Supercharger opinions/advice
Discussion in 'Performance and Tuning' started by TommyTundra, Feb 15, 2022.
  1. Feb 15, 2022 at 1:37 PM
    TommyTundra
    TommyTundra [OP] Oh God the anger’s changing me
    Long Island NY
    2019 PRO
    Ok. So now that spring is slowly coming I am starting to gather info on supercharging my truck and can use some assistance
    A little background. I have a 2019 TRD PRO. It has 26k miles on it. I plan on keeping it for a long time. I do not do any towing/ hauling or off roading. Its a pavement princess in every sense. I have done a bunch of mods myself but a supercharger is not something I want to even try. I would rather leave that to a professional who has the proper equiptment and experience. The truck is not lifted, has the stock suspension, stock exhaust, i installed front and rear TRD swaybars, had Ridge Grapplers installed (295s),installed a Hikeit throttle controller and installed a S&B cold air intake which I hope can be fitted into the suoercharger (not fond of K&M)It still has the OEM brakes and I will consider a big brake kit when I burn through them.
    Is there anything else I should be doing before being supercharged???
    I want to go with the Magnusson TVS 1900 and there is a performance shop about 20 minutes from me that is a certified dealer/installer of Magnusson. The shop is BPR, Big Power Racing
    Is there anything I should be asking them??
    Can you explain to me what is a tune and do I need to get that done too??
    Magnussons site says no
    Also the site says its a closed system and doesnt need any maintenance ever. Is this real world??
    Thanks for any feedback.
    nobodyintexas likes this.
  2. Feb 15, 2022 at 1:52 PM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
  3. Feb 15, 2022 at 3:09 PM
    colenation
    colenation What’s next?
    Cole
    Alabama
    2018 Tundra TRD Sport
    Readylift 4”F/2”R SST LIFT Kit Fuel Sledge D595 (20x9 +20) Thunderer Ranger A/TR (35x12.5R20) Havoc HS2 black hoop steps
  4. Feb 15, 2022 at 3:56 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Traction bars if your going to be launching and such since you said its a pavement princess.
  5. Feb 15, 2022 at 4:46 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    As far as I know there aren't any hard "prerequisites" for getting a blower as long as your engine is healthy. The shop doing the install will check this before installing the kit. At 26K miles the engine shouldn't be a factor. You can always talk to the shop to see what they recommend. Maggie has some recommendations on their site:
    https://cdn.shopify.com/s/files/1/0...9-89-67-003_RevJ_Tundra_5.7L.pdf?v=1614361639
    If the shop nearby does Maggie installs I would go with them. Unless you are pushing for top end performance the three supercharger kits, Maggie, Harrop, and Whipple, offer similar performance gains (~550Hp) before you need to start upgrading the intake, engine internals, and transmission. Brakes and traction bars are (arguably) quality of life as long as you aren't racing your truck at which point they become essential. Maggie also offers a three year warranty where the other two are only one year warranties. Also the Maggie is closest to the original OEM TRD kit.
    Tuning may not be required but is recommended for things to run optimally. Tuning basically overwrites the ECU (truck's computer) with new parameters and instructions to allow it to deal with the increased airflow the supercharger provides. A computer is connected to your ECU via the OBD port for the overwrite to occur.
    Without a tune the stock ECU pulls timing and dumps fuel (basically runs less efficiently) to preserve the engine. You are also leaving HPs on the table: untuned (Stage 1) gets you about ~450, tuned gets you to ~550ish (Maggie says 543 or somewhere there about. In your case I've not seen any untuned Maggies installed so I am surprised it is an option.
    As far as maintenance Maggie says its prefilled and sealed so no maintenance is required. You can always double check with the shop performing the install. If it is sealed there isn't much you'll be able to do but on other brands you typically have to do oil and coolant maintenance at around 100K miles.
  6. Feb 15, 2022 at 5:02 PM
    ZPMAN
    ZPMAN 2nd place is the 1st looser
    Minnesota
    2016 Black Platinum Supercharged
    4" lift, 35s, Magnuson Supercharger
    Is your truck a flex fuel?
    AZBoatHauler likes this.
  7. Feb 15, 2022 at 5:40 PM
    TommyTundra
    Long Island NY
    2019 PRO
    It is not flex fuel
  8. Feb 15, 2022 at 5:43 PM
    TommyTundra
    Long Island NY
    2019 PRO
    Definitely not doing any racing. Im mid 50s. Just want to make my drive a little more exhilirating.
