  1. Feb 12, 2022 at 12:01 PM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    No, but i would like to meet someone with a 3d printer.
    i have pliers and hammers.
    5N0W808 likes this.
  2. Feb 12, 2022 at 1:03 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    My steering controls are all disconnected except for cruise control. When I get some time (lol), I may investigate the possibility of wiring one or more of the buttons for a momentary or on/off trigger switch.
  3. Feb 12, 2022 at 1:10 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    You'll need a controller of some sort.
    The OEM controls are a resistive load, not just a switch. They share the same wire(s).
  4. Feb 12, 2022 at 1:19 PM
    alb1k
    Left Coast
    It's good
    Thank you - my little brain imagined there was some voodoo going on in there.
  5. Feb 12, 2022 at 1:26 PM
    I have 4 of them 20 feet away from my desk at work. Haven't figured out how to get the software installed to use it yet. One has a Mr Robot insignia. Guessing thats some brand name. Probably several hundred grand in equipment.
    chrisb and NWPirate like this.
  6. Feb 12, 2022 at 1:29 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    tell someone that works it to make me a 1/10 scale tundra body.
  7. Feb 12, 2022 at 1:59 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  8. Feb 12, 2022 at 2:43 PM
    shifty` You can call 1 (800) PP5-1-DooDoo
    We have any HVAC dudes here?
    Someone tried to scam me into a new furnace earlier, was really sneaky how he did it. That said, I fixed the issue he created while "troubleshooting" w/me, which led me to fumble through finding the actual cause (no continuity at hot surface ignitor, ignitor cracked). Part overnighted, I'll repair tomorrow.
    Anyway, got a couple extra questions (simple) I know any HVAC person could probably answer easy. Related to switches (flame rollout limiter, furnace limiter). It's for a Payne PG8MAA series.
  9. Feb 12, 2022 at 2:45 PM
    You can buy replacement cases on fleaBay.
    (non-OEM but they work)
  10. Feb 12, 2022 at 2:53 PM
    What’s the question, I’m not a furnace wiz but I also wouldn’t just sell something to someone that didn’t need it, or create a scare issue
  11. Feb 12, 2022 at 3:04 PM
    Well, this guy, super nice older fellow, went to test the limiter switches since the error code pointed to that as a possible issue. On the 2nd one, he either [accidentally or purposefully] left the power on and arced his pliers against the chassis, which quietly blew the 3A fuse on the mainboard without any indication. He then continued testing limiters as if nothing happened, and deemed them all OK, but the unit wouldn't fire off, which led to his diagnosis:
    "Either the board, the gas valve, or (some other part I don't recall) is bad. Each is about $700. We could replace one, but the other may go bad 6-12mos from now, then you're out $1400, and if the last one goes bad, a new furnace is only $2300 ... might as well just be proactive here". I asked if there were any other creative options, we'd budgeted to overhaul our HVAC in the fall. "Nope, if you want heat, it'd be a week to get any of those parts, I'd just replace it, my person will send you a quote".
    Went into house. Nest t-stat was showing the unit was 'disabled' or something weird it wasn't saying prior. That's when I went to the furnace and saw the code our unit was flashing switched from 34 to 24, 24 being 'secondary fuse blown'. So I replaced that fuse, and the unit powered up, kicked on, I smelled the 1st burst of gas, no ignition. So I lit the gas it sprayed, POOF, I have heat again. That MF'er! The ignitor never lit up, so I started hunting for the ignitor itself and .... Yup. Visual inspection shows it's toast, clearly fractured, apparently the classic white line of death. $24 part.
    chrisb, NUDRAT[OP], txagg and 3 others like this.
  12. Feb 12, 2022 at 3:16 PM
    Oh damn I forgot to ask the question. Payne PG8MAA unit. I found four limiters inside but looking thru the parts list here, it's not clear which is which, there's apparently at least two, possibly three different switches inside?
    See this pic. I've labeled the limiters "A", "B" and "C", and C has two matched, one on each side of the burner. A is on the exhaust stack. B is facing the blower motor side, I think, and it's different enough in appearance I think it's HH18HA502.
    But I'm just confused about A and C? and...
    Is it worth just replacing them all after 20 years, it's cheap enough? and...
    Should get reset-able switches, since it seems like there's an option? and ...
    Anything else I may be missing b/c I don't do this for a living?
  13. Feb 12, 2022 at 3:22 PM
    Honestly, just replace the igniter, I wouldn’t worry about the safeties unless you know they are open, easy test with a ohm meter. Igniters and ignition modules are the most common since they are always the ones doing the work, and a HSI has a rough life!
    It’s also good to clean, some people replace the flame sensing rod. I believe it’s a thermopile so when it gets hot it produces a milivolt signal that is seen by the ignition module.
    chrisb, Festerw, BubbaW and 2 others like this.
  14. Feb 12, 2022 at 3:29 PM
    Good point on continuity test, I just didn't know if it was a simple circuit, or how it works. I assumed when they heat beyond their manufactured threshold, it interrupts the circuit, and continuity would then cease.
    I'm having the same intermittent error (33) or (34) on my upstairs unit - the ignitor isn't firing up. But on that one, if I cut its main power off, leave off for 30sec, then turn power back on, like 90% of the time, it fires right up. But visual inspection of the HSI in that case, it looks alright. So I'd planned to swap out the limiters based on the error. FTR, here are Payne's definition of those codes, I swear it's 34 but maybe it was 33, I can't remember:
    CODE: 33.
