Turbo issue
Discussion in '3rd Gen Tundras (2022+)' started by Lowcountry4x4, Jan 9, 2022.
  1. Feb 9, 2022 at 9:31 PM
    #991
    5thgen
    5thgen New Member
    Seattle
    2024 limited trd crewmax
    1/22 build date is bad news.
    I think Toyota don't know wtf is going on. If it's a bad batch, the issue would have resolved itself once a good batch gets cycled into production lines. They're also losing money if they are purposely sending bad trucks out.
    At this point, they can't guarantee future trucks won't have the same issue. Therefore, no choice for them but to keep this quiet until they're certain the issue is identified, located, and fixed.
    My main concern is we have a ticking time bomb in every truck that will generate a 7k service bill once warranty period is over.
    paulphilly[QUOTED] likes this.
  2. Feb 9, 2022 at 9:35 PM
    #992
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    Toyota deletes posts with questions about known problems from their social media accounts. Rather than answer questions inconvenient to their marketing malarkey, they delete them.
    Does that answer your question?
    stevesgraytundra likes this.
  3. Feb 10, 2022 at 12:00 AM
    #993
    Tundrafan23
    Tundrafan23 New Member
    And people wondered why we wanted the trusty old 3UR-FE V8 to continue in 3rd gens?
  4. Feb 10, 2022 at 12:03 AM
    #994
    Tundrafan23
    How efficient is the new TT V6 sitting at the dealer waiting for repair?
  5. Feb 10, 2022 at 1:58 AM
    #995
    Coal Dragger
    Kung Fu Dick
    Super fuel efficient. Doesn’t burn any gas at all when it’s broken!
  6. Feb 10, 2022 at 3:19 AM
    #996
    raylo
    raylo not so new member
    Frederick, MD
    DashCam, amp & sub, DIY rear seat delete, cat shield, AMP power boards
    The other questions I have is that when a truck goes in with this problem do they, or can they even, test the other good turbo somehow in the absence of a separate trouble code? And have we had any "repeat offenders" where a truck has to go back again for an issue with the other turbo or to replace the first replacement?
    Mattedfred likes this.
  7. Feb 10, 2022 at 3:51 AM
    #997
    Retired...finally
    Glad you didn't let him walk all over you.
  8. Feb 10, 2022 at 6:15 AM
    #998
    OnThaLake
    OnThaLake New Member
    I was being sarcastic y'all!
  9. Feb 10, 2022 at 6:17 AM
    #999
    OnThaLake
    0 mpg is pretty bad efficiency if we spin it just right!
    raylo likes this.
  10. Feb 10, 2022 at 6:24 AM
    #1000
    OnThaLake
    I noticed that Toyota officially states "turbocharger sub assembly is not a serviceable part"
    This means that despite being 2 main, separate components, it is assembled in such a way that the entire assembly needs to be replaced.
    Basically, if the actuator is a $400 part, and it fails, you get to pay thousands to remove a good turbocharger.
    Not trying to bash the truck, but it's something to keep in mind for those who intend to own past warranty.
  11. Feb 10, 2022 at 8:25 AM
    #1001
    mass-hole
    mass-hole New Member
    I don't understand why the part costs so much. Raptor turbos and F150 turbos are <$600 including the electric actuator. Even a full blown Borg Warner EFR or Garrett G series turbos with their most advance compressor tech, light weight turbine materials, ceramic ball bearings, etc don't cost >$2000.
    Toyota sounds like BMW with their parts pricing.
  12. Feb 10, 2022 at 8:32 AM
    #1002
    Jaxyaks
    Jaxyaks New Member
    Reliability and resale...lol
    OnThaLake likes this.
  13. Feb 10, 2022 at 8:32 AM
    #1003
    raylo
    Frederick, MD
    Many many years ago I installed an alarm and remote start system in my Tacoma. As part of that process I removed the driver's seat and had to disconnect the seat airbag connector. I did something wrong and the connector body came apart and I managed to lose this tiny special spring. I went to Toyota and asked for the spring or at least the connector. But, LOL, it was only available as a unit with *the entire vehicle wiring harness*. I was able to measure the other spring and source one from a 3rd party.
