Tundra front end popping noise when making full turns
Discussion in 'Suspension' started by Tundra Enthusiast 5.7L V8, Feb 8, 2022.
  1. Feb 9, 2022 at 12:12 PM
    A visual inspection is a good start. Check the boots for dry rot, check for grease slinging, check the clamp ends. Some play in the CV is expected, it has to rotate and angle with turning. Getting in the truck in 4wd on loose surface with the windows down or a friend to help and inspect the CV's during full lock turn left and right while rolling slowly. Listen for popping and binding, look for openings in the boot that may not have been obvious during static inspection. Should smoothly rotate. Shouldn't have a lumpy rotation or any sloppy movement.
    Uhhhh.... likes this.
  2. Feb 9, 2022 at 12:49 PM
    Tundra Enthusiast 5.7L V8 [OP] New Member
    Jeffrey
    2019 Tundra Limited 4x4, 2016 Tundra 1794
    I am taking off the CV axles at the moment. I already took the drivers side off and am in the process of the passenger side. This is driver side photos. I guess CV housings look bent and have grease on them as well as the inner wheel seal
    texasrho83 and Occidentalis like this.
  3. Feb 9, 2022 at 3:33 PM
    Jeffrey
  4. Feb 9, 2022 at 3:37 PM
    No CV’s. No skids. No sway bar. What’s left? Ball joints? Steering rack?
    texasrho83 likes this.
  5. Feb 9, 2022 at 3:40 PM
    Jeffrey
    I pray it’s not the rack, it’s going to be a real PITA to replace. I’m guessing LCA bushings although there is no play, they might be bad.
  6. Feb 9, 2022 at 4:35 PM
    My tie rods (non-Toyota replacements) started knocking when backing up mostly after about 2 months. I overlooked them for a while since they had recently been replaced. I ended up replacing them with Toyota ones and that fixed it.
    edit: outer tie rods.
    Joro43 likes this.
  7. Feb 9, 2022 at 4:58 PM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    Virginia
    2016 Silver Limited DC
    7” BDS, 37s
    Could coilovers make that noise?
  8. Feb 9, 2022 at 5:38 PM
    Joro43
    Joro43 New Member
    2018 TRD Sport 4x4 quicksand crewmax
    1st tundra nautical blue 4x4 5.7l DC TRD had oracle custom color shift halo projector headlights, Fab4 bumper with 12k winch. RBP RX3 Grill Pro Comp stage 1 with bilstein 6112 coil overs SPC UCAs BFG KM3 35x12.5x20 with Moto metal 959s NFab running boards TRD LED DRL pioneer avh 4200nex with Polk speakers and JL 600w amp with JL audio stealth box 196k miles and running strong ready for another 200k until I wrecked it on 2/26/21 Just bought 2018 CM 4x4 5.7l quicksand TRD package upgraded headlights and adaptive CC Trifold bed cover, blacked out badges, KMC wheels BFG KO2 tires, 3/1 pro Comp lift FAB4 front bumper with rigid lights and fab4rear bumper.
    Mine did it for years at full lock. I had an 08 for 12 years. Pop only happened when backing up at full lock. Never affected my steering or anything it was just a pop at full lock in reverse. If you look there’s a plate the outer tie rod would hit. Pretty sure that’s the noise I was dealing with
  9. Feb 12, 2022 at 7:20 PM
    Jeffrey
    Update:
    Got new bushings for the lower control arms. Problem fixed. No more popping noise. I also torqued lower cam bolts to 207ft Lbs. Very happy camper.
  10. Feb 12, 2022 at 7:41 PM
    cctxquicksand
    cctxquicksand IG - TRDistheWrd
    Nice! My problem has gotten worse but this gives me hope as I have new LCAs on the way! Thanks for the update op!
  11. Feb 12, 2022 at 7:43 PM
    Jeffrey
    No Problem. I hope that fixes your issue as well. Good luck
  12. Feb 12, 2022 at 7:53 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    This after you did all that troubleshooting :ohsnap:
    At least you found the culprit! Great work dude.
    cavalry bear likes this.
  13. Feb 12, 2022 at 8:00 PM
    Jeffrey
    Thanks. I honestly didn't it was the bushings because the wheel didn't move at all while the truck was jacked up so I said What the Hell, let me try the bushings instead of the steering rack and it fixed it. Now I learned just because bushings look good doesn't mean they are all always good. I hope this thread helps a lot of people.
  14. Feb 13, 2022 at 4:49 AM
    Uhhhh....
    Dave
    Virginia
    7” BDS, 37s
    What brand did you go with? Did you have a hard time pressing the old bushings out / new ones in?
    And I assume an alignment is needed after this?
  15. Feb 13, 2022 at 5:27 AM
    Jeffrey
    I bought some bushings from Amazon since I wanted something delivered very fast. I took off both LCAs from my truck and I took them to a local suspension shop to do the work since I don't have the tool to remove and press in the bushings. Hope these bushings last a long time. And yes you do need an alignment after
    Here is the link to the bushings I bought. https://www.amazon.com/Bushing-1-06...&sprefix=tundra+lower+control+a,aps,87&sr=8-8
    Uhhhh....[QUOTED] and texasrho83 like this.
  16. Feb 13, 2022 at 5:48 AM
    CaptainMcJedi
    CaptainMcJedi New Member
    Durham, NC
    19 Tundra Sport
    Man... that's maddening. Bushings can drive you nuts... heard them squeak before, but wouldn't have guessed that pop came from them. Nice work on the fix dude.
  17. Mar 1, 2022 at 2:58 PM
    Uhhhh....
    Dave
    Virginia
    7” BDS, 37s
    Not trying to hijack your thread here, OP, just adding more potential solutions for folks who may have this issue down the road.
    Mine was fixed by tightening up the LCA bolts. The rear cam bolt on each side was loose. Also had loose Coachbuilder tie rod end bolts, but I think the popping was from the LCA bolts.
  18. Feb 18, 2024 at 4:00 PM
    lukedias00
    lukedias00 New Member
    2014 Tundra 4x4 Off-Road Limited
    mine pop as well, not a big deal but just kind of annoying. When torquing can bolts you always tighten the nut correct?
    I put cheaper aftermarket LCA on about 4 months ago, and moog outer tie rods ends. I think it’s one of the two.
