Oil burning question
Discussion in '2.5 Gen Tundras (2014-2021)' started by JEHTUNDRA, Jan 30, 2022.
  1. Jan 31, 2022 at 8:01 PM
    stevesgraytundra
    stevesgraytundra New Member
    Stephen
    2021 MGM SR5 CM 4x4
    I only have 3,800 miles. Changed it at 2,000 with Pennzoil Ultra Platinum and haven’t lost/burned a drop. I didn’t notice any loss in the first 2,000 either. I had a Subaru that burned oil from day 1, so I know how frustrating it can be. So far, not a hint of oil consumption with my 3UR-FR.
  2. Jan 31, 2022 at 8:58 PM
    Ders
    Ders Washington
    Washington
    2014 Tundra
    MKW Chrome Off-Road Wheels 275/65R20 Tires Bilstein 5100 Middle Setting In the Front, 1/2 Block in the Rear Highway Products Gull Wing with Roof Rack Tracks Protech lumber rack LED headlight and foglight bulbs 30% Front window tints Boost Auto Tow Mirrors
    Mine never lost any oil. Then at 150k miles or so I went to the Mobile 1 high mileage, now it seems to consume about 1/2qt or so every 5k miles. I might change back to normal mobile 1. We’ll see.
    Hoff likes this.
  3. Feb 1, 2022 at 3:41 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    My 2017 says 7.9 quarts for oil and filter change. It takes 8.4 quarts to get it to the top line. If anyone is using the top line as their point of reference. I've now done 8 engine oil changes and can you indubitably that's what she takes. My oil level has never changed after an oil change in the 80,000 miles she has gone.
  4. Feb 1, 2022 at 4:02 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    ditto
    and (i use Kirkland 0w-20)
    '20 tundra does not burn any oil
    '15 4Runner does not burn any oil
    '18 Highlander does not burn any oil
    '21 Tesla MS Plaid does not burn any oil
    history
    '11 Lexus LS460L no oil burn...in-laws are cruising it now. 9.6qt sump!
    06 Sequoia no oil burn...loved that beast...still chugging with 2nd owner
    '96 4Runner no oil burn...it's still on the road.
    Hoff likes this.
  5. Feb 1, 2022 at 6:51 AM
    Mr_Ed
    Mr_Ed New Member
    Ed
    2018 Limited 5.7
    None
    The oil level drops considerably when the engine is running. Both my bikes have a sight glass, and the oil level drops completely out of sight when they're idling.
    If the oil level is fine with cold oil, it's gonna be fine with hot oil. It may be a bit higher on the stick because of expansion, but if there's enough it it cold, there will still be enough in it hot.
    To gauge oil consumption (the subject of this thread) my main concern is repeatability. I check my vehicles sitting in the same place with cold oil after they've not been run for quite a while and can easily see if the level on the stick drops. I doubt it matters much how it's done, but that's why I wondered if JEHTUNDRA was comparing apples to apples in the opening post.
    Just for fun, (I'm easily amused ;) ) I checked my oil this morning cold. My wife is gone in the truck now, and when she gets back, I'm going to let it sit for 5 minutes and check it again. It'll be interesting to see how much it changes.
  6. Feb 1, 2022 at 6:56 AM
    2mchfun
    I would bet most check it cold after a drain and fill anyway. I have never done an oil change on anything and run it 5 minutes before checking the level.
  7. Feb 1, 2022 at 7:09 AM
    Mr_Ed
    Mr_Ed New Member
    Ed
    2018 Limited 5.7
    None
    I run it long enough to fill the filter and check for leaks. Then I let it sit level while I take care of the old oil and put stuff away before checking. It's way more than five minutes.
  8. Feb 1, 2022 at 7:11 AM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    2008 Tundra DC 4x4 5.7l V8 Blue Streak Metallic
    Goodyear UltraTerrain AT 275/70/r18, Stoptech Cryo Slotted Rotors/Hawk LTS Pads, DECKED, and lots more!
    Have owned my truck from 104k miles and it has 148k on it now. I run 10k oil change intervals w/full synthetic Schaeffers. It looses about .5-1qt p/5k miles consistently. Honestly, it was loosing more like 1.5 when running Mobil1, as that oil seems to have a higher evaporation than others (Project Farm). I'd say your loss is completely normal and no worries. As long as you're within your hash marks on the dipstick, you're good. I'm anal too and try to keep my oil a the top of the dipstick as well. If I forget to check it...then I know I have PLENTY of reserve till its too low to worry.
  9. Feb 1, 2022 at 7:13 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    What does the owner's manual say is the proper procedure for checking and verifying oil level?
    Are your comparisons over the life of an oil change always completed under the same conditions?
  10. Feb 1, 2022 at 7:17 AM
    Wallygator
    Got into this pretty deep when I thought I had an issue. Long story short, I will now do 5000 mile oil changes only. Severe duty change interval. YMMV.
    https://youtu.be/v4JS7PybV2k
    2mchfun likes this.
  11. Feb 1, 2022 at 7:22 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    Damn, what kind of oil you using for a 5,000,000 interval?
  12. Feb 1, 2022 at 7:24 AM
    Wallygator
    Amsoil! What else! :p... Im on the phone, I'll fix it. Big thumbs on a little phone....
    https://tenor.com/ooQj.gif
    2mchfun and 14burrito[QUOTED] like this.
  13. Feb 1, 2022 at 7:29 AM
    xJuice
    xJuice This guy...
    Josh
    DFW, TX
    '19 MGM DC SR5 4.6 TSS
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill, Remote Start, One-touch Auto Windows
    Tundra Manual:
    Doesn't state specifics, but says oil consumption is normal.
    P.S.
    Y'all don't want to see what my 07 Tacoma manual stated for oil consumption.
  14. Feb 1, 2022 at 7:51 AM
    Wallygator
    I would say some oil consumption is normal, but over a quart in 5000 miles is not.
    2mchfun likes this.
  15. Feb 2, 2022 at 8:46 AM
    Mr_Ed
    Mr_Ed New Member
    Ed
    2018 Limited 5.7
    None
    OK. After my wife returned, I let the truck sit for 5 minutes or so and checked it. It was actually lower on the dipstick than it was when cold and sitting overnight -- not a lot, but some. That actually surprised me a little; I thought it'd drain back faster than that. The level is really hard to see in the photos, but I didn't doctor them any. The arrows point to the true level after pulling, wiping, then checking.
    At any rate, I think we're all overthinking it. :)
    2mchfun likes this.
  16. Feb 2, 2022 at 8:51 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    This makes sense, when the oil is hot, it means the engine was running recently, thus, the oil from all the nooks of the engine havent fully drained down yet. I would think cold would be the best indicator of true oil level.