  14. Feb 10, 2022 at 8:35 AM
    #1004
    xc_tc
    xc_tc New Member
    Probably for now they want to collect all the turbo parts. The wastegate actuator has a part number on it, probably can buy it in the future. I’m also sure there will be companies in the future that do rebuilds. When I had a WRX, I sent a turbo in to a company to have it rebuilt after the turbine housing cracked near the wastegate. Didn’t cost too much.
    ryanwgregg and raylo like this.
  15. Feb 10, 2022 at 8:39 AM
    #1005
    raylo
    Frederick, MD
    That makes sense. They really need to do a thorough post-mortem on this now as part of the TSB to nail down the cause so need the entire assembly. But I wonder if the Toyota parts catalog lists these parts separately and they would be available in the future for routine failures?
  16. Feb 10, 2022 at 8:44 AM
    #1006
    xc_tc
    xc_tc New Member
    Yeah, that’s true. Sometimes you can order a part if you have the part number but dealers may not make the actuator part available.
  17. Feb 10, 2022 at 8:52 AM
    #1007
    mass-hole
    Apparently not. Hence this 36 page thread.
  18. Feb 10, 2022 at 8:54 AM
    #1008
    mass-hole
    So what you are saying is I can source an electric actuator for my Tundra turbo at the local Ace Hardware?
    JK
    raylo[QUOTED] likes this.
  19. Feb 10, 2022 at 9:01 AM
    #1009
    raylo
    Frederick, MD
  20. Feb 10, 2022 at 12:06 PM
    #1010
    borla123
    borla123 The Pits
    Ontario
    18 Tundra TRD OR - '17 4Runner Torsen Full Time 4wd
    Driver Grip Handle Borla Dual, Line X, ESP Underseat
  21. Feb 10, 2022 at 12:34 PM
    #1011
    OnThaLake
    Ford uses a ton of Chinese made parts on their vehicles. In the turbo aftermarket, Chinese turbos are a fraction of the cost of name brand turbos.
    I'm not saying that is the case with Ford, but it's a possibility.
  22. Feb 10, 2022 at 12:39 PM
    #1012
    winchester44
    winchester44 New Member
    2016 1794 4WD
    Would love to know more about what the TAS and MIL in the recommendations mean along the last note about not replacing without direction from TAS.
  23. Feb 10, 2022 at 12:47 PM
    #1013
    winchester44
    2016 1794 4WD
    We do wonder as that would not have made sense, at least not for US Market with latest CAFE standards. You want to complain about that call your congressperson, stop putting that on Toyota.
    Mattedfred and Nm6300'asl like this.
  24. Feb 10, 2022 at 12:50 PM
    #1014
    winchester44
    2016 1794 4WD
    False equivalence is a logical fallacy in which an equivalence is drawn between two subjects based on flawed or false reasoning i.e. comparing an apple to an orange.
  25. Feb 10, 2022 at 12:52 PM
    #1015
    winchester44
    2016 1794 4WD
  26. Feb 10, 2022 at 1:03 PM
    #1016
    wired
    wired New Member
    2022 Tundra Black SR5
  27. Feb 10, 2022 at 2:22 PM
    #1017
    5thgen
    5thgen New Member
    Seattle
    I think they charge 4.7k for just the turbo. Some engines cost less than that.
  28. Feb 10, 2022 at 5:23 PM
    #1018
    trazerr
    trazerr New Member
    Oregon
    2024 Toyota Tundra Platinum LR
    Guess this is another way to do it. Seems a bit excessive…
  29. Feb 10, 2022 at 5:28 PM
    #1019
    OnThaLake
    It's fine, it's fine.... nothing to see here, move along folks .......
    Breathing Borla likes this.
  30. Feb 10, 2022 at 5:56 PM
    #1020
    5thgen
    5thgen New Member
    Seattle
    You'd be limping halfway home with a turbo failure.
    Retired...finally and OnThaLake like this.
