Turbo issue
Discussion in '3rd Gen Tundras (2022+)' started by Lowcountry4x4, Jan 9, 2022.
  1. Feb 10, 2022 at 6:05 PM
    #1021
    xc_tc
    xc_tc New Member
    Fucking wild. Repair methods are all over the place.
    Texmech and Breathing Borla like this.
  2. Feb 10, 2022 at 6:14 PM
    #1022
    Breathing Borla
    Northern Illinois
    otherwise known as caught with your pants down
    Tundrastruck91 likes this.
  3. Feb 10, 2022 at 6:30 PM
    #1023
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    On the plus side it will be an opportunity in the future to have them swap the grill and bumper on from a Sequoia….
  4. Feb 10, 2022 at 6:42 PM
    #1024
    DrZoidberg
    DrZoidberg New Member
    Dave
    Tesla MYP
    Someone posted on FB they had the bad turbos but was able to get them out by removing the exhaust system only.
  5. Feb 10, 2022 at 8:05 PM
    #1025
    winchester44
    winchester44 New Member
    2016 1794 4WD
    Good photo from FB with actuator circled.
    Acedude, raylo, Texmech and 2 others like this.
  6. Feb 10, 2022 at 8:09 PM
    #1026
    5thgen
    5thgen New Member
    Seattle
    2024 limited trd crewmax
    Seems like easy to replace that instead of the whole damn turbo.
  7. Feb 10, 2022 at 8:26 PM
    #1027
    bmc02
    bmc02 New Member
    Buddy
    E WA
    05 DC SR5 / 06 SEQUOIA LTD
    I've been spending too much time on these threads, half my Google news feed is turbo and wastegate related articles... I'm not even in the market for a 3rd gen. I'm like an onlooker coming out to watch the aftermath of a wreck. I can't look away...
  8. Feb 10, 2022 at 8:32 PM
    #1028
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Judging from the photo it seems WD-40 and some Never-Seize has completely solved this problem. Time to move on, nothing to see here.
  9. Feb 11, 2022 at 3:05 AM
    #1029
    dekeman
    dekeman New Member
    Derek
    Ottawa, ON, CANADA
    2022 Tundra Limted TRD
    Wheel-well access, from FB post, so consider the source (just like the frame-off photo).
    rideandfly, Acedude and raylo like this.
  10. Feb 11, 2022 at 3:26 AM
    #1030
    RavingOx
    RavingOx Member
    WNC
    2022 Tundra Platinum in Black
    And you can’t look away because more cars keep slamming into the pile.
  11. Feb 11, 2022 at 4:31 AM
    #1031
    Polo08816
    Polo08816 New Member
    2014 BMW 335i
    Facts.
  12. Feb 11, 2022 at 7:30 AM
    #1032
    xc_tc
    xc_tc New Member
    This is what I’ve been saying for awhile now. BUT turbo is not coming out the wheel well, it’s pulled out down between the engine and frame. The previous post showed the turbo with all the compressor side piping on it. That probably needs to come off though.
    Yeah, Toyota could but seems like Toyota is collecting the whole assembly for analysis.
    rideandfly and Acedude like this.
  13. Feb 11, 2022 at 8:22 AM
    #1033
    wired
    wired New Member
    2022 Tundra Black SR5
    I saw 3500 listed. Or about the same price as all these Gen2 guys on here will pay for their eventual cam tower fiasco, except theirs is coming out of their pockets.
  14. Feb 11, 2022 at 10:51 AM
    #1034
    Acedude
    Acedude New Member
    Colorado Plateau
    2019 Sequoia SR5 4WD
    RCI aluminum front skid, Timbren rear bumpstops, Carhartt seat covers and cargo area cover, Weathertech floorliners, Hewitt SAIP bypass, genuinecoolingsystems trans cooler, Lexus front diff fill/drain plugs
    Thanks, now we see the nuts and bolts. Seeing it's a two-part assembly illustrates and explains that TAS bulletin from TakiEvo a couple pages back. The wastegate actuator is a subassembly attached to the turbo. David Chao did a Youtube about this. So (after access by whatever means) the mechanic removes a circlip, a wire connector, a couple of bolts and the wastegate subassembly is out.
    Yeah, the turbo itself doesn't have to come off the exhaust manifold.
    Good photo.
    mountaingroan and rideandfly like this.
  15. Feb 11, 2022 at 11:08 AM
    #1035
    Wahayes
    Will
    2017 tundra limited
    Maybe they thought ahead and were like this is perfect we can do a turbo replacement and frame inspection at the same time lol:boink:
  16. Feb 11, 2022 at 6:27 PM
    #1036
    Texmech
    Texmech New Member
    Roger
    Oklahoma
    2022 Toyota Tundra TSS SR5 4dr Cr cab 4wd Blueprint
    Over 1300 mi and so far, GOOD.
    (Jan 5th build)
    Totherion, raylo, rideandfly and 6 others like this.
  17. Feb 11, 2022 at 7:13 PM
    #1037
    Coal Dragger
    Kung Fu Dick
    Awesome.
    mountaingroan and Texmech like this.