    RESULT: LIMIT CIRCUIT FAULT - Indicates a limit, or flame rollout is open. Blower will run for 4 minutes or until open switch remakes whichever is longer. If open longer than 3 minutes, code changes to lockout #13. If open less than 3 minutes status code #33 continues to flash until blower shuts of Flame rollout switch requires manual reset. Check for: - Restricted vent - Proper vent sizing - Loose blower wheel - Excessive wind - Dirty filter or restricted duct system. - Defective blower motor or capacitor. - Defective switch or connections. - Inadequate combustion air supply (Flame Roll-out Switch open).
    CODE: 34.
    RESULT: IGNITION PROVING FAILURE - Control will try three more times before lockout #14 occurs. If flame signal lost during blower on-delay period, blower will come on for the selected blower off-delay. Check for: - Control ground continuity - Flame sensor must not be grounded - Oxide buildup on flame sensor (clean with fine steel wool) - Proper flame sense microamps (.5 microamps D.C. min., 4.0 - 6.0 nominal). - Gas valve defective or gas valve turned off - Manual valve shut-off - Defective Hot Surface Ignitor - Low inlet gas pressure - Inadequate flame carryover or rough ignition - Green/Yellow wire MUST be connected to furnace sheet metal.
  15. Feb 12, 2022 at 3:33 PM
    So that one is probably the flame sensing rod, it’s just a ceramic coated rod with a bend on it and a terminal that faces you as it’s in the unit, I think a screw usually holds it in place, but pull it and use sand paper at the very tip and clean it up so fresh metal is shining, I bet that will cure it.
    chrisb and shifty`[QUOTED] like this.
  16. Feb 12, 2022 at 3:38 PM
    Yup, know what you're talking about. I can give that a go. I wasn't sure how it worked, I assumed it was a thermocouple of some sort to ensure flame was rolling. I didn't think you could sand on those things.
  17. Feb 12, 2022 at 3:50 PM
    It’s similar to a thermocouple. I guess they can go bad over time, so if cleaning it doesn’t work, I’d replace the flame sense rod, it’s in the same extreme use category as the HSI
    shifty`[QUOTED] likes this.
  18. Feb 12, 2022 at 3:51 PM
    Oh and in other off-topic news, I've had this little Snap-On ratchet, an awesome road score from the RR tracks by my house that have separated many a tool from its owner and landed it in my stash. It's never really worked right, kicking itself out into a neutral position if I'm cranking hard.
    I know there's rebuild kits out there and I found the kit for models like mine from Snap-On's documentation. But before dropping the $25 on the kit (RKRA930A for this GM70M), I went ahead and pulled it apart to see what I was up against. While the main gear (with the 1/4" end) definitely has some wear as you see in that last pic below, it turns out the interior was just gummed all to hell and I'm guessing that made the pawl stick or not fully seat.
    So I got some PB Blaster, scrubbed the hell out of it, blew it out, then threw some Super Lube in there and ... works like a champ! No more sticking while throwing torque on it. I thought Snap-On was lifetime warranty, I'd kinda hoped they'd just send a kit but whatever.
  19. Feb 12, 2022 at 7:52 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    find a snap on guy and they rebuild them for free
  20. Feb 12, 2022 at 8:51 PM
    alb1k
    Left Coast
    It's good
    First attempt at skid plate noise removal involves these isolators. These are the cheaper and fatter ones than I will use if they are promising.
    daveeasa and des2mtn like this.
  21. Feb 12, 2022 at 9:13 PM
    How bad could it be to need isolators? Is it warped or something? Personally, I'd just small rubber washers around the existing bolts.
  22. Feb 12, 2022 at 9:20 PM
    alb1k
    Left Coast
    It's good
    I ran some poly washers between the bolts. It was horrible. Sounds like a ball joint with no cup liner. As we speak, I'm looking at some cool bushings that are likely better than this style. They provide buffer for the bolts and between plates. But it's going to be trial and error. I've been running without the middle plate this week and Im not going back to that noise I had.
  23. Feb 12, 2022 at 9:52 PM
    I give my 1/2” ratchet this treatment about every 3 years or so. Seems to get sticky with crud and it starts doing the same thing. Pull the circlip, clean, lube, pop it back together and it’s good as new.
  24. Feb 13, 2022 at 6:19 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Are you calling me a tool, or is this directed at the thousands of dudes running amber and yellow fogs during the day time? I never turn off my OEM fogs, partially because I don't think to do it.
  25. Feb 13, 2022 at 7:14 AM
    Anyone have a factory emblem for a 2000 Tundra grille laying around? The Chromey one.
  26. Feb 13, 2022 at 7:16 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    My broken ratchets become finger tools.
    Double handy if you need it.
    shifty` likes this.
  27. Feb 13, 2022 at 7:21 AM
    daveeasa
    I did. I gave it away with the grille. Sorry.
    I have a super big one off my friends 2016 though. Bigger is better right?
  28. Feb 13, 2022 at 8:13 AM
    alb1k
    Left Coast
    It's good
    Not at all. And I would like to condemn the idiot with my name that posted after his bedtime.
    shifty`, bmf4069 and NWPirate like this.
  29. Feb 13, 2022 at 8:17 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Sirfive likes this.
  30. Feb 13, 2022 at 8:35 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    My rotator ratchet came from an estate sale.
    shifty`, dinosaur, Festerw and 3 others like this.