  9. Feb 15, 2022 at 5:57 PM
    Dr Doobie
    Dr Doobie Growing member
    Talkeetna,Alaska
    '07 RCSB 5.7 SC'd 4x4 SSM
    A blower will definitely do that:thumbsup:
  10. Feb 16, 2022 at 4:16 AM
    Saltyhero13
    You'll see a big increase in "Smiles per gallon" for sure. Well worth it.
  11. Feb 16, 2022 at 4:27 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    I had 26k miles on my '20 when I installed my S/C.
    it's a hoot. I love driving it. I am of similar vintage as you. I generally drive like an adult & mileage is "relatively" unaffected.
    Get your shop to dyno tune it. it's worth the extra $700 or so. mine really came alive when I took it off of the stock tune.
    My airbox is stock, so I don't know if your aftermarket box will affect the tune that comes with the Mag. I assume the inlet is still 3", so the tuner should be able to work with it.
    there are no other preps. just keep the variables to as few as possible. cat-back exhaust does not affect tune...so I'm told. I use the TRD, like you. it sounds even better with S/C.
    once you get it installed and tuned, there is not much to do. check the intercooler fluid & radiator...bubbles settle & you will need need to add a splash.
    budget?
    $10k for all-in install. it will probably land around 8k.
    then, plan on spending another $4k because you will start reading the threads here. it happens.
    I'm @ 40k miles now. my only issues were install related - a couple hoses got loose. easy fix.
    I am still new to all of this. from what I learned here, I asked my tuner to get me as much SAFE hp as possible. low AFR's when in the throttle. they delivered.
    lots of trials & tribulations in the thread @omgboost pointed you to. dive in.
    Traction bars (Caltracs) are your friend. it does not hook up in 2wd. in a fun way.
    As @Saltyhero13 said...you smile EVERY time you drive it.
  12. Feb 16, 2022 at 4:45 AM
    TommyTundra
    Long Island NY
    2019 PRO
    Looking forward to it all
    Im looking at the SDHQ traction bars so far. Watched some video last night
    Will look into caltrac today while im at work.
    I will order them and di the install as soon as i get a decent day here
    Big brakes will be done in time.
    Also ive been using BP 93 octane since I got the truck over 2 years ago so im already into that habit.
  13. Feb 16, 2022 at 6:51 AM
    Saltyhero13
    "One of us! One of us!"
    You'll need to post when you pull the trigger. It is always great to hear how owners respond to a S/C Tundra
  14. Feb 16, 2022 at 6:57 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Have the shop install an AFR gauge. In my opinion an AFR gauge and a tune are mandatory to help keep your engine alive, and are both a drop in the bucket compared to the cost of the supercharger, no excuse not to do them.
    ViktorG, Silver17, reywcms and 3 others like this.
  15. Feb 16, 2022 at 7:24 AM
    TommyTundra
    Long Island NY
    2019 PRO
    Will most certainly do that. Just read up on the subject. Thank you for the info.
  16. Feb 16, 2022 at 9:56 AM
    TommyTundra
    Long Island NY
    2019 PRO
    I just ordered the SDHQ traction bars. 100% bolt on. American mAde. Should go on same as the rear TRD swaybar
    PNWTundra2021 likes this.
  17. Feb 16, 2022 at 10:08 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    As mentioned I agree to budget for an AFR gauge, a boost gauge, custom tuning, an oil separator is nice to have, and any traction upgrades you may see yourself wanting in the future although not immediate necessary. As far as maintenance the oil in the blower should be changed somewhere between 100-150k miles from what I’ve seen. The Magnusons tend to eat through couplers as well, but that isn’t necessarily a maintenance item.
  18. Feb 16, 2022 at 4:29 PM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    Bak Revolver, BedRug, Undercover Swingcase, PopLock, Bilstein 5160(rear), Firestone RideRite, TRD rear sway bar, Coachbuilder +2 rear shackles, Andersen 5” aluminum adjustable hitch, TRD dual exhaust, VLEDS interior leds including the footwell kit, TundraTex FRAC mod, VLEDS LPR backup tag mount led, Husky X-Act mats, Color matched cup holder bezel (silver), Ceramic 20% tint all around, 50% Ceramic windshield, Color Matched door handles & mirror caps, The “Stubby” antenna, AMP Research steps, VLEDS 6”step lights, ToyTec/5100 Bilstein coil overs, 700lbs red ToyTec springs (2.75” lift), 20x9 +18 Method 306 custom painted and custom fit center caps, Gorilla spline lugs, Bridgestone Revo 3s 285/60R20, TRD skid plate, RaptorLiner “Red” tow hooks, 19 Pro black LED headlights, VLEDS Triton V6 turns, Rigid SAE D series fog lamps, 19 TRD hood scoop, 2019 TRD Pro grille, Coachbuilder bumper shims, X-Pel protect under mud guards, Opti Coat Ceramic, Opti Coat Sealed. And some snakes and sparklers, because they are my favorite!