  18. Feb 12, 2022 at 4:52 AM
    #1038
    CMikeB
    CMikeB New Member
    Hopefully the
    With 86,000 miles on my 2010, I'll be sure to post on here about my "eventual"cam tower fiasco!:devil:
    stevesgraytundra likes this.
  19. Feb 12, 2022 at 5:11 AM
    #1039
    wired
    wired New Member
    My point is that no vehicle is exempt from issues. The pile on happening on this forum about an issue happening to a few 2022s is epic. We don’t know yet how many. But we do know about the cam tower leak. Most appeared between 60k to 100k miles. Check your driveway in the morning and Good luck. The Gen 2s are good trucks despite this and other known flaws. Tired of all the crapping on the 2022 by people just speculating with little knowledge. It’s a great truck.
  20. Feb 12, 2022 at 5:19 AM
    #1040
    CMikeB
    CMikeB New Member
    Garage floor stays dry, for now. I shine a flashlight on the cam tower area every now and again though! We've been buying Toyotas since '79 but if it fails me; it's gone.
  21. Feb 12, 2022 at 5:45 AM
    #1041
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    You’re right but it’s not like the new TTV6 is that much more efficient. They could have put put the new 10 speed transmission with new differential gearing and done just as well. Just sayin’.
    CMikeB and OnThaLake like this.
  22. Feb 12, 2022 at 5:50 AM
    #1042
    gmcguire7220
    gmcguire7220 New Member
    Ontario Canada
    2022 Limited TRD OR Crewmax - WCP- 2019 Toyota RAV4 Hybrid XSE
    TRD running boards & Falken Wildpeak tires
    But it’s also amount of emissions put out by engine, even if getting the same mpg. Not all are as “clean burning” which is I think the bigger part of it.
    Texmech, doublethebass and Mattedfred like this.
  23. Feb 12, 2022 at 5:56 AM
    #1043
    OnThaLake
    OnThaLake New Member
    Man, if people really cared about emissions, they'd be more honest with themselves and resist using a damn full size as a single occupant commuter.
    I mean, compared to people buying Platinum, 1794 or Capstone, what's wrong with buying an SR or low end SR5 and a new Corolla, same overall cost, only drive the truck when needed.
    Nope. People want to play the "better emissions" or "better mpgs" acting like someone actually cares.....
    Melikeymy beer likes this.
  24. Feb 12, 2022 at 6:10 AM
    #1044
    gmcguire7220
    Ontario Canada
    I agree, but there are many more factors than emissions alone for personal choices. Cost of insurance changes, parking changes, maintenance and upkeep changes. For some 1 veh is their “best option” so they will pick one Thant can do as much for them as they think they need (or want). Don’t get me wrong, my other veh is a hybrid that I put more miles on, for some of those reasons you mentioned.
    However, the manufacturers are facing emission standard #s across their whole line up. They get dinged for not meeting standards on their entire lineup, regardless of who or why people are buying them. They market is demanding trucks, so they will build them, but have to build them to meet standards. End users just want the vehicles they want. It’s a vicious cycle
  25. Feb 12, 2022 at 6:20 AM
    #1045
    OnThaLake
    Yeah I don't really blame people for buying a nice truck. It's a freedom we are able to enjoy.
    I should be more clear.... the legislative entities are just doing busy work to justify their paycheck.
    I, personally, have owned my current truck 13 years and also always had a second car to keep the miles off of the truck. Some years the truck only gets 2k miles, some 5k. We only use it for towing, road trips, off-roading, camping, working.
    I haven't found the cost to be any higher, having 2 vehicles. My truck rarely requires much, and my car has been dead-reliable too. Could be because I only buy Japanese.
  26. Feb 12, 2022 at 6:35 AM
    #1046
    OnThaLake
    Ha! Wow, man you are usually pretty level headed, but that's pretty far off.
    I mean, if you said they're doing it to avoid sanctions, I might buy that.
    The USA is no longer "competitive" on a global scale, at best we merely contribute.
    BTW, as a government employee, I can assure you that most agencies are busy growing themselves, like a cancer. These people only care about their resumes and "failing upwards"
    But I guess I've derailed a turbo thread way too much for one day!
  27. Feb 12, 2022 at 7:24 AM
    #1047
    Totherion
    Totherion New Member
    I'm sick of the "truck is fugly" opinions. Imagine these same people IRL buying a truck and someone walking by yelling "that is an ugly POS". Same energy.
    I would prefer people to post the goods and bads, be constructive and be helpful to other forum members.
  28. Feb 12, 2022 at 12:52 PM
    #1048
    wired
    wired New Member
    Yes. That is what I’m talking about. And if I say I have a good truck, I’m not speculating—I own one.
  29. Feb 12, 2022 at 1:01 PM
    #1049
    Retired...finally
    Oh, you mean the perpetual rust inhibitor application option?
    batman900 likes this.
  30. Feb 12, 2022 at 1:33 PM
    #1050
    737fixer
    737fixer New Member
    Wow, exactly what the Yugo commercials used to say.
