  1. Feb 9, 2022 at 8:33 AM
    aelarson
    aelarson New Member
    AZ
    2011 SR5 Tundra (Silver Sky Metallic)
    Installed the Meso customs LED interior lights! Very easy installation. Also another confirmation that these fit 2nd Gens. If you have a crew cab with the stand alone dome light, the rear light will fit. Fitment is spot on, color match is spot on and they are brighter then bright - seems like a quality product.
    Not much else has changed on the truck recently, life has been busy (I've still been lurking around here on the daily). However, I have been going back and forth with Diode Dynamics because my SS3's were not functioning as they should. They were making a horrible humming/hissing/buzzing sound when turned on. After testing and sending lights back and forth since Thanksgiving, they are going to refund me entirely. Going to pull the trigger on some SS5's instead. The customer service has been great and they have totally backed the products. I was also having an issue with my sPOD randomly turning on/off and choosing random switches, so I sent that in the get work done. I also have plans to get my new rust free bed popped on, some offroad bumpers and additional lighting - I just need life to slow down for a bit so I can focus on the truck!
  2. Feb 9, 2022 at 2:11 PM
    Ohannon7
    Ohannon7 New Member
    Central Fl
    2013 5.7 4WD CM Bench-Seat Silver
    6” Pro Comp 37’s Custom audio and interior Off road capability is current focus
    @aelarson - those are awesome lights. I would buy them for sure if they had black housings!!
    aelarson likes this.
  3. Feb 9, 2022 at 2:15 PM
    aelarson
    aelarson New Member
    AZ
    I haven't tested them out in the dark yet, but I think they are going to be sweet! Is your trim all black on the roof?
  4. Feb 9, 2022 at 2:32 PM
    Windsor
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    Got my solar panel installed, made a new mount for the VHF antenna using a 5" x 1/8" stainless steel disc.
    Thumb screws look like they'd be easy to take off.... Looks are VERY deceiving. To get the panel off, you have to take the rail off. To get the rail off you have to hire a 10yr old or a junkie to reach their arm in to tighten the center support bolt.
    D4x4TRD, wv00097, Prostar 190 and 7 others like this.
  5. Feb 9, 2022 at 2:35 PM
    Mattyc
    Mattyc <insert custom title>
    Matthew
    NY
    2008 Limited Rock Warrior
    Not stock
    Are you running a secondary battery for add-ons? What setup do you have?
  6. Feb 9, 2022 at 3:29 PM
    Windsor
    Homeless in Oregon
    Some.
    No secondary battery. Put solar on to keep the battery topped up and to deal with the draw from my company supplied vhf radio. Have to leave it on 6-14 hrs a day depending on what they have me doing and don't like idling the engine.
  7. Feb 9, 2022 at 6:29 PM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    Optitron came in today. For $113 it’s in really good shape. I will get it in this weekend and update with photos.
    D4x4TRD, Filthyphil, wv00097 and 11 others like this.
  8. Feb 10, 2022 at 4:44 AM
    Ohannon7
    Ohannon7 New Member
    Central Fl
    Yup
  9. Feb 10, 2022 at 4:46 AM
    Ohannon7
    Ohannon7 New Member
    Central Fl
    now if you can find a 10yr old junkie you’d be set for sure!!
    Windsor[QUOTED] likes this.
  10. Feb 10, 2022 at 4:48 AM
    Ohannon7
    Ohannon7 New Member
    Central Fl
    whoa, optitron for $113??
    That’s cheap enough to make me upgrade my sweet JDM orange gauges lol
    can’t wait to see final results
    eBay find?
    joseph_womack likes this.
  11. Feb 10, 2022 at 4:58 AM
    Shanet421
    San Diego,CA
    Yes I have been scouring eBay for quite some time. Then this one appeared with close mileage.
    Ohannon7[QUOTED] and 20GR8 Super like this.
  12. Feb 10, 2022 at 7:00 AM
    Retroboy1989
    Northern Utah
    I would probably do this if I could find a deal like that.
    There are milage correction services. Or I saw a diy where someone connected a laptop to the circuit board and changed the mileage.
    Ohannon7 and joseph_womack like this.
  13. Feb 10, 2022 at 9:48 AM
    COElkHunter
    COElkHunter New Member
    Jeremy
    2012 Silver Tundra TRD limited Crewmax 4x4
    3" OME lift w/ UCAs. ARE overland shell w/ ARE roof rack. 34" Falken Wildpeaks. ARB awning. Road shower. Wilco Offroad Hitchgate Solo High Clearance. LED lighting upgrades. Lockerdown console safe. Weathertech floormats. Duluth deluxe rear seat cover to go under the offroad approved car seats.... :P
    120,000 mile service. New spark plugs, oil change, 5 wheel rotation. Nothing too exciting... But the truck seems happy with new plugs, and my mpg looks like it maybe got a minor uptick.
  14. Feb 10, 2022 at 1:55 PM
    Malinois38
    Malinois38 New Member
    Pa.
    2022 Platinum Hybrid WCP
    Original muffler made it 14years in the snow/salt belt, not bad! Cherry Bomb Salute with a black tip. Tried to attach a video, but it wouldn’t let me. Sounds good, not too loud but loud enough for us 50+ Old School guys.
