Suspension Help and Advice
Discussion in 'Suspension' started by big_t1986, Feb 16, 2017.
  1. May 28, 2017 at 4:20 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Add a leaf and some shackles either from coach builder or Toytec.
    Jsena likes this.
  2. May 28, 2017 at 4:23 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    We add a "leaf" to the one we already have? Or replace it with a bigger one?? And that can get 4 inches??
    Law323[QUOTED] likes this.
  3. May 28, 2017 at 4:28 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    You can get a 2" AAL and 3+ shackles, that should give you 4"
    Jsena likes this.
  4. May 28, 2017 at 4:30 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Okay and does that AAL replace the one I have now
  5. May 28, 2017 at 4:32 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Nope. It "adds a leaf". Will make your ride stiffer though.
    3+ shackles will add 1.75" so you may have a quarter of an inch less than you want, but then again, you can get a 2.5 AAL
    Jsena likes this.
  6. May 28, 2017 at 4:38 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Looked online, those are re about $100 each so that's about $200 for those plus whatever the coach builders cost
  7. May 28, 2017 at 4:55 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Yep. Not cheap
    Jsena likes this.
  8. May 28, 2017 at 4:59 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Nah that's cool. I was thinking that would be like 1k plus.. so maybe this could be another option to me.. everyone says this is a better way than blocks, right??
  9. May 28, 2017 at 5:10 PM
    Eclipsed & Floating
    Eclipsed & Floating Over it.........
    I’m right where I need to be
    Voluptuous Whitey
    You CAN replace the leaf pack, which is what I'm about to do. It's more costly but it's what I need.
    Adding a leaf will give you some height but stiffens the ride. If that's good with you then it's definitely the more economical route
    Law323 and Jsena[QUOTED] like this.
  10. May 28, 2017 at 5:15 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Well if I replaced instead of adding, can I acheive the height??
  11. May 28, 2017 at 5:22 PM
    Eclipsed & Floating
    Voluptuous Whitey
    Very much so. The options are endless if you replace. There are custom builders out there that can do pretty much whatever you want, but it's gonna cost much more.
    If I were you I would take the @Law323 advice. My needs are different than yours. My suspension is different, and my height is different. You're not doing the same stuff as me and you're not carrying what I do.
    What he suggested can and will add some height.
  12. May 28, 2017 at 7:15 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    MUCH better than a 4" block. If you were only putting in a 1"-1.5" I wouldn't worry about the AAL.
    Now if you want to replace the whole leaf pack, @Almaboy is spot on when he says there are endless possibilities out there and just as many custom shops that will do what you ask them to do.
    It all boils down to what you want and what you're using your truck for. If I were to haul and tow a lot, I wouldn't have put 1" blocks on mine, much less a 4 incher. Although, I am thinking of getting an 1.5" Icon leaf pack when I bump up my tires to 295/70's.
  13. May 28, 2017 at 7:17 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    I don't have anything to tow or haul.. it's just for looks.. I just wanted to know other options besides the blocks and thanx bro... appreciate it
  14. May 28, 2017 at 7:20 PM
    Eclipsed & Floating
    Voluptuous Whitey
    When i get Jay to let me borrow some money i'm going to go with the Alcan custom pack with a 500 lb overload. It's 9 thin leafs and i'm going to add in a 1.5 lift curve to add the extra height. From what i understand you cant overstress their leaf packs. I've really been investigating and am almost sold. It might come down to price between those and the Deavers
    Jsena and Law323[QUOTED] like this.
  15. May 28, 2017 at 7:23 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Anytime bud! Good luck!!
    Jsena[QUOTED] likes this.
  16. May 28, 2017 at 7:24 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    you have a topper right?
    That'll definitely help!!
  17. May 28, 2017 at 7:25 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    All that sounds cool, but I have no clue what any of that is.. lol I'm so lost when it comes to all this truck stuff...
    Law323 likes this.
  18. May 28, 2017 at 7:28 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Just an aftermarket replacement leaf pack with a 1.5" AAL (basically)
    Allan and deaver make some good leaves.
    A year ago, I swear I was so lost when it came to this stuff, but spending so much time on here, researching the net and picking others brains (probably aggravating them to no end) helped a ton!
    CM-LENNY likes this.
  19. Jun 7, 2017 at 6:20 PM
    Payaso 9394
    Payaso 9394 New Member
    Ricky
    La Puente CA
    16' Tundra 2wd CrewMax 5.7l
    Tint, 33x12.5r18
    Hey guys I'm also doing a 4 inch lift I'm 2wd using Coilovers in front with maxtrax spindles for rear would it be fine with just a 1.5 toytec shackle?
