022 at 7:29 PM
    #838
    Rozr1
    Rozr1 New Member
    2008 SR5 DC
    Finally got my high beam connector to click in place.. guess it needed even more separating or the pins. Now to adjust the beams they are aiming super high.
    MTRock likes this.
  29. Feb 22, 2022 at 7:35 AM
    #839
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    I've actually had some Phillips (xtra vision?) halogen bulbs in my bimmer's projectors for the last 5 or 6 years.
    It's no HID or even LED in brightness, but they were noticeably brighter than the standard bulbs and have proven to be long lived (knock wood). The car lives outside here in Colorado where it is currently below zero, which seems to be hard on bulbs.
    WVI likes this.
  30. Feb 22, 2022 at 8:44 AM
    #840
    FredB32
    FredB32 New Member
    Fred
    2011 TRD RW
    Could just be a thing with the startup voltage on the cars...I'm glad you have had better luck than I did, because that sucked!
