  1. Feb 8, 2022 at 4:12 PM
    #7861
    TundraRunner481
    TundraRunner481 Kinda New Kinda Not
    SB
    So. Oregon
    2018 Cement SR5 CrewMax
    We have had a GE GNE27xxxxx French door fridge that we like. Going on 3 years now. The water dispenser is in the inside of the door, so it has a clean look to it, nothing on the front of it sticking out. We have not and will not hook the water line up to it, seen too many houses ruined when the line ruptures.
    20GR8 Super[QUOTED] likes this.
  2. Feb 8, 2022 at 4:15 PM
    #7862
    I’ll be that guy…..
    Subzero! If you win the lottery, get a subzero………
    I’ve worked on ones that are 30 years old!!!! The fridge I had to replace the clogged filter dryer, and door switches.
  3. Feb 8, 2022 at 4:17 PM
    #7863
    Kung
    KG, VA
    *hopes like hell the Samsung they bought a year ago continues to work* :oops:
    Seriously though...it's been fantastic so far. With that said, if it ever goes kablooie, we'll go with a Frigidaire or Maytag or something. I WILL say that we specifically got a fridge without the door ice/water thingy; we've not even hooked up the icemaker. (Yet.) Giving serious thought to just
    *gasp*
    making ice manually. :eek:
    Outbound, Fotnot, NWPirate and 3 others like this.
  4. Feb 8, 2022 at 4:27 PM
    #7864
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    Yeah, this. I've got a 15 year old sub zero. Replaced a fan motor about a year ago. But think 8K plus. My wife thinks it's loud but she hears things differently than I do. No water or ice dispenser. Just an ice maker.
    Rats under the house chewed the water line maybe 12 or 13 years ago. I replaced it with stainless steel braid and killed the rats. No problem since. Fortunately my wife heard the water running and I looked and found the leak.
  5. Feb 8, 2022 at 4:33 PM
    #7865
    Is yours a combo? The house I was at had side by sides, but separate, one entire unit was the fridge, and one separate full size freezer. They of course then has a separate undercounter ice maker……. Pretty sweet house in the foothills
    TaquitoBandito and 20GR8 Super like this.
  6. Feb 8, 2022 at 4:48 PM
    #7866
    JMB
    Chesapeake, VA
    If I remember right the fridge and freezer drawers are separate but can be combined. The guy that did our remodeling has been a friend since 1980. Ours was the least expensive kitchen he had done to that point, he took it on as a friend.
  7. Feb 8, 2022 at 4:51 PM
    #7867
    That looks awesome!!!
    TaquitoBandito and JMB[QUOTED] like this.
  8. Feb 8, 2022 at 6:20 PM
    #7868
    JMB
    Chesapeake, VA
    Thanks. My friend recommended the integrated look. For a few years we got a kick out of telling people it's in the fridge, or put it in the dishwasher. And then watching them try to find it.
    Dishwasher
  9. Feb 8, 2022 at 9:37 PM
    #7869
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    I read a lot of the post posts. It might a good time to check the water pressure.
    Fotnot[QUOTED] likes this.
  10. Feb 9, 2022 at 3:42 AM
    #7870
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    You talking to the whole house or just that bib to the fridge?
  11. Feb 9, 2022 at 9:00 AM
    #7871
    WAtundra4x4
    Den
    Wet side WA
    I’d check the pressure at an easy spot like the outside hose bib that can have a screw on connection. You can purchase a water pressure gage relatively cheap and couplings are available for hose connections. I did it when installing a sprinkler system a long time ago to get an idea of my coverage. The water system is a closed system, so the pressure should be the same if everything is off.
    I had a shower at the old house that would drip at different times of the day. I replaced the valve cartridges and no more problem. Moen suggested flushing the system in case there are particles getting into the valve causing problems. Moen is the faucet mfr. I did not have problems after that.
  12. Feb 9, 2022 at 9:04 AM
    #7872
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    :thumbsup::fistbump:
  13. Feb 9, 2022 at 3:34 PM
    #7873
    NWPirate
    Zach
    WA
    You guys have me nervous now on the water lines. This LG has been flawless for 5.5 years.
  14. Feb 9, 2022 at 7:10 PM
    #7874
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    FYI....my fridge hasn't leaked in a couple days. I'm starting to think that purge helped/fixed it. We'll see in a couple days.