    I’m giving serious thought to pulling the trigger on a supercharger for my 18, will 10k get it done?
  19. Feb 16, 2022 at 4:59 PM
    Silver17
    Eastern PA
    To run a magnuson with their provided tune, I would say 10k should cover it.
    Omohundro[QUOTED] likes this.
  20. Feb 16, 2022 at 5:38 PM
    SoCalRandy
    SoCalRandy New Member
    Randy
    San Diego, California
    2020 MGM Limited Crewmax 4x4
    I just recently paid about $9,500 total for the Magnuson kit, sales tax, and install. I added a Radium PCV oil catch can and a Figs Engineering heat exchanger cooling tank. I think $10K will definitely be enough to get you taken care of.
    Jcmf52 and Omohundro[QUOTED] like this.
  21. Feb 16, 2022 at 5:43 PM
    Joro43
    Joro43 New Member
    2018 TRD Sport 4x4 quicksand crewmax
    1st tundra nautical blue 4x4 5.7l DC TRD had oracle custom color shift halo projector headlights, Fab4 bumper with 12k winch. RBP RX3 Grill Pro Comp stage 1 with bilstein 6112 coil overs SPC UCAs BFG KM3 35x12.5x20 with Moto metal 959s NFab running boards TRD LED DRL pioneer avh 4200nex with Polk speakers and JL 600w amp with JL audio stealth box 196k miles and running strong ready for another 200k until I wrecked it on 2/26/21 Just bought 2018 CM 4x4 5.7l quicksand TRD package upgraded headlights and adaptive CC Trifold bed cover, blacked out badges, KMC wheels BFG KO2 tires, 3/1 pro Comp lift FAB4 front bumper with rigid lights and fab4rear bumper.
    Man now y’all got me revisiting adding the SC. A lot of money to chunk down. If you’re going to own for a while worth it. I just ordered a 22 King Ranch Tremor F250. Must hold off on any more mods!
  22. Feb 17, 2022 at 3:07 AM
    Omohundro
    Jody
    McMinnville TN
    I’ll be keeping this truck forever ( no joke). It’s not that it’s anything special and I’m more than sure I’ll buy another new truck at some point.
  23. Feb 26, 2022 at 6:18 PM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    Words cannot describe how perfect these engines are with a sc kit, I thought I was happy with headers and gears, but now after the sc kit, it's just wow, a vehicle that's size of a house shouldn't move this fast.
  24. Feb 26, 2022 at 6:19 PM
    SoCalRandy
    Randy
    Which gear ratio did you decide on? And what size tire are you running?
  25. Feb 26, 2022 at 7:06 PM
    boomsling
    boomsling New Member
    ‘18 SR5 Double Cab 4x4
    Magnuson, Rough Country 2” coil overs
    Just had a Magnuson installed on my ‘18 with 65k miles. I highly recommend it.
  26. Feb 26, 2022 at 8:31 PM
    Downytide
    GTA
    I've got 5.29s and skinny 35s, (285/75r18)
    SoCalRandy[QUOTED] likes this.
  27. Feb 26, 2022 at 9:06 PM
    Joro43
    Joro43 New Member
    Thinking of doing the same. That or new truck...
    boomsling[QUOTED] likes this.
  28. Feb 26, 2022 at 10:20 PM
    pvmike
    pvmike Home Depot flexing
    Los Angeles
    2014 Platinum Super White
    TRD Pro suspension, supercharger, 5.29 gears, Auburn LSD
    Sounds like I should be looking into traction bars as well for my SCed Tundra. Why did you choose SDHQ over Caltracs? It looks like it's 3x the price.
  29. Feb 27, 2022 at 6:23 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    given what we will ask them to do. I think both products will perform well
    I’m ok with my caltracs. Now that I’m all adjusted and such
    If you like fiddlin with stuff. Get the caltracs. If not. Get the sdhq
    pvmike[QUOTED] likes this.
  30. Feb 27, 2022 at 9:37 AM
    TommyTundra
    Long Island NY
    2019 PRO
    I went with SDHQ because of exactly what nobodyintexas stated. I am very mechanically inclined but by no means am I a motorhead. The SDHQ seemed like a more straight forward install and I like the set it and forget it. Im pushing 55 and just wanted to get under the truck to do the install and not adjust it constantly. Also there is something unique in the design of the front brackets to help with handling. There is an excellent video on youtube giving an overview on the SDHQs
    PNWTundra2021 and pvmike like this.
