FINALLY! Black Out Kit for Adults.
Discussion in '2.5 Gen Tundras (2014-2021)' started by woods, Feb 7, 2022.
  1. Feb 10, 2022 at 8:10 PM
    #61
    PNW_Husky
    PNW_Husky New Member
    Great Pacific Northwest
    2018 MGM CM Platinum
    Yes, minor drilling of the plastic welds. Just go slow and easy.
    Tundra805[QUOTED] likes this.
  2. Feb 11, 2022 at 4:49 AM
    #62
    NuTundra18
    NuTundra18 New Member
    Jimmy
    2020 TRD Pro CM - MGM
    Toyota OEM Hard Flip Tonneau, Predator Steps, Driver Grab Handle, Console Sage, Spray Berliner.
    All done, very high quality kit and another great product by MESO and crew!
  3. Feb 11, 2022 at 5:12 AM
    #63
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    Man when I had my Tundra I would have been all over this. Looks great!
    Taco-Spike likes this.
  4. Feb 11, 2022 at 7:14 AM
    #64
    5.7TRDProm
    5.7TRDProm What's bothering you?
    Dara
    2018 Cement Tundra SR5
    All stock-ish. Powdercoated blue suspension.
    Mines is expected to be delivered Monday. 4 years just taking that sun blinding, but I refused to go with the other kit that has rivet looking bolts and making my inside have some alien aircraft accents design.
    NuTundra18 likes this.
  5. Feb 11, 2022 at 1:24 PM
    #65
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    Sure would be nice if they would post the install video on this.
  6. Feb 11, 2022 at 1:39 PM
    #66
    timmyKGB
    timmyKGB New Member
    21 black tundra trd pro
    Any of our more advanced friends have any tips or a step by step for install?
  7. Feb 11, 2022 at 2:53 PM
    #67
    Predator Tundra
    Predator Tundra New Member
    Fallon, NV
    2020 Platinum
    So what holds the shifter trim in? I’m staring at my kit and I can’t figure that part out lol
  8. Feb 11, 2022 at 2:54 PM
    #68
    RusPro21
    Don
    Pa.
    No instructions to the kit?
  9. Feb 11, 2022 at 2:55 PM
    #69
    Predator Tundra
    Fallon, NV
    2020 Platinum
    Nope, and the video isn’t up yet
  10. Feb 11, 2022 at 2:57 PM
    #70
    RusPro21
    Don
    Pa.
    My email yesterday from meso said it would be asap. Not buying this kit till I see the install and then it will be out of stock. Oh well.
    south and Bergy24 like this.
  11. Feb 11, 2022 at 3:02 PM
    #71
    NuTundra18
    Jimmy
    Ok let me give some advice on this install. As for the shift gate piece, all I did was get an interior trim plastic tool and slide it between the chrome piece and the shifter panel and twist just a little and all the black welds just popped off nice and clean. I didn’t glue new piece in place, when you reinstall it back in truck it stays in with pressure when you clip in the shifter panel back into truck.
    As for the outer trim piece around shifter, I turned the whole panel over and used a 1/4” drill bit. I first took a razor to all the plastic welds to take off the rounded parts and flattened them all out. Then I placed a piece a tape about 1/2” up the bit and drilled very and I mean very slowly. Do not press down. Let the bit do all the work with the weight of the drill. Hold back the drill as much as possible. Once your through all 6 welds, then get a large flat head screw driver and pry the piece out start at each weld. Make sure to bend the tabs off the parts that lock in. Once you break the three welds on one side you can basically grab the panel and slowly break free the other side. Do this slowly.
    I hope this helps a few folks.
    bulldog93, OhEmmBee and timmyKGB like this.
  12. Feb 11, 2022 at 3:26 PM
    #72
    Predator Tundra
    Fallon, NV
    2020 Platinum
    Definitely helped thank you.
    Cthulhu likes this.
  13. Feb 11, 2022 at 3:28 PM
    #73
    NuTundra18
    Jimmy
    Nice and clean install!
  14. Feb 11, 2022 at 3:50 PM
    #74
    Predator Tundra
    Fallon, NV
    2020 Platinum
    The only thing I have ever found wrong with meso stuff. And no it’s not missing one I already took that one out.