  15. Feb 11, 2022 at 2:42 PM
    #7875
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Maybe they talking about the water line kits brought from big box store, those kit just punch a small hole in the main water supply to supply water to the fridge. Those one always leak when the gasket get old or the metal needle get rusted. As long as you run a solid pipe behind the fridge wall and use stainless steel braided line connecting from wall to fridge, it shouldn’t be a problem.
    TaquitoBandito and FrenchToasty like this.
  16. Feb 11, 2022 at 4:06 PM
    #7876
    P-Factor
    P-Factor New Member
    2018 Tundra Limited Double Cab
    TRD Sway Bar, TRD Exhaust, TRD Cold Air Intake
    Nothing spectacular.
    Replaced a 22 year old 50 gallon water heater while installing a (first time) thermal expansion tank, isolation valves, and all sweated brass/copper.
    I'm not a plumber and way to old for taking on this task and yes it did kick my ass.
    I took on this project as a personnel challenge to see if I still retain some early life skills.
    After seven hours this task is now complete with no leaks.
    P-
  17. Feb 11, 2022 at 4:07 PM
    #7877
    Your going to sleep sooo good! But the morning might suck
  18. Feb 12, 2022 at 8:33 PM
    #7878
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    At the entry way of our home we have this niche that looked very plain. My wife picked out an antique glass tile she wanted to have installed on the back of the niche. It took 14 (1 sq ft) sheets that were $20 each. Cutting all the edges and the arch was tedious work. Glass tiles can be a pain to cut. You have to use the right blade and make sure you have plenty of water if your using a wet saw. Glass heats up quickly and can crack easily. I grouted all the mirror tiles today and cleaned off the haze this evening. My latest home improvement project is done and my wife is very happy.
    Before:
    After:
  19. Feb 12, 2022 at 8:39 PM
    #7879
    1UPPER
    TEXAS
    Flux capacitor!
    My wife got me a 85” led tv for Valentines. So I removed our previous 55” and put up the new tv for the Super-Bowl. It fit perfectly above our living room fireplace.
  20. Feb 12, 2022 at 8:51 PM
    #7880
    Beer Man
    Beer Man @cement.tundra
    2021 SR5 XP CrewMax Cement
    That’s awesome. Now you just need a couple more!
  21. Feb 13, 2022 at 4:03 AM
    #7881
    1UPPER
    TEXAS
    Flux capacitor!
    I like the way you think! :cheers:
  22. Feb 13, 2022 at 5:30 AM
    #7882
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    That looks outstanding!
  23. Feb 13, 2022 at 9:49 AM
    #7883
    1UPPER
    TEXAS
    Flux capacitor!
    If you have kids like me, you know their sinks can get dirty quickly. I have tried to clean the porcelain sinks with about everything I could think of but nothing would remove the hard water stains. I bought this Scouring Stick at lowes for $3. I had my doubts it would work. I will always be using this stuff on porcelain sinks & tubs. It’s amazing stuff!!!
    Before: Hard water stains on Porcelain sink.
    After: Used Scouring Stick to remove all the hard water stains.
  24. Feb 13, 2022 at 9:55 AM
    #7884
    NWPirate
    Zach
    WA
    :yes:
    Looks great!
  25. Feb 13, 2022 at 10:46 AM
    #7885
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    I learned this years ago on a urinal I had in our bathroom at work. Decided eff it, if I gotta use thos every day, it's gonna be better. And holy hell those things work great!
  26. Feb 14, 2022 at 8:49 PM
    #7886
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    been using those for years - nothing else actually works.
  27. Feb 15, 2022 at 3:54 PM
    #7887
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    how do you get hard water stains off of shower glass doors ?
    TaquitoBandito and NWPirate like this.
  28. Feb 15, 2022 at 3:59 PM
    #7888
    blackoutt
    blackoutt YEAH BUDDY!
    Indy
    07 DC Long Bed - Old Man Tan
    OEM+
    Moen has lifetime warranty to original purchaser and will send free cartridge supposedly. Going through this with a shower right now after replacing another with $50 Lowe's part. Depends on how soon you need it.
    T-Rex266[QUOTED] likes this.
  29. Feb 15, 2022 at 4:02 PM
    #7889
    Good to know. I spent $30 on two cartridges
    blackoutt[QUOTED] likes this.
  30. Feb 15, 2022 at 4:05 PM
    #7890
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Try vinegar and distilled water..50/50.