  15. Feb 11, 2022 at 3:09 PM
    Jorgesworld86
    Jorgesworld86 New Member
    Orange County,CA
    2013 Tundra Limited Rock Warrior
    Before and after
  16. Feb 12, 2022 at 7:08 AM
    FredB32
    FredB32 New Member
    Fred
    2011 TRD RW
    Added a "TRD" shift knob. It's an Amazon piece for $35... But looking it over, I'm willing to bet it's a legit TRD knob 'second'. There's a small scuff on the plastic that likely means it didn't pass quality inspection. But I expect it'll get scuffed up anyway, so I'm happy with it. No issues installing, perfect fit.
  17. Feb 12, 2022 at 7:11 AM
    Ohannon7
    Ohannon7 New Member
    Central Fl
    Today I started shopping for 17” wheels with 37” tires bc the 18” set I ordered on December 15th still are not available.
    It’s been 8 weeks already.
    For some reason 17” is readily available but I didn’t think I could fit 17” but after browsing a bit on the internet apparently I can
  18. Feb 12, 2022 at 7:15 AM
    FredB32
    FredB32 New Member
    Fred
    2011 TRD RW
    Jealous. From what I've read, the fuel gauges don't work with FFV so I'm SOL. I am strongly considering doing the LED swap once it's not 4 degrees.
  19. Feb 12, 2022 at 7:15 AM
    20GR8 Super
    Corey
    PNW Outskirts
    2007 Super White CM Limited
    I’ve got 17’s and 35’s. You have to run stock size brakes, and make sure that when they get balanced they put the weights at the edge of the wheel. They might clear the caliper but I didn’t want to risk it. There is not much clearance in there with 17’s
  20. Feb 12, 2022 at 12:44 PM
    shannon
    shannon New Member
    shannon
    Asheville, NC
    2010 DC
    It works with ffv
    Ohannon7 likes this.
  21. Feb 12, 2022 at 1:00 PM
    FredB32
    FredB32 New Member
    Fred
    2011 TRD RW
    I've read several places (including the manufacturer's website) that the sending unit on the FFV is different. It probably works overall, but the fuel gauge might not.
    You're saying that's not right? If not, this becomes an option (they're only like an hour and a half south of me).
  22. Feb 12, 2022 at 1:01 PM
    FredB32
    FredB32 New Member
    Fred
    2011 TRD RW
  23. Feb 12, 2022 at 2:22 PM
    Windsor
    Homeless in Oregon
    Some.
    Turned two antenna brackets into one. Didn't get a chance to do it last week, so I'll get it welded next time I go to town.
  24. Feb 12, 2022 at 3:08 PM
    Peeeheeuuu
    Peeeheeuuu New Member
    Peter
    Elk Grove, CA
    08 Tundra CM 4x4. 21 Sequoia SR5 4wd
    It's the small things that matter.
    Trooper2, D4x4TRD, wv00097 and 8 others like this.
  25. Feb 12, 2022 at 6:59 PM
    shannon
    shannon New Member
    shannon
    Asheville, NC
    2010 DC
    Yeah, I'm 100% positive the optitron cluster I have works 100%. I put it in my 2010 Flex fuel SR5. I got the thing off ebay a couple years ago. I have no idea what it came out of, would probably have to be a limited. There's a guy in Denver that I sent it to and he programmed the exact mileage I needed it to be and sent it back, wanna say it was $80 +shipping. The guy's warning seems pretty serious, but I'm not sure if he's right.
    D4x4TRD and Ohannon7 like this.
  26. Feb 13, 2022 at 12:01 PM
    Shanet421
    San Diego,CA
    Got the Optitron in today and I must say it’s very nice. I didn’t lose any gauges and everything works as it should. It’s cool to have all the extra features and settings. Money well spent!
    Also while I was in there I lowered the dash dimmer switch to the opening near the left knee and the tow/haul up to the open space near the right knee. I have plans to paint the last few grey pieces on the dash so organizing switches ahead of time.
    Trooper2, wv00097, tnbndr and 9 others like this.
  27. Feb 13, 2022 at 12:07 PM
    Shanet421
    San Diego,CA
    Next to go is the grey climate control knobs.
    3937FCAB-8D68-424F-9102-FEFC368DCC88.jpg 2F461905-67E7-4EE0-A672-7BC4FD4BBD82.jpg
    Trooper2, D4x4TRD, Filthyphil and 6 others like this.
  28. Feb 13, 2022 at 12:27 PM
    Ohannon7
    Ohannon7 New Member
    Central Fl
    I’m gonna relocate the dimmer as well, wonderful idea bc I always forget I have one bc it’s hidden from view, thank you!
    another reason I’m not super happy to have FFV. Guess I’m gonna keep the sweet JDM orange:( :pout::(
    Shanet421[QUOTED] likes this.
  29. Feb 13, 2022 at 3:53 PM
    Peeeheeuuu
    Peter
    Elk Grove, CA
    After such a long wait, these showed up on my door step today.
    King 3.0 16 inch triple bypass rear shocks for the tundra.
    D4x4TRD, WVI, Beachcomber and 12 others like this.
  30. Feb 13, 2022 at 4:59 PM
    digit4l-gh0st
    digit4l-gh0st New Member
    Tony
    East Texas
    2011 White Tundra SR5 4x4
    I started peeling the plasti-dip that the previous owner poorly applied off so I can reapply it later...