  15. Feb 11, 2022 at 4:38 PM
    #75
    Badge618
    Badge618 New Member
    Lassen County, Ca
    2019 TRD Pro Voodoo Blue
    Can you take a picture of where you inserted the pry tool on the shifter gate replacement?
  16. Feb 11, 2022 at 4:47 PM
    #76
    NuTundra18
    Jimmy
    Sure, I slid the thin section of the tool under where the arrow is on the part in the picture. I used this tool in 2nd pic and circled it.
    bulldog93 and Taco-Spike like this.
  17. Feb 11, 2022 at 5:20 PM
    #77
    Badge618
    Badge618 New Member
    Lassen County, Ca
    So do I need to remove anything else before prying? I can’t figure out where to pry up the stock stuff.03C187F0-10C6-4E56-A3E7-52954799B45B.jpg
  18. Feb 11, 2022 at 5:25 PM
    #78
    Predator Tundra
    Fallon, NV
    2020 Platinum
    Take that off and look on the back you will see. It’s held on with 4 little tabs
  19. Feb 11, 2022 at 5:26 PM
    #79
    NuTundra18
    Jimmy
    you have the remove that whole black piece with the letters. Be easy with it, it just has a few tabs on each side and comes off real easy. You have to pry from the bottom side.
  20. Feb 11, 2022 at 6:02 PM
    #80
    Badge618
    Badge618 New Member
    Lassen County, Ca
    That’s the step I was missing and was trying to figure out how you popped the chrome piece off. Thank you for all of the help and advice. All finished up. D670FDDE-9AA0-4D6E-AA83-44923EBB22AE.jpg
  21. Feb 11, 2022 at 6:03 PM
    #81
    Badge618
    Badge618 New Member
    Lassen County, Ca
    How do I get my pics to rotate?
  22. Feb 11, 2022 at 6:14 PM
    #82
    chriszulli
    chriszulli New Member
    New Jersey
    2020 MGM Tundra TRD Sport
    I ordered one. Thanks for the info.
  23. Feb 11, 2022 at 6:16 PM
    #83
    Taco-Spike
    Two Trucks
    o_O
    wuut
    Beer Man likes this.
  24. Feb 11, 2022 at 6:47 PM
    #84
    Badge618
    Badge618 New Member
    Lassen County, Ca
  25. Feb 11, 2022 at 7:13 PM
    #85
    zlaneb
    zlaneb New Member
    Austin, TX
    Don't do it Man! I tried that, starting over is fun, recoving from totalling a Tundra sucks.
  26. Feb 11, 2022 at 7:20 PM
    #86
    2020cement_tundra
    2020cement_tundra New Member
    SC
    2020 tundra
    I bought one came in today, waiting on ajt shift gate to arrive before sticking it permanent
  27. Feb 11, 2022 at 8:56 PM
    #87
    Reekers529
    Reekers529 New Member
    I like the AJT:) should be here soon, does Meso offer knobs too?
  28. Feb 11, 2022 at 11:27 PM
    #88
    Bentarm13
    Bentarm13 New Member
    It seems funny that the "other guy’s" products were so well received by the vast majority but now some of you are calling them junk? The man puts out so many great products that a lot of us are very happy with. Many of you have stated you love some of his pieces, but the trim is trash. Grow up and just say you found something that suites your taste without bashing a very reputable businessman. Hurt feelings are for kickball, this is adult stuff where your sometimes stupid comments make you sound like trash.
  29. Feb 12, 2022 at 5:04 AM
    #89
    War Machine
    War Machine SSEM # 5 3MW
    I wonder if you could’ve promoted this product without shitting on the other one….
    Maybe you don’t like the AJT offering, but he has provided great service, and actually designed his stuff from scratch. I’ve no doubt that these guys used his as a model to make theirs.
    Your jackassery turns me off of the product, regardless of quality. Work on your social skills maybe.
  30. Feb 12, 2022 at 5:35 AM
    #90
    Taco-Spike
    Two Trucks
    He doesn’t. Yet?
    probably won’t though, I’m he didn’t for Tacoma except trim rings but no knobs. If you want knobs you’ll probably want ajt
